handlebar grip removal
White Noise
Mr Dudwee
PostPosted: 22:16 - 28 Feb 2005    Post subject: handlebar grip removal Reply with quote
Hi all,
has anyone got any tips for getting handle bar grips on and off,
WN
Guest
PostPosted: 22:29 - 28 Feb 2005    Post subject: Reply with quote
Stick a flat bladed screwdriver down the grip from the inner end and squirt a bit of WD40 down there and work it round - it'll come off easy.
To put back, make sure you've got rid of all the WD40 - you don't want the grip sliding off again - and spray the bar with hair spray. Slide the grip on and the hairspray will evaporate and the grip'll stick.
mr jamez
Are you replacing them with new ones? if so and they are really stubborn, just cut the up with a stanley knife.
binge
Emo Kiddy
PostPosted: 22:44 - 28 Feb 2005    Post subject: Reply with quote
Yea, If you dont want the old ones. Just slice it straight along and it will come straight off...
Reaplying new ones, Ive found hair spray works brilliant. That or Carburettor cleaner. They both evapurate very quickley...
<|Ben|>
White Noise
Mr Dudwee
PostPosted: 22:49 - 28 Feb 2005    Post subject: Reply with quote
i'm replacing the whole bars after they got bent in a fall today, think i am going to replace them but the WD40 did the trick, cheers for that! also i need to ask there is a load of grease under the throtle and on the lever joins, can i use lithem grease to re-grease them?
WN
PostPosted: 00:50 - 01 Mar 2005    Post subject: Reply with quote
Hairspray for fitting new ones Thumbs Up
Any grease will be OK as it is neither a high speed or a high load use. I would usually use copper grease on the pivots and Moly grease on the cable nipples. Lithium is usually used for high speed aplications such as bearings but will do a good enough job. I suppose in an ideal world you would use graphite grease for metal on metal contacts as it will still work once the grease has dried out but you never see graphite grease these days.
The last post was made 21 years, 267 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 1.28 - MySQL Queries: 15 - Page Size: 47.93 Kb
