Mechanic started my Bike while draining engine oil!!!!!
ABR1997
PostPosted: 20:04 - 23 Jan 2021    Post subject: Mechanic started my Bike while draining engine oil!!!!! Reply with quote
Hi guys I'm new here, I've been riding for almost 5 years, I have anxiety and OCD, my bike is a Royal Enfield Thunderbird 500X, recently I went for an oil change and during the oil change when the oil was draining half way, I told my mechanic to adjust the throttle cable and make it softer, he immediately turned the ignition On and started the bike, I panicked and I immediately turned off the engine 5 seconds later, I've been told to never start a vehicle without engine oil and my mechanic started it for 5 seconds, I'm really worried that my bike might be damaged because he started the bike without engine oil, he told me that it was actually okay because some engine oil was stuck on top of the engine because he was draining it and it came out half, it was still draining and half of the engine oil had already dropped on the pan below but some oil was still in the sump, since I have OCD I assume that my bike might be slightly damaged, is my bike damaged? He started the bike while draining the engine oil half way and the bike was running for 5 seconds till I shut it off, I'm really worried guys! Help me.
doggone
PostPosted: 20:08 - 23 Jan 2021    Post subject: Reply with quote
It would be fine for a minute or two, he would be wanting to clear the oil pump of old oil.
Oil is ... oily and coats surfaces for a long time.
Riding down the road is very different to a minute ticking over.
ABR1997
PostPosted: 20:15 - 23 Jan 2021    Post subject: Reply with quote
I have anxiety and OCD, let me tell u this again, the bike was getting drained of engine oil and already half of it was out and dropped in the pan below, the mechanic started it out of the blue and I panicked and shut it off 5 seconds later, he said it was okay that there was actually some engine oil left and the engine was fine, I have my doubts though is my engine fine? Give me advice friend please, sorry for repeating I have anxiety and OCD, I'm a perfectionist, also what are the symptoms of a dying engine? I've only ran 6000 kilometres but I'm worried that the damage has been done! Reply please! 😭
PostPosted: 20:17 - 23 Jan 2021    Post subject: Reply with quote
Don't worry - half full of oil is a natural running condition for an Enfield Smile
gbrand42
PostPosted: 20:19 - 23 Jan 2021    Post subject: Reply with quote
ABR1997 wrote:
I'm a perfectionist
And you ride a RE? Wow
Engine will be fine, they are hardly highly stressed, especially at no load for a short time, dont worry
Yamaha RD50M, Honda C90, Yamaha RS100, Yamaha RD125LC, Honda XL125 V9 Varadero, Honda NT700VA, Honda VFR800X, Honda CRF1000L, Honda ST1300 Pan European
Nobby the Bastard
Harley Gaydar
PostPosted: 20:23 - 23 Jan 2021    Post subject: Reply with quote
Repeating things again and again isnt going to change the fact that 5 seconds on tickover with a low oil level isn't going to hurt an Enfield.
The fact you are ocd doesn't in any way affect any potential damage to the engine.
Are you just upset that we haven't given the reply you want?
Triumph Sprint ST 1050
ABR1997
gbrand42 wrote:
ABR1997 wrote:
I'm a perfectionist
I used to ride a KTM and my anxiety went crazy with that bike, it had so many issues like ECU, headlight, TFT failure etc, I sold it eventually because it caused too much stress anyways my bike is fine right?
Enfields are easy to fix and maintain and cheaper that Japanese too, but still my OCD is killing me, give me advice and reassure me! 🙏🏿😭
ABR1997
PostPosted: 20:25 - 23 Jan 2021    Post subject: Reply with quote
I hope my bike is fine though, I have serious anxiety and OCD, I'm taking medication and I'm sick mentally that is, please forgive me. 🙏🏿😭
smokin joe
PostPosted: 20:37 - 23 Jan 2021    Post subject: Reply with quote
You do seem to worry a lot.
You sure you're not suffering from OCD?
Riejufixing
PostPosted: 20:38 - 23 Jan 2021    Post subject: Re: Mechanic started my Bike while draining engine oil!!!!! Reply with quote
You're probably OK, but I would not go back there, to me it's indicative.
A100man
PostPosted: 20:39 - 23 Jan 2021    Post subject: Reply with quote
1) Your bike is fine.. Don't worry.
If in future if some thing else happens rember everyting can be fixed.
Evil Hans
PostPosted: 21:11 - 23 Jan 2021    Post subject: Reply with quote
Nah. I'm sure he would have said ...
mentalboy
PostPosted: 21:18 - 23 Jan 2021    Post subject: Reply with quote
Buy yourself a stress ball and use it.
Make mine a Corona.
