| onlyJaz |
 onlyJaz Scooby Slapper
| MarJay |
 MarJay But it's British!
| onlyJaz |
| MarJay |
| Rogerborg |
 Rogerborg nimbA
 Posted: 10:59 - 09 May 2017 Post subject: |
Is it a thickish round-section rubber gasket, or a thin, flat one that's a bit fibrous?
Round-section are usually re-usable. If it's a flat one, they don't tend to squish back down as evenly.
For the sake of a few £££ you might as well replace it.
Pikey options are:
Make your own from a cereal packet. Yes, totes srs.
Seal the existing one with blue hylomar / RTV gasket sealant. Clean off the gasket and the faces thoroughly, and use a very thin smear towards the outside of the gasket. Having it squidge out of the casing is fine, you don't want any being squidged inside and getting in the oilways. ____________________ Biking is 1/20th as dangerous as horse riding.
| Hawkeye1250FA |
 Hawkeye1250FA World Chat Champion
 Posted: 11:03 - 09 May 2017 Post subject: |
| MarJay |
 Posted: 11:07 - 09 May 2017 Post subject: |
That's why so many second hand bikes are fcuked. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| Hawkeye1250FA |
 Posted: 11:19 - 09 May 2017 Post subject: |
| MarJay wrote: |
That's why so many second hand bikes are fcuked. |
Its fine. ____________________ 1993 RF400R - 2002 Bandit 1200 - 2012 1250 FA |
| MarJay |
| Hawkeye1250FA |
| onlyJaz |
 Posted: 12:02 - 09 May 2017 Post subject: |
| Rogerborg wrote: | Is it a thickish round-section rubber gasket, or a thin, flat one that's a bit fibrous? |
It's a thin, flat one.
| Rogerborg wrote: |
Pikey options are:
Seal the existing one with blue hylomar / RTV gasket sealant. Clean off the gasket and the faces thoroughly, and use a very thin smear towards the outside of the gasket. Having it squidge out of the casing is fine, you don't want any being squidged inside and getting in the oilways. |
Lol wow cereal box! I've ordered a gasket from eBay for £6 (I know it's not too cheap but I need it soon) so it should be arriving by Thursday latest, as should my torque wrench.
So hopefully on Friday afternoon/Saturday morning I will crack on with it and change the air filter/spark plug/lube chain while I'm at it.
I'm also going to attempt tightening my chain as it's a little loose but first need to research if it's beginner friendly. Hopefully it'll feel like a much improved bike with this maintenance (I think it's been a while since it had its last service ____________________ Yamaha YBR 125 |
| Hawkeye1250FA |
| Islander |
 Islander World Chat Champion
| chris-red |
| MarJay |
| Hawkeye1250FA |
 Posted: 12:55 - 09 May 2017 Post subject: |
I think the noob comment is key there.
An idiot using the correct tool incorrectly can still break something. In the same way that an experienced person can use the wrong tool and still get the job done safely. (caveat: this in no way should be taken as an admittance that instant gasket is the "wrong" tool... Its an analogy)
and I disagree Chris-red (on your costings at least). I'm still using the instant gasket I paid £12 for a good few years ago. I use about 5ml or less for a gasket. so it costs me roughly 22p for a gasket that (imo) works perfectly well.
| arry |
 arry Super Spammer
| arry |
 arry Super Spammer
| onlyJaz |
 Posted: 10:49 - 14 May 2017 Post subject: |
An update guys..
So I ordered a torque wrench and a new gasket, they both arrived during the week and I realised the wrench was WAY too bulky for the small bolts of my clutch case
So I fit the new gasket and used my own judgement to equally tighten the bolts very slowly one at a time in a crosscross pattern to keep it equal, it hasn't seemed to leak anything yet so hopefully it is all good.
Changed the air filter, changed spark plug, tightened the chain (it really is so easy), decided to give the bike a bit of a wash down, cleaned the chain, sprockets & front disk, lubed the chain and pretty much completed my first service so I'm quite chuffed.
Two issues to note;
1) When I started it after the spark plug & air filter change, it was choking a little and it was struggling to respond to the throttle for about 2 seconds on each roll of the handlebar. But this problem hadn't come back after a few times so I stopped worrying about it.
2) sometimes I heard a loud click when I press the rear brake whilst riding, I'm not sure if I have tightened it properly after adjusting the chain. It stops the bike fine, no error there but not sure what the click is but I'm sure on close inspection I will find out ____________________ Yamaha YBR 125 |
| Rogerborg |
 Rogerborg nimbA
 Posted: 11:18 - 14 May 2017 Post subject: |
| onlyJaz wrote: | I realised the wrench was WAY too bulky for the small bolts of my clutch case  |
I don't like them anyway. Too much risk of snappybolt. The last time I used one was on a valve cover and even with everything (including bolts) cleaned up and a fresh gasket, it leaked after using the specified torque.
I'd rather trust my own judgement, or yours for that matter. Good job on getting everything done.
| onlyJaz wrote: | 2) sometimes I heard a loud click when I press the rear brake whilst riding, I'm not sure if I have tightened it properly after adjusting the chain. It stops the bike fine, no error there but not sure what the click is but I'm sure on close inspection I will find out |
When you did the chain, did you:
Slacken then re-tighten the torque arm, circled in red?
Adjust (i.e. slacken) the rear brake adjuster, circled in yellow?
https://i.imgur.com/C0MDKur.png ____________________ Biking is 1/20th as dangerous as horse riding.
| onlyJaz |
| Rogerborg |
 Rogerborg nimbA
 Posted: 13:22 - 14 May 2017 Post subject: |
I back the adjustor right off while I'm moving the axle, then check the brake actuator arm is free to wiggle (drum brake mechanisms to tend to gum up). Then when I've locked the axle off, I do the brake adjuster up until there's just a little bit of slack left in the arm.
Your click, could it be a spring fouling and releasing? ____________________ Biking is 1/20th as dangerous as horse riding.
| craigT19 |
 craigT19 Jolly Green Giant
 Posted: 13:24 - 14 May 2017 Post subject: |
| Nemo |
 Nemo Could Be A Chat Bot
| onlyJaz |
The last post was made 8 years, 333 days ago. Instead of replying here, would creating a new thread be more useful? |
