Problem installing engine bars on ER-6N
sapstar
PostPosted: 22:13 - 29 Feb 2020    Post subject: Problem installing engine bars on ER-6N Reply with quote
I bought Renntec engine bars for my 2015 Kawasaki ER-6N and installed them today
The bars came with all nuts and bolts necessary, except for the right side, behind the fairing, just in front of the engine. The instructions suggest I need to use the existing bolts which were taken out. In my case the existing bolts continuously spin and I can't tighten them. These are 2 M8x60 bolts. See picture below from installation instructions.
https://i.ibb.co/hFLzyXr/20200229-210652.jpg
Can someone please let me know what kind of bolts I need to buy to replace these? I checked in ebay and see a number of different types of bolts and unable to decide which ones are right.
Eventhough the bolts are spinning when I tighten them, the fitting seems to be sturdy and there is no movement. Is the bike drivable in this condition?
Also anyone know if the nuts behind these bolts are removable? If so I would like to replace them too.
Found these on ebay.
https://www.ebay.co.uk/itm/233275990803
https://www.ebay.co.uk/itm/362217874580
https://www.ebay.co.uk/itm/362293650219
https://www.ebay.co.uk/itm/372090349564
First/Current Bike - Kawasaki ER-6N
Nobby the Bastard
Harley Gaydar
PostPosted: 22:51 - 29 Feb 2020    Post subject: Re: Problem installing engine bars on ER-6N Reply with quote
The problem isnt the bolts are wrong, it's the fact you haven't realised that the holes aren't aligned.
Triumph Sprint ST 1050
sapstar
PostPosted: 23:16 - 29 Feb 2020    Post subject: Re: Problem installing engine bars on ER-6N Reply with quote
The holes are definitely aligned. I can see the bolts come through the nut on the other side. I also checked if the nuts were spinning on the back, which is not the case.
When I tighten them, they get tight upto a point and then if I give it one more turn, they become loose and keep spinning.
NJD
PostPosted: 23:25 - 29 Feb 2020    Post subject: Reply with quote
Then you've either damaged the threads on the bolts or inside the frame of the bike, or nut (assume welded nut onto frame or engine bars for bolt to feed into).
Local bike shop can repair, or D.I.Y if you can afford a kit of the correct size (M8 x whatever pitch the bolt is).
The bolts shouldn't be that far out, though, and the head of the bolt should get closer to the frame as it gets tighter. As above either isn't in line or you've tightened them at a slight angle and damaged it as per above.
PostPosted: 01:25 - 01 Mar 2020    Post subject: Reply with quote
Damage to the threads on the bolts should be obvious when you look at it. If the thread on the bolts is ok, the captive nuts may be damaged.
You've got most of it. they are called "flange bolts". I'd go for high tensile steel if they are attaching an engine mount to the frame like it looks in the picture. The ones there appezar to be part-threaded.
The ones in your third link down would be ideal and I have used that seller on several occasions.
https://www.ebay.co.uk/itm/FLANGED-HEXAGON-BOLTS-HIGH-TENSILE-8-8-PLATED-STEEL-FLANGE-HEX-SCREWS-M6-M8-M10/362293650219
If the captive nuts are damaged, you might be able to get slightly longer bolts and use a nut on the end of them.
If they are holding an engine mount and are loose, I would not ride the bike.
sapstar
PostPosted: 01:38 - 01 Mar 2020    Post subject: Reply with quote
Thanks @NJD @stinkwheel.
I didn't see any obvious damage on the threads. I have some fully thread M8x70mm bolts at home. I will try these first to identify if it is the nut or the bolt which is stripped. If they work, then I will buy the m8x60mm. If not, I will get m8x70mm along with nuts to secure on the other side.
Will the zink plated bolts be ok outdoors? One of the links I posted is A4-80 stainless steel which is supposed to be high tensile and corrosion resistant. Would these be better?
sapstar
PostPosted: 10:25 - 01 Mar 2020    Post subject: Reply with quote
Tried another brand new m8 bolt I have and it does the same. So I think its definitely the welded nut on the back which got stripped.
