| Kezh |
 Kezh L Plate Warrior
| stinkwheel |
 Posted: 23:44 - 16 Jun 2023 Post subject: |
I'd concentrate on getting it running first before blowing your wad on running gear. Being a 90's honda, there's a fair chance most of it will be ok.
It's clearly been out in the rain for a long time.
If it was me. First thing I'd do is get a socket on the end of the crank and make sure it turns over. I'd drain the oil and coolant, see what the stuff that comes out looks like. If it all looks good, flush through the coolant system and stick some fresh fluids in.
I'd have a damned good look in the tank, drain any fuel and if it's rusty, see if that's saveable. If it's clean I'd give it a swill out with fresh fuel and check the tap is working.
I'd be very tempted to pull the carbs and give them a clean, expecially if the rubbers are perished.
Evict any mice from the airbox and clean/replace the air filter.
Check the coils for corrosion round the earths and connectors. Likewise the plug caps. Consider fresh plugs.
Having done all that, I'd get a charged battery hooked up to it and see if the electrics work and the engine turns over. After turning it over for a bit to let oil circulate, I'd hook up the fuel and see if it'll fire up.
Once it's running, then start the long process of de-yakking it. From the looks of it you're going to need chain and sprockets, tyres, probably cables, high likleyhood you'll need to fully strip and service the callipers and master cylinders.
Those dominator headlights were shit when they were new, I'd be fitting a round headlamp. From past experience, the sort of person who fitted dommies also made a dogs dinner of the wiring that used to be in the back of the original headlight. The front indicators are ropy, the rear ones aren't even road legal (too close together).
It'll probably need fork seals. Stanchions seem to have some rust which may or may not clean up.
Some corrosion on the radiator, it may or may not be good. Likewise hoses.
I'd be surprised if you get this back on the road in anything like good order for less than £1000. By the time you've got 2 tyres, chain and sprockets, oil and filters, calliper service kits, MC service kits, brake pads, fork seals, headlamp, flashers, new battery, rubbers/hoses and so on, you're pretty much into 4 figures.
Just so you're aware this isn't a "free" bike. It's probably worth doing because they were decent bikes in their day but it's going to take a lot of work to get it back to properly functional. Even more work to getting it looking good. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Bhud |
 Bhud World Chat Champion
 Posted: 00:23 - 17 Jun 2023 Post subject: |
I would guess the owner doesn't like junk littering their property, and it probably belonged to a family member who's unreliable and has failed to pick it up. Is that correct? In any case, try to find out why it was laid up.
Oil, coolant, carb cleaner, tank de-ruster, new brake pistons, brake fluid, carb rubbers, etc. Plus a chain. These things cost money. Money which you'd perhaps have better put towards a running bike. At this point, who knows? Just a thought.
Some people call them projects. I've done plenty, and I now call them shitters. The nicest possible description of most of them is "false economy". I'm only going to get nice/new bikes from now on. What you've got there is a low mileage decent quality and superbly engineered bike that was set to one side for some reason (what?), and if it's fine, then all you've got to look at is oil, filter, chain, tyres, etc. In which case, take it. If it's more, then run. You see, bikes of that type were taken for granted by idiots who thought they were bulletproof (they weren't - all bikes need proper maintenance). Most new bikes are overweight and underpowered. So it's worth having if it's good and all it needs are basic maintenance items.
You've got to know when to hold 'em, know when to fold 'em, know when to walk away, and, know when to RUN.
Now, there's a possibility the owner is just being kind to you, in which case definitely snap up that bike. Look that gift horse right in the mouth and investigate for faults. I suggest a compression test as well as testing the electrics with a fully charged battery. |
| stinkwheel |
 Posted: 00:36 - 17 Jun 2023 Post subject: |
Just to give you an idea of what you are taking on. Here's a blog of me doing up my old VFR which is a similar age to that bike and had been left sitting for a similar length of time.
