| sapstar |
 sapstar Nova Slayer
 Posted: 22:13 - 29 Feb 2020 Post subject: Problem installing engine bars on ER-6N |
I bought Renntec engine bars for my 2015 Kawasaki ER-6N and installed them today
The bars came with all nuts and bolts necessary, except for the right side, behind the fairing, just in front of the engine. The instructions suggest I need to use the existing bolts which were taken out. In my case the existing bolts continuously spin and I can't tighten them. These are 2 M8x60 bolts. See picture below from installation instructions.
https://i.ibb.co/hFLzyXr/20200229-210652.jpg
Can someone please let me know what kind of bolts I need to buy to replace these? I checked in ebay and see a number of different types of bolts and unable to decide which ones are right.
Eventhough the bolts are spinning when I tighten them, the fitting seems to be sturdy and there is no movement. Is the bike drivable in this condition?
Also anyone know if the nuts behind these bolts are removable? If so I would like to replace them too.
Found these on ebay.
https://www.ebay.co.uk/itm/233275990803
https://www.ebay.co.uk/itm/362217874580
https://www.ebay.co.uk/itm/362293650219
https://www.ebay.co.uk/itm/372090349564 ____________________ First/Current Bike - Kawasaki ER-6N |
| Nobby the Bastard |
 Posted: 22:51 - 29 Feb 2020 Post subject: Re: Problem installing engine bars on ER-6N |
| sapstar wrote: | I bought Renntec engine bars for my 2015 Kawasaki ER-6N and installed them today
https://www.ebay.co.uk/itm/372090349564 |
The problem isnt the bolts are wrong, it's the fact you haven't realised that the holes aren't aligned. ____________________ trevor saxe-coburg-gotha:"Remember this simple rule - scooters are for men who like to feel the breeze on their huge, flapping cunt lips."
Triumph Sprint ST 1050 |
| sapstar |
 sapstar Nova Slayer
| NJD |
 NJD World Chat Champion
 Posted: 01:25 - 01 Mar 2020 Post subject: |
Damage to the threads on the bolts should be obvious when you look at it. If the thread on the bolts is ok, the captive nuts may be damaged.
You've got most of it. they are called "flange bolts". I'd go for high tensile steel if they are attaching an engine mount to the frame like it looks in the picture. The ones there appezar to be part-threaded.
The ones in your third link down would be ideal and I have used that seller on several occasions.
https://www.ebay.co.uk/itm/FLANGED-HEXAGON-BOLTS-HIGH-TENSILE-8-8-PLATED-STEEL-FLANGE-HEX-SCREWS-M6-M8-M10/362293650219
If the captive nuts are damaged, you might be able to get slightly longer bolts and use a nut on the end of them.
If they are holding an engine mount and are loose, I would not ride the bike. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| sapstar |
 sapstar Nova Slayer
| sapstar |
 sapstar Nova Slayer
| doggone |
 doggone World Chat Champion
| sapstar |
 sapstar Nova Slayer
| sapstar |
 sapstar Nova Slayer
 Posted: 13:34 - 01 Mar 2020 Post subject: |
Thanks for your help guys. The stock bolts were out enough on the back to take a nut. So I just left the stock bolts and added nuts on the back to be able to tighten them fully. All sorted now . ____________________ First/Current Bike - Kawasaki ER-6N |
 Posted: 14:35 - 01 Mar 2020 Post subject: |
One caveat. You MIGHT want to use some sort of locking device (either a spring washer or a nylok nut) to prevent them rattling loose. That said, the bolt didn't have one so it shouldn't if it's done up to the correct tension as per the owners manual.
I would always use high tensile steel over stainless in this application. It's load bearing and acting in shear. Stainless is unpredictable in its strength (even within the same grade) and can harden and become brittle with time/work/temperature/weathering. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| sapstar |
 sapstar Nova Slayer
| NJD |
| sapstar |
 sapstar Nova Slayer
 Posted: 13:25 - 02 Mar 2020 Post subject: |
@NJD thanks very much for the helpful advise. I have now ordered a torque wrench like you suggested and some 1/2" impact sockets to go with it.
