How aggressive do you ride in the wet?
How aggressively do you ride if it's been raining, compared to normal conditions?
100%, same as if it were dry.
6%
 6%  [ 6 ]
90%
1%
 1%  [ 1 ]
80%
11%
 11%  [ 10 ]
70%
25%
 25%  [ 23 ]
60%
14%
 14%  [ 13 ]
50%
21%
 21%  [ 19 ]
40%
5%
 5%  [ 5 ]
30%
10%
 10%  [ 9 ]
20%
0%
 0%  [ 0 ]
10%
4%
 4%  [ 4 ]
Total Votes : 90
Lord Percy
PostPosted: 11:35 - 29 Sep 2016    Post subject: How aggressive do you ride in the wet? Reply with quote
When the road's wet I go into ultra-safe mode, mainly when cornering where I barely dare to lean at all.
I'm certain I could push it a bit more but after 10 years of being a skater boy I see wet tarmac and relate it to the loss of grip on polyurethane skateboard wheels, which is far worse than the loss of grip on rubber bike tyres.
Instead of testing the limits myself and risking a crash, I figured it would be best to get some general consensus from BCF.
Not that I want to take the piss and/or kill myself; I just wonder how my reaction to wet conditions compares to that of everyone else.
Thoughts/experiences welcome or just answer the poll.
Cheers Thumbs Up
BrownTrousers
PostPosted: 11:41 - 29 Sep 2016    Post subject: Reply with quote
I clicked 70%.
In the wet I tend to go almost as fast as normal in most places, but I cut back a lot on filtering and overtakes or other manoeuvres that increase the likelihood of something unexpected happening.
Bikers make great organ donors - add your name to the register
Ducati Multistrada 950 | Triumph Tiger 800 XR | Honda CBR500R | Yamaha YBR 125 Custom
stevo as b4
PostPosted: 11:48 - 29 Sep 2016    Post subject: Reply with quote
Loss of grip from aqua planing should be more of a worry IMO. On good tarmac free from road paint, mud, oil, leaves etc pure lean angle alone should not reduce grip by much at all over a dry road.
Its acceleration and hard braking or combining these with cornering and big lean angles that you want to avoid.
Ok you can wash out the front tyre from overloading it with say throwing it over in a bend with no throttle applied. But on a neutral throttle a bike should be well balanced, and I've never been scared of leaning over as much in the wet as I would in the dry, as long as your not crossing manholes or other low friction surfaces or debris in the road.
wots
PostPosted: 12:15 - 29 Sep 2016    Post subject: Reply with quote
I'll take the option not listed, depends on the bike.
MSX125 with City Grip winters, doesn't change much, as it grips all the time. Some of the roundabouts I can go much quicker in the wet, than in the dry on a bigger more powerful bike.
Other bikes, between 50-70% depending on the weather.
My first bike a CBF125, at times 10%, skinny crappy tyres and the first sign of any damp and it became dangerous.
B5234FT
PostPosted: 12:42 - 29 Sep 2016    Post subject: Reply with quote
I back off a lot, similar to you through lack of confidence in what the bike will do/the road conditions and through fear of the consequences (a slide in a car is fine, less so on the bike).
I live in the sticks where there is almost always mud/crap/diesel/whatever which exacerbates the change from dry to wet and the unpredictability around the next corner
PostPosted: 12:50 - 29 Sep 2016    Post subject: Reply with quote
I saw a patch of that, once!
I'm even more careful in the wet than the dry, particularly on roundabouts. The GS in particular has had a few wobbles and weaves thanks to all the rainbow unicorn vomit sloshing around.
tom_e
PostPosted: 12:51 - 29 Sep 2016    Post subject: Reply with quote
If it's just damp/wet from earlier rain then I'll ride around 70% if it's actually peeing down at the time then it probably comes down to 50ish.
Lord Percy
PostPosted: 12:58 - 29 Sep 2016    Post subject: Reply with quote
BrownTrousers wrote:
I clicked 70%.
