Aftermarket bolts
B0ndy
PostPosted: 14:44 - 26 Dec 2019    Post subject: Aftermarket bolts Reply with quote
My 929s fork pinch bolts are looking worse for wear and quite heavily corroded, thinking about replacing them and see Pro bolt want £20 for four stainless bolts.
£20 for four bolts seems a bit excessive so looked on fleabay and noticed a company selling four stainless steel bolts for the 929 comes in at £5.50.
The grade of stainless used is a little different to Pro bolt in that their (probolt) bolts are more resistant to corrosion but other than that very similar properties.
Probably over thinking this but would buying the £5 set be a dumb idea? Don't want to put myself or anyone's safety in danger for the sake of £15 ...
CBF 125 -> CB400SF -> GSX600F -> ZX6R (G1) -> GSXR1000 K4 -> ZX6R (B1H Stunt bike) -> VFR800 -> R1 5PW -> Sprint 1050 -> Fireblade 929 -> ZX10R C2H -> GSXR1000 K3
Sister Sledge
PostPosted: 15:22 - 26 Dec 2019    Post subject: Reply with quote
Could take a look here if you know the specs?
https://www.accu.co.uk/en/
CCM 404 DS
JackButler
PostPosted: 16:42 - 26 Dec 2019    Post subject: Reply with quote
I buy a lot of fasteners & I'm VERY careful who I buy from.
If you want cheap then these folk on eBay sell reasonable quality :
https://www.ebaystores.co.uk/Bolt-Base
As you suspect, not all fasteners are created equally & it's not just down to what from or how they made.
I clean my guns with the tears of the snivelling, left wing scum.
Teflon-Mike
tl;dr
PostPosted: 18:04 - 26 Dec 2019    Post subject: Reply with quote
How much are OE bolts from Honda?
And why stainless? Stainless is brittle, and usulally harder than high-speed tool steel.. ie normal drill bits that blunty rather than cut it; hence where you have a steel bolt in an aluminium hole.. like an engine casing, or a fork yoke... if you come to have to get bolt out by brute.. its a royal PITA, and oft makes more hasle than it would ever save.. all for the sake of a little coppa-slip and some solvol...
Mild bolts work... add coppa-slip or loctite as needed, vasaline or grease and occasional preventative maintenence and job-jobbed....
I would use mild-steel bolts and compare price with OE.
ThatDippyTwat
PostPosted: 18:57 - 26 Dec 2019    Post subject: Reply with quote
Speedy Fasteners. https://www.speedyfasteners.com/default.asp
They also have an ebay shop. Got my entire fairing kit of stainless Dzus 1/4 turn fasteners and clips on there for the Viffer at a decent price.
redeem ouzzer
PostPosted: 22:28 - 26 Dec 2019    Post subject: Reply with quote
Also remember stainless is heavier than OEM.
Be a REAL MAN!
stevo as b4
PostPosted: 23:03 - 26 Dec 2019    Post subject: Reply with quote
This +1!
Ive replaced alot of fasteners on my KMX with generic stainless steel just to get rid of some of the furred up OEM plated stuff. But it's a fair bit heavier than OEM bits.
I think that all the pro bolt engine bolts might help even things out though, as they are beautifully light and parred down to the minimum weight possible.
stevo as b4
This +1!
PostPosted: 13:04 - 27 Dec 2019    Post subject: Reply with quote
Should probably have a grade 8,8 mild steel bolt in that application. If you want them shiny, get bright zinc plated ones (bzp) . Be about £1.99 delivered off eBay.
Vracktal
PostPosted: 21:14 - 27 Dec 2019    Post subject: Reply with quote
Any time a bolt feels funny winding it out I swap it out for titanium unless it's something where tension is specifically important like fork legs or wheel bolts, then I go for stainless from a local machine shop.
2007 BMW R1200R: On road
2009 BMW G650X Challenge: On road
1975 Norton Commando 850: Off road, awaiting recommissioning
PostPosted: 00:19 - 30 Dec 2019    Post subject: Reply with quote
You know steel bolts are, generally speaking, stronger than both titanium and stainless?
I always use steel unless it's something non-load bearing or had an exotic fastener material in there in the first place.
Steel is stronger, cheaper and more durable.
Stainless looks cleaner.
Titanium is lighter.
The last post was made 6 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.05 - MySQL Queries: 13 - Page Size: 70.19 Kb