Now I started from a place of knowing what was wrong with it because the 10 years of neglectful abandonment were down to me. That one had been stored indoors and I knew it had a good engine. As you can see, you're looking at taking off and at least inspecting if not cleaning and re-building pretty much every cycle part on the bike.
https://www.bikechatforums.com/viewtopic.php?t=334031 ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Kezh |
 Posted: 00:39 - 17 Jun 2023 Post subject: |
| stinkwheel wrote: | I'd concentrate on getting it running first before blowing your wad on running gear. Being a 90's honda, there's a fair chance most of it will be ok. |
Thank you for the very detailed response, I really appreciate it. I am aware it is not a 'free' bike and I'm ready for the frustration and cost. Each point you made will be taken into consideration, cheers.
| Bhud wrote: | I would guess the owner doesn't like junk littering their property, and it probably belonged to a family member who's unreliable and has failed to pick it up. Is that correct? In any case, try to find out why it was laid up. |
This bike belongs to my uncle, and is still in his possession. He had multiple bikes and stopped riding for a while after an accident(on a different bike), he sold his other two bikes and kept this as he always wanted to get back riding but circumstances and other priorities took over(I know, cliché) and the bike was unfortunately just left sitting there as it is today.
All his bikes, including this one were always looked after and I do believe him when he says it was in working order when it was laid up.
I know this is out of my league, and I probably am biting off more than I can chew, but like you said, as long as the bike itself was in good nick, its worth a shot right? |
| Bhud |
 Posted: 00:51 - 17 Jun 2023 Post subject: |
| Kezh wrote: | This bike belongs to my uncle, and is still in his possession. He had multiple bikes and stopped riding for a while after an accident(on a different bike), he sold his other two bikes and kept this as he always wanted to get back riding but circumstances and other priorities took over(I know, cliché) and the bike was unfortunately just left sitting there as it is today.
That seems to be OK then. If it's your uncle and he isn't secretly pissed at you, then it should be fine and shouldn't be hiding any nasty secrets. I would take it, yes.
It will need a few things. At least the following:
1) Tyres
2) Components needed for brake overhaul
3) Fuel lines and other rubbers (e.g. set of carb rubbers)
4) Carbs service
5) Chain and sprockets set
6) Battery
7) Brake components (fluid, piston seals, probably new pistons)
And other stuff. I'd take it.
If it's going to be your only bike and you're doing all the work yourself, you might not have it ready in time for much riding this summer. But it's a quality bike and very much worth having, in my opinion. People will eventually appreciate these bikes a lot. |
| Easy-X |
 Easy-X Super Spammer
| Islander |
 Islander World Chat Champion
| stinkwheel |
 Posted: 11:46 - 17 Jun 2023 Post subject: |
Get the proper factory workshop manual too. It doesn't explain HOW to do things but it does have detailed diagrams or the parts, diagrams of how cables and hoses are routed and all the measurements, specs, fluid types, tighening torques and volumes.
Importantly, it has the order of operations for how to dismantle and reassemble things. So what you take off first, second and third which can be the difference between success and failure.
Haynes/clymer manuals will give you more about to do things but not necessarily as good at what to do in what order. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Fullers1845 |
 Fullers1845 Nova Slayer
| Polarbear |
 Polarbear Super Spammer
 Posted: 09:22 - 20 Jun 2023 Post subject: |
I'd certainly go for it as you know the history of the bike. I presume you have somewhere to work on it where the lady of the house isn't going to moan about you using her kitchen for bike rebuilds .
If you enjoy spannering it will be interesting and educational. If you don't, well that's when you start rushing bits and things start to go wrong. ____________________ Triumph Trophy Launch Edition |
| A100man |
 A100man World Chat Champion
 Posted: 09:40 - 20 Jun 2023 Post subject: |
Pff, you guys.. a wipe over with an oily rag and she'll be good as new
..more seriously provided you're a) not in a hurry and b) not looking to sell on for a profit, have a go. Nothing more satisfying than rescuing the fallen. ____________________ Now: A100, GT250A, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion |
The last post was made 3 years, 57 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 80.07 Kb
