Rear wheel alignment
shadywiki
PostPosted: 12:18 - 15 Jul 2023    Post subject: Rear wheel alignment Reply with quote
Morning all,
I am new to DIY motorbike maintenance and have recently replaced the chain and both sprockets on my FZS600. In attempting to align the rear wheel, I loosen off both locking nuts and unwind all the way out.
The axle on the right side on the swing arm doesnt move, where as the left side where the sprocket is, it loosens off and pushes right the way forward with the tension.
Upon nipping up both nuts, the chain goes tight.
So, in my mind, I need to get the right side to push forwards to match the left, but it won't.
Any ideas?
A100man
PostPosted: 12:32 - 15 Jul 2023    Post subject: Reply with quote
Fazer? Sprocket is on the left hand side isn't it? Confused
shadywiki
PostPosted: 12:35 - 15 Jul 2023    Post subject: Reply with quote
Yes, thats where the sprocket is.
So the sprocket side moves forwards when the alignment nut is loosened, where as the right side when loosened doesn't shift.
Easy-X
PostPosted: 12:39 - 15 Jul 2023    Post subject: Reply with quote
Might want to mention the year along with the model.
Regardless, almost every swing arm has some version of a slot on both sides for the rear axle to sit in i.e. the axel can move forward and back while staying perpendicular to the arms. It sounds like either the axel, adjuster or both is seized on one side.
A few taps with a rubber mallet (or hammer + block of wood) might free it up but worst ways you might have to drop the back wheel out.
shadywiki
PostPosted: 12:42 - 15 Jul 2023    Post subject: Reply with quote
Ah sorry, its a 1999 FZS600.
Thanks, i'll give that a go. I've taken both out and given them both a clean, but i'll try and give it a few gentle nudges! Very Happy
Kawasaki Jimbo
PostPosted: 12:46 - 15 Jul 2023    Post subject: Reply with quote
It’s probably the brake caliper bracket snagging.
https://www.fowlersparts.co.uk/parts/4165917/fzs600-fazer-5dm7-2000-070-b/rear-wheel
shadywiki
PostPosted: 14:47 - 15 Jul 2023    Post subject: Reply with quote
So i've got the back wheel off, and the adjusters move freely inside the swing arm. The only thing thats tight and won't budge is the bolt/joint where the torque arm meets the caliper bracket.
It'll move up and down, but won't sort of pivot left and right. In my mind, if the adjusters are to move inwards and outwards within the swing arm, then surely this should have some level of play in it to allow adjustement? Is this correct?
I've taken a pic (as per the link below) of what I think should have some play in it. Please correct me if i'm way off.
https://imgur.com/M3Fvt2m
doggone
PostPosted: 16:04 - 15 Jul 2023    Post subject: Reply with quote
That needs to pivot, the brake caliper can then rotate slightly as the spindle moves forward or back.
The bolt is too tight or rusted up, it needs releasing even if that means it cutting off and driving the remains out.
Nobby the Bastard
Harley Gaydar
PostPosted: 16:17 - 15 Jul 2023    Post subject: Reply with quote
Buy some.wd40. Spray it.liberally on that joint and then give it some muscle. Do that repeatedly.
Triumph Sprint ST 1050
Islander
PostPosted: 17:07 - 15 Jul 2023    Post subject: Reply with quote
Better still buy some Plus Gas or other dedicated penetrating/release oil... Wink
shadywiki
PostPosted: 17:34 - 15 Jul 2023    Post subject: Reply with quote
Thanks all, much appreciated!
MCN
PostPosted: 17:42 - 15 Jul 2023    Post subject: Reply with quote
All penetrating/release oil is Snake Oil/Shite.
It has more to do with psychological effect than freeing stuck stuff.
Elbow grease or heat are the only methods that work.
Anyway... the axle sits in a block inside the swing arms.
Make sure both blocks are slippery slidery inside the swing Arms. A bit of moly-grease will help. But mostly washes out over time.
Then you'll have to do a rear wheel alignment using string.
Or if you have a nice 'straight' length of wood.
There are tons of video on YouTube that explains how to set up the rear wheel straight.
When you have it straight, the chain is then tensioned by turning the adjuster one turn each as the chain slack get to specification. Rotate the wheel to find the section of chain with least slack. That is the place to set the slack. And lock everything up.
Islander
PostPosted: 22:29 - 15 Jul 2023    Post subject: Reply with quote
Strongly disagree. I've been using it for years and it works. The trick is to give it time to do its stuff.
Elbow grease is likely to end up damaging the fastener or shearing something. Heat works but it's not always appropriate or safe to use.
PostPosted: 23:11 - 15 Jul 2023    Post subject: Reply with quote
Loosen the rear bolt on the torque arm and the carrier should pivot on the bolt.
Once you've got it moving you can adjust your chain. Replace the wheel, axle and nut. Bump it forward using a hammer on the tyre. Get the chain fitted and pull the wheel back on the adjusters. Use the marks on the side, or even the gap from slot to axle as a guid to get the wheel pulled back evenly.
You're looking for about 30mm total up/down play on the chain in the middle of the run AFTER the nut is tightened. When you tighten the nut, the chain will pull slightly tighter so start with a little more play, clamp up the axle nut then check it. Adjust as required.
shadywiki
PostPosted: 20:33 - 16 Jul 2023    Post subject: Reply with quote
Dowsing the thing in WD and long bar did the trick in the end with loosening the nuts/bolts on the torque arm. All adjusted and back on the road.
Thanks all for your input.
MCN
PostPosted: 20:21 - 17 Jul 2023    Post subject: Reply with quote
If something is rusted stuck it's not coming loose with snake oil. I guarantee that.
If it will come loose with snake oil then it wasn't really that stuck.
I do this shit for a living.
Heat and muscle and ally pipes are what works.
The last post was made 2 years, 354 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.68 - MySQL Queries: 13 - Page Size: 89.68 Kb
