| Oil level above the max notch |
| Leave it as is |
50% |
[ 9 ] |
| Suck the excess out |
11% |
[ 2 ] |
| It's gonna explode any minute now |
16% |
[ 3 ] |
| I love polls and clicking stuff online |
22% |
[ 4 ] |
| Total Votes : 18 |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 23:14 - 26 Oct 2019 Post subject: |
For christ sake don't lean the bike round any corners or it'll go up to 2mm. ____________________ a.k.a 'Geri'
| RhynoCZ |
 Posted: 23:17 - 26 Oct 2019 Post subject: |
Off to the garage...
https://media1.giphy.com/media/11NybLJG6LsHx6/source.gif ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| jaffa90 |
 jaffa90 World Chat Champion
 Posted: 01:20 - 27 Oct 2019 Post subject: |
You have a major problem, don`t get married and have kids.  |
| ThatDippyTwat |
 Posted: 06:33 - 27 Oct 2019 Post subject: |
While overfilling can cause issues, that's not a problematic level, that's well within margins of error. Silicone tubing dunked in to the filler hole, a finger over then end, remove tubing into receptacle, remove finger, repeat, works well, if slowly, and avoids dumping the lot out. I used 6mm aquarium airline, as that's what I had kicking about. Adding a blunt/mixing syringe to that would greatly speed up the process.
For instance, a YBR125 does not like being overfilled. Changed oil out after buying it and instead of ~1L, it was almost 2. All gearbox clunkiness (other than being a YBR) went away with that. Once I overfilled it by about 100ml, and the clunkiness partially came back. ____________________ '98 VFR800 (touring) - '12 VFR800 Crosrunner (Commuting) - '01 KDX220 (Big Green Antisocial Machine) |
| doggone |
 doggone World Chat Champion
| RhynoCZ |
 Posted: 10:15 - 27 Oct 2019 Post subject: |
I only ask as now I can hear sort of a hissing sound from the left hand side part of the engine when under load.
I'm not sure if the sound was there before though and there's no hiss when in neutral. Could be the gearbox, but could as well be nothing. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| TbirdX |
 TbirdX Crazy Courier
| RhynoCZ |
| Polarbear |
 Polarbear Super Spammer
 Posted: 13:49 - 27 Oct 2019 Post subject: |
Useless nuggets of information....
No 1. - BMC B series diesel engines must not be filled above the max line as they have a tendency to blow the crank shaft oil seal if overfilled.
No 2. - BMC B series diesel engines were supplied with dipsticks with no marks on because when used in marine and industrial applications the engines might be mounted on the slant. You were meant to pop mark the dipstick with a centre punch to allow for your mounting arrangement. Work that one out!
HTH  ____________________ Triumph Trophy Launch Edition |
The last post was made 6 years, 255 days ago. Instead of replying here, would creating a new thread be more useful? |
