Sealing exhaust collector box to downpipes
Nipedley
PostPosted: 15:43 - 25 Aug 2018    Post subject: Sealing exhaust collector box to downpipes Reply with quote
Hi guys
Trying to fit a new collector box on my 1989 VFR750 (RC24). Previously it had the Motad 2 into 1 silencer fitted straight onto the downpipes
I've bought from david silver spares the gaskets they carry for that part number which is a repro item I believe. They're the graphite kind. Problem is, the collector box won't fit with the gaskets on - they just get torn up. I tried gasket on the pipe then fitting the box, and gasket in the box to fit on the pipe and both ways they get shredded. I've gone through 4 of them now (2 sets) and can't get it fitted on
Is there anything else I can use to seal these up, or some kind of trick to it ?
Many thanks Thumbs Up
CBR600 (1988) | GS500 (1989)
Nobby the Bastard
Harley Gaydar
PostPosted: 15:58 - 25 Aug 2018    Post subject: Re: Sealing exhaust collector box to downpipes Reply with quote
Silicon Sealant.
Triumph Sprint ST 1050
ThatDippyTwat
PostPosted: 16:30 - 25 Aug 2018    Post subject: Re: Sealing exhaust collector box to downpipes Reply with quote
Nobby the Bastard wrote:
Silicon Sealant.
Copper silicone sealant. Loctite 5990. Used without issues on an almost identical bike.
Islander
PostPosted: 16:46 - 25 Aug 2018    Post subject: Reply with quote
The cheap ordinary stuff does the job Thumbs Up
ThatDippyTwat
PostPosted: 17:57 - 25 Aug 2018    Post subject: Reply with quote
I had issues with it smoking up - However, that was nearer the cylinder head where it's a lot hotter.
RhynoCZ
PostPosted: 18:12 - 25 Aug 2018    Post subject: Reply with quote
Go to your local auto parts shop and buy proper exhaust sealant, they sell it even in small tubes and it costs next to nothing. I 100% guarantee it will work and the exhaust won't leak, ever.
Or just waste your time and money experimenting with silicone.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:19 - 25 Aug 2018    Post subject: Reply with quote
Except the last exhaust I fitted specified silicon sealant between the downpipes and the end can...
RhynoCZ
PostPosted: 18:30 - 25 Aug 2018    Post subject: Reply with quote
I use this with great success. I wouldn't use it between the head and headers though, there should not be any sealants.
https://www.partslist.cz/assets/images/products/tecdoc/full/041/637090.JPG
ThatDippyTwat
PostPosted: 18:36 - 25 Aug 2018    Post subject: Reply with quote
It's Gungum. It cracks and falls out, it's not waterproof.
RhynoCZ
PostPosted: 18:56 - 25 Aug 2018    Post subject: Reply with quote
Well, I don't know about that. Thinking
EDIT: Thinking of it, I used it on the MZ several years ago and the exhaust still doesn't leak. I also used it on several cars and those are driven in rain and salt as well and are alright. I smear it on the mating surfaces and put the exhaust together and I'm done with it.
EDIT: That however might be confusing to some.
Islander
PostPosted: 18:59 - 25 Aug 2018    Post subject: Reply with quote
Not a huge waste of time or money - it just works. Razz
Suntan Sid
PostPosted: 20:32 - 25 Aug 2018    Post subject: Reply with quote
Regarding common or garden silicone sealant, it works very well.
I used it to seal the joints on my DRZ400, it worked fine, especially when you consider how hot the down pipe gets on that bike!
WD Forte
PostPosted: 20:49 - 25 Aug 2018    Post subject: Reply with quote
I'll use silicon over gum gun anyday
Gun gum's ok for wood burning stoves Laughing
If you have to apply it thickly and want it to set fast thoughout
not just have a skin develop with snot beneath,
mix in some cornflour and trowel it in.
S'wat I do when making boots & grommets
bikers smell of wee
The last post was made 8 years, 35 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.35 - MySQL Queries: 13 - Page Size: 79.06 Kb