I am able to get high tensile bolts in toolstation so I can finish the job today. These are fully threaded though. Is there an issue using fully threaded instead of the part threaded bolts?
doggone
PostPosted: 10:58 - 01 Mar 2020    Post subject: Reply with quote
Probably not, You are getting longer bolt(s) with a nut to go right through I take it.
sapstar
PostPosted: 11:04 - 01 Mar 2020    Post subject: Reply with quote
Yes correct, the only difference is that the stock bolts are partially threaded, but I can only get fully threaded ones locally.
sapstar
PostPosted: 13:34 - 01 Mar 2020    Post subject: Reply with quote
Thanks for your help guys. The stock bolts were out enough on the back to take a nut. So I just left the stock bolts and added nuts on the back to be able to tighten them fully. All sorted now Smile.
PostPosted: 14:35 - 01 Mar 2020    Post subject: Reply with quote
One caveat. You MIGHT want to use some sort of locking device (either a spring washer or a nylok nut) to prevent them rattling loose. That said, the bolt didn't have one so it shouldn't if it's done up to the correct tension as per the owners manual.
I would always use high tensile steel over stainless in this application. It's load bearing and acting in shear. Stainless is unpredictable in its strength (even within the same grade) and can harden and become brittle with time/work/temperature/weathering.
sapstar
PostPosted: 18:35 - 01 Mar 2020    Post subject: Reply with quote
The nuts I used are the standard zink plates ones. Not the nylok nut. I just hand tightened it to the maximum I can. Will have a mechanic look at it next time I go for a service, so it can be tightened to the correct tension.
I have some medium strength loctite. Would it be wise to add some to the new nut?
NJD
PostPosted: 19:34 - 01 Mar 2020    Post subject: Reply with quote
Can't hurt. Only need a small amount. Apply to threads and tighten as quickly as can so will set and then leave alone.
When you're next in the shop ask them for, as above, a nylok nut. They'll have tubs of various bolts and nuts hanging around. Also google torque setting and get them to use a torque wrench to go over the bolts you've done up as it doesn't sound like you have one (something like this may be of use. I went with the ones that Halfords sell but depends what type you like and can afford).
Just be aware that when you apply copper grease to threads of bolts torque settings go out the window. That's an easy way to cause some damage so if you ever do that on a bolt that needs torquing up just go by experience and hand tighten to about what the book says and use feel at the same time. Torque settings often don't account for age of bolt being used or the threads.
I had this issue when installing engine bars on my CBF1000. For me it was more the standard bolt didn't fill the extra gap the engine bars added so stripped the thread on the bolt. Local shop used a longer one. Just something to expect if you're ever doing this again in the future.
I shoved one end of my engine bars into the gap its supposed to be mounted to and angle grinded the other side off as there was no way I was undoing an engine bolt on a 2006 bike that I can almost guarantee hasn't been out since it was fitted at the factory. Kind of takes away from the bars purpose but there's an afternoon of pain I didn't want to get into.
sapstar
PostPosted: 13:25 - 02 Mar 2020    Post subject: Reply with quote
@NJD thanks very much for the helpful advise. I have now ordered a torque wrench like you suggested and some 1/2" impact sockets to go with it.
I wasn't even aware of tightening the bolts to a specific torque setting... Sad. First job I took up on my bike myself and learnt a lot from it...
From the below table can someone advise the right torque setting for these bolts on both sides?
https://i.ibb.co/qxHX3n5/Screenshot-2020-03-02-at-12-14-21.png
There are 2 bolts on the right and 2 on the left. I am guessing these are the Front engine mounting bolt (Left - 44nm, Right - 49nm) and Rear engine mounting bolt (Left - 44nm, Right - 44nm). Is this correct?
Also I replace the following bolt just above brake pedal on the right and the same location on the left. What is this bolt called. so I can find the right torque setting?
https://i.ibb.co/tPJrcXH/Screenshot-2020-03-02-at-12-18-58.png
NJD
PostPosted: 01:13 - 04 Mar 2020    Post subject: Reply with quote
Providing that this -- https://mototh.com/files/kawasaki/ER6n/Kawasaki-ER6n-Service-Manual-EN.pdf -- is the correct year of your bike then as below.