Interesting, I tend to go the same for filtering etc whether it's wet or dry. My only big worry is cornering in the wet really.
Me too.
Aye well this is the main thing for me in the wet. Not that I'm anything like a 'knee down' guy as it is, but I pretty much don't lean at all sometimes if the floor is wet. OTT safety cornering.
tom_e
PostPosted: 13:06 - 29 Sep 2016    Post subject: Reply with quote
I clicked 70%.
I reduce my filtering simply because white lines/cats eyes can be bad enough in the dry nevermind skipping over them in the wet.
M.C
PostPosted: 13:09 - 29 Sep 2016    Post subject: Reply with quote
Not aggressive at all, riding in the wet's about being smooth. Less lean angle when cornering and being more caution on roundabout's, although a lot of that's due to having crap wet grip with my current tyres. With decent tyres you can still have fun and not have to take it too easy.
el_oso
PostPosted: 13:10 - 29 Sep 2016    Post subject: Reply with quote
filtering is probably where I take the biggest hit in terms of reduction in speed. I don't want to be grabbing at the front brake when some tit pulls out in front of me in the pouring rain.
I used to be a lot more cautious. Since getting rid of the gixxer, I've had a lot of fun sliding the 125 and 250 round.
Duke 390
Car: Jeep Wrangler 4.0L
Notj7
PostPosted: 13:17 - 29 Sep 2016    Post subject: Reply with quote
Barely any lean angle in the wet. Slow and steady, and no filtering. It's shit, basically.
Left the forum.
BTTD
PostPosted: 13:28 - 29 Sep 2016    Post subject: Reply with quote
I clicked 70%, although I would say that it depends on the road surface and the type of rain.
Heavy on-going rain that's washed the road clean and runs off the visor is usually less of a concern than a hanging misty drizzle that just lifts all the greases in the road up and turns it into a slippery slick where every pot hole repair and overbanded bump has the bike squirming, and best of all you can't see f'all.
I'm thinking back to one specific winters night ride in drizzly mist where I was just glad to get off the bike. I even stopped mid journey to check the tyres as the bike felt horrible.
PostPosted: 13:29 - 29 Sep 2016    Post subject: Reply with quote
I'm terrible in the wet most of the time. Goes back to having truly horriffic tyres on my first few bikes and repeatedly falling off on wet patches on the road.
I carry on fine, and my new tyres are fantastic in the wet. Then something slips or shimmies, even slightly and I totally lose my mojo for the rest of the ride. I comfort brake, 50p corners, run wide, wobble, death grip, feather the throttle, trail brake, hold my breath round corners, grip the bike with my knees etc. Pretty much everything but foot dab (althought I see that's a thing now).
Lord Percy
PostPosted: 13:48 - 29 Sep 2016    Post subject: Reply with quote
stinkwheel wrote:
trail brake
Yeah my rear break becomes primary in the wet.
Rear wheel skid = survivable thanks to years of doing the same thing on pushbikes as a kid.
Front wheel skid = hello floor and hello incoming lorry on the other side of the road (that's what I tend to think on most corners anyway Laughing)
trevor saxe-coburg-gotha
PostPosted: 13:59 - 29 Sep 2016    Post subject: Reply with quote
Depends what kind of "wet". A road pelted with more rain after a day or two of heavy rainfall is imo a lot better than a thin coating of rain on a road that's been dry for ages.
Kris
PostPosted: 14:02 - 29 Sep 2016    Post subject: Re: How aggressive do you ride in the wet? Reply with quote
Voted 70%
That's for when it's proper wet, or damp but drying.
When it's just rained after a long spell of summer sunshine I often reduce it a bit more because greasy y'all.
Modern tyres grip in the wet, as long as road conditions allow. I'm pretty obsessive about spotting manhole covers and white lines rather than slowing down per say.
www.prisonplanet.com
Derivative
PostPosted: 14:05 - 29 Sep 2016    Post subject: Reply with quote
I basically ride the same with the exception of filtering. White lines or no white lines, that's where my handling is affected in a way that has a decent probability of resulting in endeadening.
