| shadywiki |
 shadywiki Derestricted Danger
| A100man |
 A100man World Chat Champion
 Posted: 12:32 - 15 Jul 2023 Post subject: |
Fazer? Sprocket is on the left hand side isn't it?  ____________________ Now: A100, GT250A, XJ598, FZ750, SL1000
| shadywiki |
| Easy-X |
 Easy-X Super Spammer
| shadywiki |
| Kawasaki Jimbo |
 Posted: 12:46 - 15 Jul 2023 Post subject: |
| shadywiki |
 Posted: 14:47 - 15 Jul 2023 Post subject: |
So i've got the back wheel off, and the adjusters move freely inside the swing arm. The only thing thats tight and won't budge is the bolt/joint where the torque arm meets the caliper bracket.
It'll move up and down, but won't sort of pivot left and right. In my mind, if the adjusters are to move inwards and outwards within the swing arm, then surely this should have some level of play in it to allow adjustement? Is this correct?
I've taken a pic (as per the link below) of what I think should have some play in it. Please correct me if i'm way off.
https://imgur.com/M3Fvt2m |
| doggone |
 doggone World Chat Champion
| Nobby the Bastard |
| Islander |
 Islander World Chat Champion
| shadywiki |
| MCN |
 MCN Super Spammer
| Islander |
 Posted: 23:11 - 15 Jul 2023 Post subject: |
Loosen the rear bolt on the torque arm and the carrier should pivot on the bolt.
Once you've got it moving you can adjust your chain. Replace the wheel, axle and nut. Bump it forward using a hammer on the tyre. Get the chain fitted and pull the wheel back on the adjusters. Use the marks on the side, or even the gap from slot to axle as a guid to get the wheel pulled back evenly.
You're looking for about 30mm total up/down play on the chain in the middle of the run AFTER the nut is tightened. When you tighten the nut, the chain will pull slightly tighter so start with a little more play, clamp up the axle nut then check it. Adjust as required. ____________________ a.k.a 'Geri'
| shadywiki |
| MCN |
 MCN Super Spammer
The last post was made 2 years, 355 days ago. Instead of replying here, would creating a new thread be more useful? |