8-2 in that manual for better image quality.
https://i.postimg.cc/nctw0sxZ/123.png
https://i.postimg.cc/x1fpVWq4/1234.png
"Impact sockets" are made to be used on an impact gun, or alike. Mainly because they withstand more brutal force than a regular socket and therefore loosen extremely stuck nuts/bolts. Nothing wrong with using them without an impact gun, but perhaps useless for regular use unless only type of socket you have in that size.
I'd stick to using regular 1/2 sockets on that torque wrench unless budget is tight. Always handy to keep impact sockets for future use, though.
As for that bolt you picture look at manual above for the "frame" section and see if you can spot it. Looks like a small Allen head bolt with a collar, can't imagine very tight.
sapstar
PostPosted: 17:58 - 04 Mar 2020    Post subject: Reply with quote
Thanks @NJD. I found the relevant section for the 2015 ER-6N (The one in the picture is the model prior to 2012). The torque settings are 25 on the left and 30 on the right. The torque wrench I bought only starts at 27.... Sad I am going to do 27 on the left and 30 on the right.
NJD
PostPosted: 18:48 - 04 Mar 2020    Post subject: Reply with quote
27 Nm on a 25 Nm torque setting is over torquing it, and that's how things like that welded nut on the back of the bracket become rounded and useless. Its not by much, and I imagine you may get away with it, but not a habit to get into.
25 Nm and 30 Nm can be done by hand, and I'd go with a 1/4 ratchet and the appropriate socket or hex bit etc. Seat it all the way in and then give it a couple of <insert word> on the ratchet to tighten it.
Practice on the 30 Nm one first, tighten it as much as you'd go by hand until it feels like time to stop and then use the torque wrench to see how close you are; and then you'll know if you can do the left hand one without the torque wrench confidently. You'll know if you came close as the torque wrench will "click" instantly.
Be sure to learn how to set the torque wrench up before trying it on the bike first.
If you've got some brake cleaner then clean the threads out where the bolt goes into, and the thread bolt if you can. Loctite on the bolt if needed (sparkling clean first). Cotton buds may help on the internal thread. There is a drill attachment etc perfect for internal threads but that's OTT here.
Whole reason for a torque wrench here is the importance of what its doing: holding the engine in place. Tightening it to right spec will prevent them from vibrating loose over the course of rides and moving about in the frame in a way that it shouldn't -- to the extreme end if not mounted properly.
Better to er on the side of caution, and check bolt after one or two rides than to over tighten and end up at garage asking for them to repair the thread (not difficult but half an hours labour not spend is a good habit to get into).
Use nail varnish to put a dot on the head of the bolt and on the frame of the bike in line with each other once done, and then you'll be able to see if one has moved that its come loose.
sickpup
Old Timer
PostPosted: 20:23 - 05 Mar 2020    Post subject: Reply with quote
How do you strip an m8 thread without noticing?
sapstar
PostPosted: 17:35 - 08 Mar 2020    Post subject: Reply with quote
Thanks @NJD. Followed your instructions and hand tightened the left to roughly 25nm I think and the right to 30 using the torque wrench. I didn't bother removing the nuts again to put the glue, but next time it is in service, I will as the garage to do it properly.
@sickpup this is the first time I am doing any work on the bike myself. The bolts were not budging when I tried to unscrew them. So I used an impact driver I have. This got the bolts out, but unfortunately stripped the nuts. Atleast this is a good learning for me.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:19 - 08 Mar 2020    Post subject: Reply with quote
You span it the wrong way? Shocked
You do know an impact driver goes in two direction?
sapstar
PostPosted: 20:54 - 08 Mar 2020    Post subject: Reply with quote
I am pretty sure, I didn't spin it the wrong way. I was guessing that using impact driver put too much torque which may have caused this as I used it only on the right side where I ended up with problems. On the left, I was able to get the bolts off manually and no problems tightening them.
Nobby the Bastard
Harley Gaydar
PostPosted: 09:24 - 09 Mar 2020    Post subject: Reply with quote
There no way you would have stripped the thread buy undoing it. Only overtightening them strips them.
The last post was made 6 years, 221 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.05 - MySQL Queries: 13 - Page Size: 126.54 Kb
