| Siclic |
 Siclic Derestricted Danger
| Easy-X |
 Easy-X Super Spammer
 Posted: 13:58 - 20 Dec 2019 Post subject: |
The forum attachment system ain't the easiest I suggest you upload it to one of the many photo sites and post a link. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Riejufixing |
 Riejufixing World Chat Champion
| Siclic |
| Easy-X |
 Posted: 12:15 - 21 Dec 2019 Post subject: |
Hey, you're right... I haven't seen one like that either
Hopefully one of the esteemed forum members knows something... ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Siclic |
| Riejufixing |
 Posted: 01:12 - 22 Dec 2019 Post subject: |
Of any interest?
https://www.youtube.com/watch?v=qlGE9eFMVT0
It actually looks like a fairly conventional clutch under that disguise... I'd guess you have an issue in the actuating mechanism. Clearance mechanism/cable??
| stinkwheel |
 Posted: 01:16 - 22 Dec 2019 Post subject: |
Never seen one like that either. It looks backwards compared to a conventional clutch setup. I'm struggling to get my head around it
Is it a dry clutch? (was it sitting in oil?)
From the positioning of the springs, it looks like the moving pressure plate is at the back pulling the stack towards the outside of the cage (nearest the camera)? Hence the gap at the back of the clutch cage. So the fixed pressure plate (which would normally form the back of the clutch basket) is actually the shinmy disc neasrest the camera. Presumably done because they had no room to manouver around that flywheel
What goes up the middle of that ball bearing? There must be a pretty wide shaft sticking out of the inside of the side cover which I guess must go through the bearing to push on the pressure plate and release the stack? Or mayber it pulls from the other side.
Which side does the clutch cable go to?
Pic of inside of cover please. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| stinkwheel |
| Riejufixing |
| stinkwheel |
| Siclic |
| Siclic |
| Siclic |
| Siclic |
 Posted: 09:08 - 22 Dec 2019 Post subject: |
So I just found out that disc looking thing in front of the clutch is called an oil flicker or spitter n has nothing to do with the clutch dynamics  ____________________ Ml |
| Riejufixing |
| Riejufixing |
| Siclic |
 Posted: 12:55 - 22 Dec 2019 Post subject: |
Has anyone looked at the pics on my last post, I really need to know how that clutch system works, cmon world chat champions..haha Cheers ____________________ Ml |
| stinkwheel |
| Siclic |
| Siclic |
| Riejufixing |
| stinkwheel |
 Posted: 00:48 - 23 Dec 2019 Post subject: |
Well. If you had normal pressure on the clutch lever (it isn't just pulling back with little or no resistance), the pressure plate is being pushed back against the springs like it's supposed to be.
That leaves two main options (although something physically broken inside the clutch is also possible):
1) The clutch plates are stuck together.
2) The clutch hub is notched so the plain plates can't move along it.
I doubt the second case is true because I can't see any notching on the basket and that usually goes first.
Couple of ways of freeing off stuck plates. One is to hold the brakes on, give it some revs and change into first. Rinse and repeat until it does it without stalling but beware of the risk of wheelying away.
Another is to prop the rear wheel securely off the ground, change into first but keep the clutch pulled in. Once the rear wheel is spinning reasonably quickly, put the back brake on. Rinse and repeat until it no longer stalls. Again, risk of wheelying across the yard if it's not securely on the stand
However, you've already got it partially stripped so if it were me, I'd go ahead and take the spinner off, remove those 4 bolts and take the plates out, wipe them and put them back in again one at a time. While you're in there you can check for notches and make sure the centre nut is still on tight. If something's broken in there, it should be obvious. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| WD Forte |
 WD Forte World Chat Champion
| Siclic |
The last post was made 6 years, 297 days ago. Instead of replying here, would creating a new thread be more useful? |
