| White Noise |
 White Noise Mr Dudwee
 Posted: 22:16 - 28 Feb 2005 Post subject: handlebar grip removal |
Hi all,
has anyone got any tips for getting handle bar grips on and off,
Cheers
WN ____________________ Buy my wife: 96' Yam XJ600s (Diversion)
Wing Commander White Noise - SE Clique
Riding Tip #86: See God, then back off a bit: Problem is i haven't seen god yet, just a close up of tarmac on revett straight |
| Guest |
 Guest Brolly Dolly
| mr jamez |
 mr jamez World Chat Champion
| binge |
 binge Emo Kiddy
| White Noise |
 Posted: 22:49 - 28 Feb 2005 Post subject: |
i'm replacing the whole bars after they got bent in a fall today, think i am going to replace them but the WD40 did the trick, cheers for that! also i need to ask there is a load of grease under the throtle and on the lever joins, can i use lithem grease to re-grease them?
Cheers
 Posted: 00:50 - 01 Mar 2005 Post subject: |
Hairspray for fitting new ones
Any grease will be OK as it is neither a high speed or a high load use. I would usually use copper grease on the pivots and Moly grease on the cable nipples. Lithium is usually used for high speed aplications such as bearings but will do a good enough job. I suppose in an ideal world you would use graphite grease for metal on metal contacts as it will still work once the grease has dried out but you never see graphite grease these days. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 21 years, 267 days ago. Instead of replying here, would creating a new thread be more useful? |