I wasn't even aware of tightening the bolts to a specific torque setting... . First job I took up on my bike myself and learnt a lot from it...
From the below table can someone advise the right torque setting for these bolts on both sides?
https://i.ibb.co/qxHX3n5/Screenshot-2020-03-02-at-12-14-21.png
There are 2 bolts on the right and 2 on the left. I am guessing these are the Front engine mounting bolt (Left - 44nm, Right - 49nm) and Rear engine mounting bolt (Left - 44nm, Right - 44nm). Is this correct?
Also I replace the following bolt just above brake pedal on the right and the same location on the left. What is this bolt called. so I can find the right torque setting?
https://i.ibb.co/tPJrcXH/Screenshot-2020-03-02-at-12-18-58.png ____________________ First/Current Bike - Kawasaki ER-6N |
| NJD |
 Posted: 01:13 - 04 Mar 2020 Post subject: |
Providing that this -- https://mototh.com/files/kawasaki/ER6n/Kawasaki-ER6n-Service-Manual-EN.pdf -- is the correct year of your bike then as below.
8-2 in that manual for better image quality.
https://i.postimg.cc/nctw0sxZ/123.png
https://i.postimg.cc/x1fpVWq4/1234.png
"Impact sockets" are made to be used on an impact gun, or alike. Mainly because they withstand more brutal force than a regular socket and therefore loosen extremely stuck nuts/bolts. Nothing wrong with using them without an impact gun, but perhaps useless for regular use unless only type of socket you have in that size.
I'd stick to using regular 1/2 sockets on that torque wrench unless budget is tight. Always handy to keep impact sockets for future use, though.
As for that bolt you picture look at manual above for the "frame" section and see if you can spot it. Looks like a small Allen head bolt with a collar, can't imagine very tight. ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶ |
| sapstar |
 sapstar Nova Slayer
 Posted: 17:58 - 04 Mar 2020 Post subject: |
Thanks @NJD. I found the relevant section for the 2015 ER-6N (The one in the picture is the model prior to 2012). The torque settings are 25 on the left and 30 on the right. The torque wrench I bought only starts at 27.... I am going to do 27 on the left and 30 on the right. ____________________ First/Current Bike - Kawasaki ER-6N |
| NJD |
 Posted: 18:48 - 04 Mar 2020 Post subject: |
27 Nm on a 25 Nm torque setting is over torquing it, and that's how things like that welded nut on the back of the bracket become rounded and useless. Its not by much, and I imagine you may get away with it, but not a habit to get into.
25 Nm and 30 Nm can be done by hand, and I'd go with a 1/4 ratchet and the appropriate socket or hex bit etc. Seat it all the way in and then give it a couple of <insert word> on the ratchet to tighten it.
Practice on the 30 Nm one first, tighten it as much as you'd go by hand until it feels like time to stop and then use the torque wrench to see how close you are; and then you'll know if you can do the left hand one without the torque wrench confidently. You'll know if you came close as the torque wrench will "click" instantly.
Be sure to learn how to set the torque wrench up before trying it on the bike first.
If you've got some brake cleaner then clean the threads out where the bolt goes into, and the thread bolt if you can. Loctite on the bolt if needed (sparkling clean first). Cotton buds may help on the internal thread. There is a drill attachment etc perfect for internal threads but that's OTT here.
Whole reason for a torque wrench here is the importance of what its doing: holding the engine in place. Tightening it to right spec will prevent them from vibrating loose over the course of rides and moving about in the frame in a way that it shouldn't -- to the extreme end if not mounted properly.
Better to er on the side of caution, and check bolt after one or two rides than to over tighten and end up at garage asking for them to repair the thread (not difficult but half an hours labour not spend is a good habit to get into).
Use nail varnish to put a dot on the head of the bolt and on the frame of the bike in line with each other once done, and then you'll be able to see if one has moved that its come loose. ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶ |
| sickpup |
 sickpup Old Timer
| sapstar |
 sapstar Nova Slayer
| Nobby the Bastard |
| sapstar |
 sapstar Nova Slayer
| Nobby the Bastard |
The last post was made 6 years, 222 days ago. Instead of replying here, would creating a new thread be more useful? |