WD Forte
PostPosted: 22:06 - 23 Jan 2021    Post subject: Reply with quote
Look, I know you're really upset now. Why don't you sit down and take a stress pill and think things over?
bikers smell of wee
Nobby the Bastard
Harley Gaydar
PostPosted: 22:15 - 23 Jan 2021    Post subject: Reply with quote
Or you could count to ten. Every time you touch a door handle....
Easy-X
PostPosted: 22:23 - 23 Jan 2021    Post subject: Reply with quote
Suffers from anxiety... buys a motorbike Thinking
Well, don't ever buy a 2-stroke! They don't even have an oil system as such* and you just keep your fingers crossed enough enters the system mixed in with the petrol.
The good news is you could drain all the oil and there'll be still enough lurking in there on the surfaces to make little odds to all but the most highly strung engines. For example, in my user manual it says I need 2.3L for an oil change or 2.6L if I also change the oil filter cartridge. And yet the manufacturer states it has a total oil capacity of 2.7L... huh?
Yes, there's 100ml stuck in there somewhere. You'll never get it out unless you strip the engine and clean all the components or run it till it gets hot, 5 seconds isn't it by a long chalk. I'd say between the lurking oil, the filter and the "half drained" you mention there was probably another litre still in there.
Here's the other thing: what's the oil for? Seriously. If it were just for lubrication the humble 2-stroke ekes out a life of mere millilitres and does okay so what's up with the litres of oil in a 4-stroke?! Okay so unless you have a pre-unit Enfield half of it will keep the gearbox from shredding itself but the rest is actually for cooling regardless of whether you have an actual oil rad and even to some extent on water cooled bikes. The engine didn't get hot in 5 seconds.
tl;dr IMHO bike had more than enough oil to idle without any possibility of damage and neither got hot enough or put under enough load for it to be an issue.
*For combustion, the gear box has it's own separate lubrication system.
Hong Kong Phooey
PostPosted: 22:33 - 23 Jan 2021    Post subject: Reply with quote
I think you conveyed the suffering of anxiety really well in your original post, by not having a full stop until right near the end, it forced me to read it, in my own head, in one single breath, and it was quite stress inducing, and made me anxious even though there's no personal peril involved.
AND.BREATHE. Laughing
O.C.D. I doubt it, as you didn't put the periods between the initialism as in this paragraph. Wink
The bike will be fine, probably Razz. Best prepare a solicitor and brief them just in case Shocked
It's a few seconds, in an unstressed engine, under no load. Your post is a dichotomy of that.
Don't worry, the sun will be here soon and we can all get out on our bikes to escape ourselves.
Kawasaki Jimbo
PostPosted: 22:48 - 23 Jan 2021    Post subject: Reply with quote
Good job everybody.
I’ll give you £100 for the wreck.
xX-Alex-Xx
PostPosted: 23:02 - 23 Jan 2021    Post subject: Reply with quote
A person who truly has that condition spells it CDO as it’s alphabetical.
DILLIGAF
Raffles
PostPosted: 23:16 - 23 Jan 2021    Post subject: Re: Mechanic started my Bike while draining engine oil!!!!! Reply with quote
ABR1997 wrote:
I'm really worried that my bike might be damaged....is my bike damaged?
That may depend upon whether the engine was half empty or half full. Which was it?
PostPosted: 23:58 - 23 Jan 2021    Post subject: Reply with quote
One good thing for the OP is that unlike most bikes Royal Enfields have roller bearing big-ends (most bikes are shell bearing). The big-end is one of the the first things to suffer from catastrophic oil failure but his bike being roller bearing would probably run for a long while on idle and a fair good while under load even if all the oil were drained out.
I would not be going back to that mechanic though. Running the engine whilst draining the oil is stupid and unnecessary. What little is left in the pump is not going to make a difference to the oil change.
PostPosted: 00:03 - 24 Jan 2021    Post subject: Re: Mechanic started my Bike while draining engine oil!!!!! Reply with quote
Don't watch the Royal Enfield video where they run it with no oil, flush it with petrol, then run it again before filling with oil. You'll pop an aneurysm.
jeffyjeff
PostPosted: 06:29 - 24 Jan 2021    Post subject: Reply with quote
ABR1997, Maybe you should consider trading your Royal Enfield for a Honda Cub. Performance is about the same, and the Cub is indestructable. https://www.youtube.com/watch?v=aaeKrqJJqm0
wr6133
PostPosted: 07:41 - 24 Jan 2021    Post subject: Reply with quote
Everyone is winding you up, that engine is going to explode in a ball of fire while you ride.
I'll do you a favour and give you £3.50 for it (£4.50 if it has a 5 speed box).
xX-Alex-Xx
PostPosted: 09:20 - 24 Jan 2021    Post subject: Reply with quote
Dammit Loch Ness monstaaah, I ain’t giving you no tree fiddy!!!
DILLIGAF
The last post was made 5 years, 224 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.48 - MySQL Queries: 15 - Page Size: 129.59 Kb
