125 pit bike clutch help
Siclic
PostPosted: 03:17 - 20 Dec 2019    Post subject: 125 pit bike clutch help Reply with quote
Hi I’m new to bikes, I’m fixing my brothers moto vert 125 pit bike and the clutch won’t engage, so I’ve pulled the case off n it’s a clutch system I’ve never seen before. I will post some pics, any info would be much appreciated...so I’ve tried to attach a pic but it won’t let me, I’ll figure out what to do shortly
Ml
Easy-X
PostPosted: 13:58 - 20 Dec 2019    Post subject: Reply with quote
The forum attachment system ain't the easiest Smile I suggest you upload it to one of the many photo sites and post a link.
Riejufixing
PostPosted: 14:19 - 20 Dec 2019    Post subject: Re: 125 pit bike clutch help Reply with quote
Siclic
PostPosted: 06:26 - 21 Dec 2019    Post subject: Pic Reply with quote
Hopefully these pics help
Ml
Easy-X
PostPosted: 12:15 - 21 Dec 2019    Post subject: Reply with quote
Hey, you're right... I haven't seen one like that either Smile
Hopefully one of the esteemed forum members knows something...
Siclic
PostPosted: 00:39 - 22 Dec 2019    Post subject: Reply with quote
Yea it’s weird aye
Ml
Riejufixing
PostPosted: 01:12 - 22 Dec 2019    Post subject: Reply with quote
Of any interest?
https://www.youtube.com/watch?v=qlGE9eFMVT0
It actually looks like a fairly conventional clutch under that disguise... I'd guess you have an issue in the actuating mechanism. Clearance mechanism/cable??
PostPosted: 01:16 - 22 Dec 2019    Post subject: Reply with quote
Never seen one like that either. It looks backwards compared to a conventional clutch setup. I'm struggling to get my head around it
Is it a dry clutch? (was it sitting in oil?)
From the positioning of the springs, it looks like the moving pressure plate is at the back pulling the stack towards the outside of the cage (nearest the camera)? Hence the gap at the back of the clutch cage. So the fixed pressure plate (which would normally form the back of the clutch basket) is actually the shinmy disc neasrest the camera. Presumably done because they had no room to manouver around that flywheel
What goes up the middle of that ball bearing? There must be a pretty wide shaft sticking out of the inside of the side cover which I guess must go through the bearing to push on the pressure plate and release the stack? Or mayber it pulls from the other side.
Which side does the clutch cable go to?
Pic of inside of cover please.
PostPosted: 01:29 - 22 Dec 2019    Post subject: Reply with quote
Riejufixing wrote:
Of any interest?
Ahh. Never mind. I was nearly right. They are using a ball bearing where there really ought to be a thrust bearing. That's what was confusing me.
Anyway. You say the clutch won't engage? So you're not getting any drive? It's like the clutch is pulled in all the time?
Try putting it in gear now and turning the rear wheel, see if it turns the engine (may be worth pulling the plug lead off in case it starts... don't ask!). If it does, your actuator mechanism (inside the cover) is too tight for some reason. If it doesn't, you have a more fundamental problem like the centre nut having come off or similar.
EDIT: Just a quick sanity check. Is the final drive chain still on the bike and running on both sprockets and is the front sprocket attached to the shaft? (Again, don't ask!)
Riejufixing
PostPosted: 01:42 - 22 Dec 2019    Post subject: Reply with quote
Might be one o' they there wold "deep groove" bearings. Dunno. The OP could post the lettering, if visible.
PostPosted: 03:22 - 22 Dec 2019    Post subject: Reply with quote
It won't really matter, it's a huge meaty bearing for what it's doing. The axial load will be well within tolerance even for a standard double caged ball race. It just seems inelegant.
Siclic
PostPosted: 08:35 - 22 Dec 2019    Post subject: Reply with quote
Riejufixing wrote:
Of any interest?
So when I pull the clutch,nothing no engage..normally there’s a pushrod in the center of the clutch n when clutch lever is pulled it pushes the push rod n disengages the clutch plates I believe. Well on mine the pushrod comes out of the casing and pushes what ?. Haha. Hope I explained myself mate.its doing my head in. I’ll have to post a pic of the casings internal
Ml
Siclic
PostPosted: 08:41 - 22 Dec 2019    Post subject: Reply with quote
Yes there was oil in about 500 ml..I’ll send a pic of the cover inside..what your saying makes sense mate, it’s like it’s backwards. And yes the push rod in the cover is very wide probably the size of an Australian 10 cent or American quarter just for reference
Ml
Siclic
PostPosted: 08:56 - 22 Dec 2019    Post subject: Internal cover Reply with quote
So this is a pic off the net, but it’s exactly the same as mine
Ml
Siclic
PostPosted: 09:08 - 22 Dec 2019    Post subject: Reply with quote
So I just found out that disc looking thing in front of the clutch is called an oil flicker or spitter n has nothing to do with the clutch dynamics Neutral
Ml
Riejufixing
PostPosted: 10:07 - 22 Dec 2019    Post subject: Reply with quote
The bloke on that sleep-inducing video called it the "oil slinger" Smile . It seems to double as a centrifugal filter. The actuator in the casing pushes on the inner of the bearing mounted in the square transfer plate.
