| B0ndy |
 B0ndy Spanner Monkey
| Sister Sledge |
 Posted: 15:22 - 26 Dec 2019 Post subject: |
Could take a look here if you know the specs?
https://www.accu.co.uk/en/ ____________________ CCM 404 DS |
| JackButler |
 JackButler Traffic Copper
 Posted: 16:42 - 26 Dec 2019 Post subject: |
I buy a lot of fasteners & I'm VERY careful who I buy from.
If you want cheap then these folk on eBay sell reasonable quality :
https://www.ebaystores.co.uk/Bolt-Base
As you suspect, not all fasteners are created equally & it's not just down to what from or how they made. ____________________ I clean my guns with the tears of the snivelling, left wing scum. |
| Teflon-Mike |
 Posted: 18:04 - 26 Dec 2019 Post subject: |
How much are OE bolts from Honda?
And why stainless? Stainless is brittle, and usulally harder than high-speed tool steel.. ie normal drill bits that blunty rather than cut it; hence where you have a steel bolt in an aluminium hole.. like an engine casing, or a fork yoke... if you come to have to get bolt out by brute.. its a royal PITA, and oft makes more hasle than it would ever save.. all for the sake of a little coppa-slip and some solvol...
Mild bolts work... add coppa-slip or loctite as needed, vasaline or grease and occasional preventative maintenence and job-jobbed....
I would use mild-steel bolts and compare price with OE. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| ThatDippyTwat |
 Posted: 18:57 - 26 Dec 2019 Post subject: |
Speedy Fasteners. https://www.speedyfasteners.com/default.asp
They also have an ebay shop. Got my entire fairing kit of stainless Dzus 1/4 turn fasteners and clips on there for the Viffer at a decent price. ____________________ '98 VFR800 (touring) - '12 VFR800 Crosrunner (Commuting) - '01 KDX220 (Big Green Antisocial Machine) |
| redeem ouzzer |
| stevo as b4 |
| stevo as b4 |
 Posted: 13:04 - 27 Dec 2019 Post subject: |
Should probably have a grade 8,8 mild steel bolt in that application. If you want them shiny, get bright zinc plated ones (bzp) . Be about £1.99 delivered off eBay. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Vracktal |
 Vracktal World Chat Champion
 Posted: 00:19 - 30 Dec 2019 Post subject: |
You know steel bolts are, generally speaking, stronger than both titanium and stainless?
I always use steel unless it's something non-load bearing or had an exotic fastener material in there in the first place.
Steel is stronger, cheaper and more durable.
Stainless looks cleaner.
Titanium is lighter. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 6 years, 298 days ago. Instead of replying here, would creating a new thread be more useful? |
