How can i tell if i am running too much 2t oil?
simon1221
PostPosted: 19:57 - 15 Mar 2005    Post subject: How can i tell if i am running too much 2t oil? Reply with quote
Following on from this thread
Would the source of my problem being that the oil is set too much.
I know that it will kill the plug but any other signs?
Cheers Smile
mchaggis
PostPosted: 20:00 - 15 Mar 2005    Post subject: Reply with quote
The plug will be black and shiney, and there will be tons of smoke, especially at start up.
I must not be a troll...
Mmmm, Guinness
simon1221
PostPosted: 20:04 - 15 Mar 2005    Post subject: Reply with quote
Ahhh, there is loads of smoke at start up, and the plug isshiny. Rolling Eyes
Looks like i may have found the problem, but I have never had to change the settings before, but then again it was flooding the engine and it might cancel it out.
Any effects on engine running?
If i reset the cable so that the adjuster isnt being used (like the throttle cable on the carb), will this be correct? How will i know?
PostPosted: 23:30 - 15 Mar 2005    Post subject: Reply with quote
There should be adjuster marks on the arm of the oil pump that is moved by the cable (you sometimes need to remove a cover to see this). One should line up with a fixed mark at tickover and different one when the throttle is held wide open. They are all slightly different, you should be able to find the specifics for your bike in a manual.
Bomberman
PostPosted: 00:45 - 16 Mar 2005    Post subject: Reply with quote
From my experience with the same bike there will always be loads of smoke at start up. Like enough to turn my 20'x15' garage into a virtual gaschamber.
Funnily enough, my 2t pump was broken when I got the bike. Jammed on full, no matter what the throttle was at. If you need to change the plug every 3 days and it smokes heavily even when hot, then I'd say your pump was jiggered. Or at least set way too high.
Frost
PostPosted: 03:30 - 16 Mar 2005    Post subject: Reply with quote
You can also get a slight drop off in top end power.
Ideally the bike will smoke when cold, but hardly smoke at all when warm.
simon1221
PostPosted: 14:16 - 16 Mar 2005    Post subject: Reply with quote
Ah i might not be able to take the cover off, as i think i will have to take the crankcase cover off first.
The last post was made 21 years, 247 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.09 - MySQL Queries: 13 - Page Size: 52.66 Kb