I tend to be a bit of a squirt in a straight line rider, though, mostly because 90% of my rides are commuting and avoiding hazards on roundabouts at speed is not fun.
PostPosted: 14:47 - 29 Sep 2016    Post subject: Reply with quote
The only change I make is greater braking distances and a lot more gentle with the brakes, a lot more gentle tipping in. Just generally treating the controls like they're made of glass.
I still filter etc in the wet.
Teflon-Mike
tl;dr
PostPosted: 15:07 - 29 Sep 2016    Post subject: Reply with quote
I'm 'tempted' to tick 100%... question is too subjective for the scale suggested.
Check wet lap times vs dry in road-racing, and they are usually pretty close, within 10% or so, often less. Maybe slightly flattered in the higher classes where they may run slicks in the dry and wets in the wet; or alternative grades of 'production' tyres; but in the rankings they often don't have that luxuary, and run a control tyre in all weathers, and still stay in that sort of window.
On the road..... shouldn't be riding 'that' aggressively to start with.... Public roads are usually that much crapper and less consistent, and road tyres compromised for life and 'all-round' conditions, AND you have all the added risks and hazards and inconsistancies of pop-up pedestrians, un-emmission control live-stock; uncovered skip-trucks, etc etc etc....
A 'bit' of rain, shouldn't 'really' need to see very much greater degree of caution applied to riding in the dry; if I do apply any, it will generally be due to reduced visibility, in worse weather, than from worries of diminished traction.
It's a variation of the summer vs winter debate, where it's oft asked how much 'slower' you ride in the winter to in the summer, that is to my mind a bit backwards.
Question would be better put the other way about, and slightly re-phrased; "How much 'harder' do you ride; how much more 'blase' are you of the risks in the dry/summer, are you than in the wet/winter?"
Because the reveal is usually how much we let good weather and good conditions over-inflate our confidence, above what is probably prudent, rather than the other way about.
PostPosted: 15:15 - 29 Sep 2016    Post subject: Reply with quote
I ride like a granny with a full colostomy bag anyway, so not an awful lot different.
faffergotgunz
PostPosted: 15:23 - 29 Sep 2016    Post subject: Reply with quote
60-70%
Accelerate in 3rd instead of 2nd to avoid spinning up, be gentle with back brake to avoid locking up, ride slower due to crap visibility and cars with reduced visibility. Mud on road will be more slippery, manhole covers ect...
Will fatigue quicker due to higher concentration (trying to pick the road out at night in heavy rain is shit!), so take more breaks...
Sent from Samsmums mobile using Tapanarse
pompousporcup...
PostPosted: 15:31 - 29 Sep 2016    Post subject: Reply with quote
for me, the wet (even if its just drizzled) makes me scared. I've already had one hard fall and don't want to repeat it. I'm no stranger to falling - i've ridden bmx for years and skated the streets for over a decade but im not getting any younger and certainly dont bounce as well as i used to
its mainly in the corners where i'm cautious. any corner, no matter how sharp i shit myself, death grip, squeeze my knees and pray Laughing I still filter in the wet/rain, just a bit slower than usual(which is probably too fast to start with). Braking is obvs done much sooner than in the dry
Teflon-Mike makes a very good point though Thumbs Up its amazing just how much my attitude changes to corners on a dry day
Baffler186
PostPosted: 15:36 - 29 Sep 2016    Post subject: Reply with quote
If wet, or damp, I accelerate out of corners at 50%. I go round corners 30% slower. I don't go any slower in straight lines unless there are hug puddles, which is very rare in the hilly westcountry.
I do find that a very mild drizzle after a dry spell is worse than actual rain - wet enough to make a slippy surface (especially on a bus route) but not enough rain to give it a good wash.
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
recman
PostPosted: 16:16 - 29 Sep 2016    Post subject: Reply with quote
If I ever get caught in a light drizzle, I'll be pushing it on the pavement.
The last post was made 10 years, 46 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 1.05 - MySQL Queries: 15 - Page Size: 137.21 Kb
