| CG125ES-7 Nut Buster |
 CG125ES-7 Nut Buster L Plate Warrior
 Posted: 03:29 - 12 Jun 2019 Post subject: Honda CG125 ES-7 2008 UK Clutch Questions (JC30 Engine) |
Hi All,
I have bought EBC Heavy Duty friction plates, new cable to eliminate my clutch starting to slip. 11,000 miles and first change i believe. The clutch engages when the pull lever is pushed forward so probably just the 10 year old cable.
Are EBC HD clutch springs worth it or just a pain in the hand/wrist?
Do these require special tools for the oil spinner removal and clutch plates?
Every time I start a project I get caught out needing something.
Thanks for any links.  ____________________ CG125ES-7 With memories of my BSA Bantams 125, 150 and 175. Honda PC50. Honda MT50. Honda CD175. Yamaha FS1E. Yamaha RD250. Yamaha XT550. Yamaha Super Tenere 750. |
| Robby |
 Robby Dirty Old Man
| kgm |
 kgm World Chat Champion
| Teflon-Mike |
 Teflon-Mike tl;dr
| BusterGonads |
 BusterGonads Trackday Trickster
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 01:24 - 09 Aug 2019 Post subject: |
Buster: -The average M/C these days only covers around 3ooo miles a year. 110000 miles then is most likely round the clock 99,000 miles, Plus 11,000.... and the equivilent of 36 yeaars average miles or perhaps five to seven total life-miles for any motorcycle...
He says the thing is a 2008 model.... so at least ten plus years old.. has it been clocked in that time? Not impossible, these things can rack up car type annual miles in commuter service, but ho-hum. Its no spring chicken, and Learner/Commuters rarely have the most contientiouse no expense spared owners looking after them! Would only take a couple of oil changes IF its owner was even THAT contientiouse, stucking in copper or molybdnum addadive or cheap supermarket, addadive containing car oil, to lube syncro-cones in car/type gear-box, to eff up good clutch plates;
whilst learner clutch use can be horenouse...
One comes past my house regularly and I wanmt to go out with a base-ball bat and teach them how to use a clutch properly! Four gear changes in 200 yards in a 20 zone!! and banged twixt each, never letting the clutch out fully, its slipping the whole way up the road FFS! Theres another, probably CG copy that will need new clutch plates earlier on!
Vis the rest; replacing the plates and springs is not a bad bit of preventative maintenence. Meanwhile a new cable, at aprox £10-15 is cheap enough to just do and be done with rather then faff around trying to work oil down the whole length and stay there..... itrs probably cheaper then a cable luber amd a can of swuirty oil to try and recover the old one with stretched strands and loose nipples.... ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| BusterGonads |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 10:10 - 11 Aug 2019 Post subject: |
| BusterGonads wrote: | I'd like to see the round the clock cg125, by the way |
Triggers broom-bikes..... the clock doesn't have to have been around the clock with the same enginem does it?
| BusterGonads wrote: | I did meet a guy on Facebook who said he had been commuting on a couple of these bikes since they came out |
CG was launched to market in 1977....
| BusterGonads wrote: | Its true that a lot of CGs are hammered by youngsters who dont' even think of maintaining them, |
Well, I may still be a youngster from your lofty view-point.. b-u-t.... I dont think that age has a lot to do with it.... the curse of the See-Gee, is the ide that 'low maintenence' means 'NO maintenence', and there's as mamy more mature and aught know better, owners as guilty of that as there are teen-agers! If anything, teen-agers nieve enthusiasm and 'fiddle-fingers' is likely to see them treat the thing more like a lego set and get the spenners out more often than an older owner more want to treat it like a washing machine and not do a thing but ride it till it starts making funny noises or conks out, when they call a washing machine repair man....
| BusterGonads wrote: | My money is on a grotty cable. The clue is that he says the clutch engages when he pushes the lever forward. |
You may be right.... but I still say that a new cable is a more sure fix than trying to recover a chitty old cable with stretched strands and loose nipples and eons of goop down the sleeve.... and in for a penny in for a quid, mnew plates are not a bad bit of precautionary, and pulling the primary cover, is nowt else, at least demands a proper oil change! Its worth the doing for the cost/effort/time, its not an inordinately difficult, expensive of time consuming job.
| BusterGonads wrote: | By the way - a question for you:
I just got a low mileage cb250 nighthawk - 12000 miles. Am I right in thinking these have an oil screen inboard of the oil pump? Do I need to crack open the case and clean that at 12000 miles. The engine is a peach. Very smooth and quiet, so I don't want it knackered by oil starvation. |
I'd clocked that acquesition.... I think you likely paid rather over the odds for it... but still....
YES, its a Benly.. should have been badged as such, especially having single carb not twins like other See-Bee, badged offerings from Sochiro....
HOW2: change Oil & CLean strainer (Small Honda's +)
https://i178.photobucket.com/albums/w269/teflons-torque/Little%20Dreams/LD07%20Eng%20Build/100_0476.jpg
I'd do a thorough flush with derv/parafin, and a squib of fairy liquid in the old before dumping it, and on an older lkow miles long laid up example I would be as worried about firred rings in the piston/bore as excessive wear, and rejuvenation failure as soon as more usual miles put on the dang thing...... Prerrt sure Chinky barel kits are available for the 53/53 big-bore enleys, and I think that there's even a 300cc kit around for the quads, that would drop on nicely, though probably not liberate any more than its meager barely learner legal 19bhp...... may be worth lining one up for future winter project? ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| BusterGonads |
The last post was made 7 years, 79 days ago. Instead of replying here, would creating a new thread be more useful? |
