NO spark gs400
Jay2903
PostPosted: 16:13 - 08 Jun 2017    Post subject: NO spark gs400 Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=320232
Still trying to get this gs400 to spark. I just fitted new brushes to the starter motor, turns over a bit faster now but still no luck.
When i press the starter button theres a brief flash on the spark plug tester but no constant spark.
any ideas why ??
Help greatly appreciated
bypass2
PostPosted: 23:41 - 08 Jun 2017    Post subject: Reply with quote
are all the block connectors and all other connectors tight/secure. earth wire tight /secure. have you looked inside the kill switch see if any broken/damaged wires. try two earth wires one from the battery to the frame. then one from the battery to the engine mount. then try for a spark at the plugs
bikenut
PostPosted: 14:21 - 09 Jun 2017    Post subject: non starter Reply with quote
As a matter of interest, are the lights/horn misbehaving when ign is on and handlebars turned from lock to lock, neutral light flashes ???
Study the correct wiring diagram for ign circuit, so you can determine voltages to and from the "igniter" black box. If you have a manual, read what that says.
Don't know this bike in great detail which may have a battery dependant ign or the non battery dependent cdi type of system.
What was the voltage drop across the battery when cranking with the plugs in?
Post a wiring diagram please.
Perhaps disable ign kill ( system dependant ) and try again.
nuts about bikes
Jay2903
PostPosted: 15:57 - 09 Jun 2017    Post subject: Re: non starter Reply with quote
They always all work fine
Jay2903
PostPosted: 16:01 - 09 Jun 2017    Post subject: Re: non starter Reply with quote
It was around 9v when cranking
Jay2903
PostPosted: 16:06 - 09 Jun 2017    Post subject: Re: non starter Reply with quote
The kill switch has run and off positions. If its in the off position the starter button doesnt do anything so i assumed its working ok.
Jay2903
PostPosted: 16:17 - 09 Jun 2017    Post subject: Re: non starter Reply with quote
The wiring diagram -
https://s61.photobucket.com/user/Jay29031/media/gsx400_zps9n5bbmlw.jpg.html?filters[user]=145531479&filters[recent]=1&sort=1&o=1
my diagram -
https://s61.photobucket.com/user/Jay29031/media/IMG_3027_zpsws7xpbui.jpg.html?o=0
Jay2903
PostPosted: 16:27 - 09 Jun 2017    Post subject: Reply with quote
one thing i found strange is the left ign coil heats up quite warm after about 10 minutes
Jay2903
PostPosted: 12:32 - 12 Jun 2017    Post subject: Reply with quote
Any ideas ???
The last post was made 9 years, 137 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.18 - MySQL Queries: 15 - Page Size: 57.58 Kb