Riejufixing
PostPosted: 10:33 - 22 Dec 2019    Post subject: Reply with quote
It's a single-row bearing. Deep groove bearings are designed to accommodate radial loads and axial loads in both directions, so I wouldn't say it's "inelegant".
Siclic
PostPosted: 12:55 - 22 Dec 2019    Post subject: Reply with quote
Has anyone looked at the pics on my last post, I really need to know how that clutch system works, cmon world chat champions..haha Very Happy Cheers
Ml
PostPosted: 19:23 - 22 Dec 2019    Post subject: Reply with quote
That pad inside the cover pushes directly on the inner race of the ball bearing to disengage the clutch. it all looks in good-order from the pictures.
Siclic
PostPosted: 20:14 - 22 Dec 2019    Post subject: Reply with quote
I have done that previously, the back tyre just skids like it’s locked up
Ml
Siclic
PostPosted: 20:17 - 22 Dec 2019    Post subject: Reply with quote
So the inner bearing, I’ve tried to push with my finger n nothing it’s solid, it doesn’t release the plates
Ml
Riejufixing
PostPosted: 22:15 - 22 Dec 2019    Post subject: Reply with quote
You'll need more than your finger.
No, not THAT!
Have you had this to bits before?
If you have not had it to bits before, did it work before you took it to bits?
If you watch the chap's video you can see how it works when he takes the thing apart. If that's no good, have it apart yourself and then you will know. I usally like taking things to bits to see how they work. I can't see how anyone can drive, for instance, without knowing how an ordinary clutch works. Still, they do. My old driving instructor said a car clutch was like two dinner plates pressed together. I looked at him, amazed. Anyway. That's rather beside the point. Sorry.
PostPosted: 00:48 - 23 Dec 2019    Post subject: Reply with quote
Well. If you had normal pressure on the clutch lever (it isn't just pulling back with little or no resistance), the pressure plate is being pushed back against the springs like it's supposed to be.
That leaves two main options (although something physically broken inside the clutch is also possible):
1) The clutch plates are stuck together.
2) The clutch hub is notched so the plain plates can't move along it.
I doubt the second case is true because I can't see any notching on the basket and that usually goes first.
Couple of ways of freeing off stuck plates. One is to hold the brakes on, give it some revs and change into first. Rinse and repeat until it does it without stalling but beware of the risk of wheelying away.
Another is to prop the rear wheel securely off the ground, change into first but keep the clutch pulled in. Once the rear wheel is spinning reasonably quickly, put the back brake on. Rinse and repeat until it no longer stalls. Again, risk of wheelying across the yard if it's not securely on the stand
However, you've already got it partially stripped so if it were me, I'd go ahead and take the spinner off, remove those 4 bolts and take the plates out, wipe them and put them back in again one at a time. While you're in there you can check for notches and make sure the centre nut is still on tight. If something's broken in there, it should be obvious.
WD Forte
PostPosted: 03:31 - 23 Dec 2019    Post subject: Reply with quote
I see you now know that big wheel is actually the oil slinger and nowt to do with the clutch
that clutch works just like the one in my old CX
and probably many other bikes too
Activated by the lever and cable, the plunger pushes in on the bearing inner race and so takes tension off the springs which allows the clutch plates to slip.
One issue I have experienced myself and seen on similar bikes
is if/when the nut below that thrust bearing works loose, it can
unscrew, rise up the thread and stop the bearing being pushed in
The clutch lever feels rock hard if it happens when you're riding and desperately trying to use the gears
to help your shite brakes slow the bike down as you approach say a roundabout at high speed.
(Rumours I shat myself and screamed like a girl are just that,Rumours.
Nobody saw me do it you can't prove nuthin ok?)
You'll have to remove the 4 bolts and thrust plate to see if the nuts come loose and tighten it up again.
You may also need castellated socket as well, I do on mine.
NB i agree you'd expect to see a kosher thrust bearing used
here, but that common radial type is usually quite reliable
bikers smell of wee
Siclic
PostPosted: 14:08 - 23 Dec 2019    Post subject: Reply with quote
What’s a castellated socket?
Ml
The last post was made 6 years, 296 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 134.24 Kb
