| struan80 |
 struan80 World Chat Champion
| recman |
 recman World Chat Champion
| stinkwheel |
 Posted: 09:42 - 08 Sep 2024 Post subject: |
The big question is, is it done yet? Or is he still procrastinating?
I know the feeling, I've been putting off tightening up the header nuts on Mrs stinkwheels CBR because I couldn't be arsed taking all the plastics off again. When it actually came down to it, the whole job only took half an hour.
Todays job of re-fabricating a chain guard for the Enfield will be less fun. It keeps eating them because I fitted a way larger gearbox sprocket so all the tabs need remaking at a different length and angle then welding on. Has to be a precision job too, there's only about 4mm clearance between the chain and frame at one point and I need to get a bit of 1.2mm steel in there without it rubbing on either. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Nobby the Bastard |
| Nobby the Bastard |
| Easy-X |
 Easy-X Super Spammer
 Posted: 17:36 - 16 Sep 2024 Post subject: |
Nice work  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Nobby the Bastard |
| Easy-X |
| Nobby the Bastard |
| Nobby the Bastard |
| stinkwheel |
 Posted: 19:50 - 17 Sep 2024 Post subject: |
I can't see what function those flanges would have. They don't seen to butt against the head. Unless the collar goes all the way down until it hits the flange and they're to stop you over-tightening the exhaust nuts and bending the collar?
I've seen a lot of motorbike exhaust studs and never seen one with a flange. Looking closer at your pictures, it also looks like they are necked down between the two threaded sections to the minor thread diameter which is an odd decision and a stress-riser. Not to mention extra work making them. I'd have expected them to snap there although it looks like they actually snapped into the threaded section.
Most studs I've ever seen are the major diameter for the full length with an unthreaded partion somewhere in the middle (with the exception of some Honda ones which have M8 into the head and M7 for the nuts, again for no apparent good reason other than maybe to encourage them to shear off so a little bit is still sticking out because M8-M8 ones fit fine).
If it was my bike, I'd fit conventional studs and engage my brain as I'm tightening the nuts. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Nobby the Bastard |
| Easy-X |
| Nobby the Bastard |
| sickpup |
 sickpup Old Timer
| Nobby the Bastard |
| sickpup |
 sickpup Old Timer
| Nobby the Bastard |
The last post was made 1 year, 346 days ago. Instead of replying here, would creating a new thread be more useful? |
