Why does this happern!!!!!!!!!!!!!
ApriliaRs125
PostPosted: 02:10 - 19 Mar 2005    Post subject: Why does this happern!!!!!!!!!!!!! Reply with quote
sometime when im out riding i change up gears then i change in to forth and 2 seconds later it sorta jumps out of gear and i have to put it back in , i have a video i uploaded on here and it does it near trhe end of the video
https://www.bikechatforums.com/viewtopic.php?t=44032
*aprilia rs125 2005 UKRS https://www.theukrsclub.com
*peugeot speedfight 100 1999 Aprilia Forum https://www.apriliaforum.com
mr.z
PostPosted: 02:19 - 19 Mar 2005    Post subject: Reply with quote
Has it allways done this? has it got progressively worse?
Its not a good thing, start looking for a new gearbox/engine.. if its allways done it (allthough it shouldn't) and its only a random every so often then try to ignore it...
PostPosted: 02:25 - 19 Mar 2005    Post subject: Reply with quote
Make sure you are taking your foot comletely off the gear lever before trying to change into the next gear. If you are changing gear rapidly and don't allow the lever to return fully to the 'rest' position between times, the next gear may not engage properly.
Frost
PostPosted: 03:05 - 19 Mar 2005    Post subject: Reply with quote
My car does this.
Means its fooked, serious mechanical repair time i'm afraid (probably terminal for my car)
Fire_Eyes
PostPosted: 05:14 - 19 Mar 2005    Post subject: Reply with quote
My bike was having the same problem two weeks ago. After that it started to jump into neutral more often... even while taking a bend which was quite scary. Then it started to leak petrol. Mechanic says the 2nd gear went bad so you might have the same problem.
Kawasaki ZZR 400 | K5 GSX-R 600
natv4
PostPosted: 10:40 - 19 Mar 2005    Post subject: Reply with quote
All this doom and gloom. Just to let you know that it may not be all that bad. My bike has done it since I got it. Usually it seems to be lazy foot syndrome, but it is an awkward gearbox. I have ridden other VFRs and they don't do it as easily.
Anyway, mine is still going after 48K so I wouldn't worry too much. If it gets worse, then get a mechanic, otherwise, practice getting it right. As Stinkwheel said, a positive foot movement helps no end.
Travelling around the world...a bit at a time. Where am I now? / Visit my BLOG
Bike: Blue Honda VFR800fi (*NEW*) Mileage: 22k Countries visited: GB/F/D/CZ/PL/E/I/B/A/HR/H/Rus/E/MA
West Europe...2004, East Europe...2005, Russia/France...2006, Morocco...2007
PostPosted: 12:54 - 19 Mar 2005    Post subject: Reply with quote
DaFrostyOne wrote:
My car does this.
If this was the case, every Jawa, CZ, MZ, Ural and motorcycle of former communist origin, as well as older BMWs are in need of serious mechanical repair from the moment they leave the factory. Laughing
If it were to be a mechanical problem, the most likley culprit would be a bent selector fork, in these days of horizontally split crankcases it should be a piece of piss to replace one. It takes me 4 hours to tear down a Jawa engine to replace a selector fork and the same to put it back together and that is a vertically split motor so the whole bloody lot has to come apart. On a modern bike, you should just need to turn the engine upside down and unbolt the bottom of the gearbox.
Mate of mine didn't even bother taking the engine out of the frame to do the gearbox on his bandit, just turned the whole bike upside down and left it resting on the handlebars like a pushbike Laughing
The Dude
PostPosted: 13:01 - 19 Mar 2005    Post subject: Reply with quote
I know this problem. I have the 2004 RS125 (I think thats what you have to going by your avatar). It only happened to me when i was wearing my racing boots and couldn't feel the gear selector properly or when i just didn't knock it into the next gear properly. I don't think it's a problem with my bike, more a problem with my boots. I went and got a pair of gortex ankle boots from Hein Gericke and they are great for the bike. I have never had the problem when wearing my ankle boots because i can feel what i am doing a lot better.
The last post was made 21 years, 204 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 59.09 Kb
