Bringing a Bike out of Storeage
CorriganJ
PostPosted: 08:04 - 17 Jul 2020    Post subject: Bringing a Bike out of Storeage Reply with quote
I had to leave my bike in a hurry because of Coronovirus. It's been sitting in a shed since Christmas. In a few weeks I am heading back to where it is, and I need it as transport ASAP to get around. I can't afford to wait around for a garage or for parts or whatever to arrive, so I am ordering anything I might need to arrive there before I do. what will I (probably) need to do to get it up and running?
I'm planning to:
Clean the carbs - I guess its had old fuel sitting in them for 6 months now, so thats the biggest issue.
New petrol (how do I dispose of the old stuff?)
Charge the battery (hoping it doesn't need replacing but I guess halfords can sort me if it does)
Change the oil
Lube chain
Air in tires
Is there anything else that I might also need to do? I'm hoping that things like fork seals are still okay. If not I'm in trouble. But yeah, I think carb cleaner is probably all I need to buy because I have everything else? Thanks all
PostPosted: 08:24 - 17 Jul 2020    Post subject: Reply with quote
To get it up and running all you should need to do is start it up.
Bikes don't disintegrate if left for a few months.
The tyres should still have air in them and the chain lube that was on it in December will still be on the chain. The battery might need jump starting but that's no biggie.
What bike is it?
arry
PostPosted: 08:31 - 17 Jul 2020    Post subject: Reply with quote
Have left bikes far longer than that and just jumped on and ridden them. Even my Enfield with its horrifically cheap and nasty lead acid Indian battery turned over and fired up first turn of the key after ~6 months.
CorriganJ
PostPosted: 08:34 - 17 Jul 2020    Post subject: Reply with quote
Man that would be good. I miss my little Honda. Can't wait to rag it up and down some country lanes back and forth to the test center.
weasley
PostPosted: 08:56 - 17 Jul 2020    Post subject: Reply with quote
Same. When I bought my Thundercat it had been stood for 12 months with no battery tender. It very nearly started first time but did need to be charged, after which it started and ran OK for the following 17 years with no carburettor intervention. It would often stand for months at a time and still fire right up.
PostPosted: 09:20 - 17 Jul 2020    Post subject: Reply with quote
I literally just dragged my VFR out which hasn't been ridden since October last year.
I charged the battery and pumped up the tyres and did all the usual pre-ride checks. Took about 30 seconds to pick up and fire and about a minute to be idling properly on all 4 pots. Off on a run up North for the weekend.
arry
PostPosted: 10:11 - 17 Jul 2020    Post subject: Reply with quote
Be fine. Be prepared for a new battery at worst case but can't see you needing to do much to it to be back on road.
CorriganJ
PostPosted: 11:27 - 17 Jul 2020    Post subject: Reply with quote
So maybe carb cleaner will be not needed?
om15
PostPosted: 14:15 - 17 Jul 2020    Post subject: Reply with quote
You might look at putting some redex fuel cleaner in the tank on next fill up, I tend to put some in the tank in late autumn and hope that this cleans the injectors before winter lay up, and again in the spring.
Alcohol doesn't solve problems, but neither does milk
PostPosted: 14:22 - 17 Jul 2020    Post subject: Reply with quote
I've used Redex a lot, and on badly gummed up fuel systems it's not enough, and on working fuel systems it has no noticeable effect. It could be doing absolutely nothing for all I know. If I can't see a measurable effect, why spend the money on it?
PostPosted: 15:57 - 17 Jul 2020    Post subject: Reply with quote
Go to a petrol station and fill the tank up, it's no more complicated than that. Thumbs Up
dynax
PostPosted: 17:29 - 17 Jul 2020    Post subject: Reply with quote
Don't over think it, just crank it over and if it starts great otherwise try jump starting it Laughing Thumbs Up
Mike.
Bikes: Xena, Bridget,Florence
https://www.youtube.com/channel/UCmihUc0xXxYbR4_0l-F1FzA/videos?view_as=subscriber
PostPosted: 22:53 - 19 Jul 2020    Post subject: Reply with quote
Did 530 miles on it this weekend. It did actually conk out once which turned out to be because rainwater had formed a seal under my small tank bag and formed a vacuum on the tank breather. Literally had to open then close the tank to fix it.
Fisty
PostPosted: 17:03 - 20 Jul 2020    Post subject: Reply with quote
The TL1000R hadn't been used in 18 months until I took it for its MOT.
I started it, checked the lights worked, rode it.
It's been 6 months, not 6 years.
Fatter and faster than Fret
iooi
PostPosted: 17:08 - 20 Jul 2020    Post subject: Re: Bringing a Bike out of Storeage Reply with quote
Is that all...
Mine has been sat in the garage for 4 years Embarassed
Flattened 2 batteries. Now on a conditioner to make sure does not happen again.
Fires up 1st time everytime, idles just fine.
Despite only a litre or so of fuel in it.
Just do the normal checks and ride it.... Laughing
A100man
PostPosted: 07:28 - 21 Jul 2020    Post subject: Reply with quote
Interesting thread, confirms most of my experiences..
So, no ill effects form the dreaded ethanol and no need for 'Stabil' (whatever the fuck that snake oil is)..
PS I also hate battery tenders.. (disconnect the earth on storage and recharge if necessary the day before intended use)
PostPosted: 07:35 - 21 Jul 2020    Post subject: Reply with quote
it does depend on the bike. Petrol is a blend, not a single uniform liquid, and some of it's components are very volatile. That means they evaporate continually at room temperature. Higher temperatures increase the probability of any given molecule joining the vapour. Having the fuel sealed decreases the probability of the volatile components from escaping.
With Ethanol in fuels now, if you let the volatile components go, you're left with a sort of gooey varnish stuff that isn't nice. So yeah in some situations leaving fuel in a bike without running it for years is OK, and some it's bad. It's not a definitive thing, but it's wise to take precautions.
I have no idea how fuel stabiliser actually works, but it is recommended by fuel companies (who don't make it themselves I don't think). It could all be lies, but I doubt it. I don't think it's snake oil, certainly it's less snake oil like than something like Redex.
xX-Alex-Xx
PostPosted: 08:08 - 21 Jul 2020    Post subject: Reply with quote
[quote="MarJay"]
I used to be on another bike forum, and it was the same every year. Winter comes along and people put their bikes away shouting "I don't bother with stabiliser, battery chargers" etc etc, and in the spring they're the same ones bitching that their bike won't start cos the carbs/injectors are gummed up and the batteries are fubar'd. Rolling Eyes Laughing
DILLIGAF
A100man
PostPosted: 22:04 - 23 Jul 2020    Post subject: Reply with quote
Hey mister, what's an injector?
To be fair I've had gummed up carbs but only after several years of leaving the bike with fuel bowls full. I now drain the bowls before a lay up. Batteries are disconnected and left then recharged. Really 6 months is not long enough (as this thread seems to confirm) to damage the fuels system. I expect the 'bitchers' have other issues..
MCN
PostPosted: 03:04 - 24 Jul 2020    Post subject: Reply with quote
I've never ever saw a Stone age bike. 🤔
The last post was made 6 years, 113 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 111.69 Kb
