Paint stripping ABS (I think) sidepanel.
A100man
PostPosted: 13:52 - 22 Aug 2018    Post subject: Paint stripping ABS (I think) sidepanel. Reply with quote
Hi All
As above.. Can I use Nitromors I have equivalent of the old formula that actually works (get it off ebay) ?
Oh yes - bike is 70s GT250
J
Teflon-Mike
tl;dr
PostPosted: 14:53 - 22 Aug 2018    Post subject: Reply with quote
You 'can'... personally I wouldn't.. if you leave the stuff on long enough to get the paint off it usually melts and or distorts the plastic. If you dont leave it on that long.... dont get paint off.
IME old fashioned elbow grease is the best solution, and I tend to use a stanley-knife blade scraper to get most of the paint off, then fine sand-paper to get back to base plastic.
Or just sand to get key surface, dont worry so much about getting back to base plastic; plastic prime... and paint. Plastic prime is a key stage; its sort of like Air-fix model glue, and it etches itself into the plastic, and leaves a sort of tacky surface paint will adhere to.
Riejufixing
PostPosted: 19:29 - 22 Aug 2018    Post subject: Re: Paint stripping ABS (I think) sidepanel. Reply with quote
Hm, interesting.
What's it been painted with, d'you know?
I would be very inclined to see what Notromors does to a piece of scrap ABS before you douse the stuff on.
What are you going to do with the panel? Paint it again? Do you really need to remove all the paint, then?
I see you're in Bedfordshire. N/M/S/E/W?
It is possible that some solvent may remove your paint....
A100man
PostPosted: 20:54 - 22 Aug 2018    Post subject: Reply with quote
Thanks all. Side panels look like they've been painted with red rattle can circa 1984 so I guess it's some kind of cellulose. It's flaking and there appears to be some silver paint underneath. I'll try rubbing down first then maybe a test patch with the nitromors if it proves awkward.
J
PS Bedford town
Riejufixing
PostPosted: 21:19 - 22 Aug 2018    Post subject: Reply with quote
PS Bedford town
Hm, plastic/cellulose... caustic soda (or even oven cleaner, which contains it)? I visit Bedford really rather frequently. I quite like it. It varies from place to place. A while ago I was in the High Street when a load of herberts on ATVs, bikes, etc, were wheelieing down the road. Pity, nothing at hand to launch at them. Seen later, they disappeared along the dual carriageway towards Cambridge.
A100man
PostPosted: 22:44 - 22 Aug 2018    Post subject: Reply with quote
Indeed. I'm hoping one of the irksome toss-pots will end up in the Ouse one day soon.
Riejufixing
PostPosted: 22:47 - 22 Aug 2018    Post subject: Reply with quote
.... one way or another.... Wink
WD Forte
PostPosted: 23:59 - 22 Aug 2018    Post subject: Reply with quote
I'm currently tarting up me old thing and doing the side panels with a detail sander and elbow grease.
It's a bit of a chore so I'm interested to see if anyone has a cunning wheeze to make stripping them easier.
I've counted about 10 paint layers so far, 6 of em mine Laughing
bikers smell of wee
MCN
PostPosted: 02:53 - 23 Aug 2018    Post subject: Reply with quote
Buy a wee sander out of B&Queue.
Chemicals that will strip paint probably wont be good for the Praastick underneath.
mudcow007
PostPosted: 10:34 - 23 Aug 2018    Post subject: Reply with quote
i used acetone on my CG side panals, which worked marvellously up until the point the plastic started to disolve
clean the paint/ shite away though
Teflon-Mike
tl;dr
PostPosted: 11:34 - 23 Aug 2018    Post subject: Reply with quote
I 'lost' the side-panel off the Seven-Fifty for a couple of months; hunted every where for it.... eventually found it in the shed... it was furry... WTF?!
Eventually Snowie made admission; a bit like the gouge mark she had left accross the petrol tank, actually, but, possibly in the same incident, she'd knocked the side panel on the floor... and chased it around the patio...
I have to have a LITTLE sympathy here.... she has T-Rex arms and big boobs... she does have trouble reaching around them... so kept kicking the side-panel along the patio trying to pick it up...... realized it was a 'bit scratched' and I would notice, as its black paint over white plastic.... so she had an Oy-De-Ugh... she decided to repaint it... which was all reasonable, until she got out the Nitromors to strip it first......
I'm not sure whether it went furry because of the nitromors, or her attempts to wipe the nitromors off.... but it didn't do it much good either way!
So she hid it in the shed and hoped I wouldn't notice!
Took a week of effin scraping to get the fur off that dang thing!
MCN
PostPosted: 17:08 - 23 Aug 2018    Post subject: Reply with quote
Teflon-Mike wrote:
I have to have a LITTLE sympathy here.... she has big boobs... she does have trouble reaching around them...
/\ Pictures or it never happened.
Riejufixing
PostPosted: 17:30 - 23 Aug 2018    Post subject: Reply with quote
Smile I used thinners to clean an Xpelair fan housing. Worked really well, including removing a tiny fraction of the plastic. It burnished up a treat, like french polishing something.
Teflon-Mike
tl;dr
PostPosted: 23:03 - 23 Aug 2018    Post subject: Reply with quote
See Pup-Post:-https://i1177.photobucket.com/albums/x349/snowtigeress/Strip%20Down/imag0685.jpg
Eeek!
Forum-Alert wrote:
The last post was made 8 years, 74 days ago.
Bleedin'Eck! That means she's been about longer than I was married!
stirlinggaz
PostPosted: 04:58 - 24 Aug 2018    Post subject: Re: Paint stripping ABS (I think) sidepanel. Reply with quote
hi,
im looking for a decent paint stripper type stuff (but not for use on abs or any type of plastic) & always used to use nitromors until it went sh*te.
link to said alternative or brand name?
is it really any good?
cheers,
GAZ
Riejufixing
PostPosted: 09:58 - 24 Aug 2018    Post subject: Re: Paint stripping ABS (I think) sidepanel. Reply with quote
stirlinggaz wrote:
looking for a decent paint stripper type stuff ... link to said alternative or brand name?
https://bit.ly/2w9p9PE but you will have to sign a declaration on "company-headed paper".... I have not done this.
What are you stripping?
A100man
PostPosted: 11:43 - 28 Aug 2018    Post subject: Re: Paint stripping ABS (I think) sidepanel. Reply with quote
stirlinggaz wrote:
hi,
cheers,
GAZ
Lots of options on ebay - I think as long as it says 'for commercial use only' its the good stuff and works just like 'old nitromors'.
https://www.ebay.co.uk/itm/Paint-stripper-Heavy-Duty-Industrial-Strength-5-Litre-Free-Gloves
ZRX61
Victor Meldrew
PostPosted: 21:02 - 28 Aug 2018    Post subject: Reply with quote
Old rattlecan paint will just wipe off with a rag & some lacquer thinner.
They're not one night stands, they're auditions.
The last post was made 8 years, 50 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 105.42 Kb
