Motorhispania Furia indicators not flashing
AzzA1990
PostPosted: 14:08 - 18 Sep 2024    Post subject: Motorhispania Furia indicators not flashing Reply with quote
Hello everyone it's been a while since I have posted on here, I am trying to repair an old 2002 motorhispania furia 50 for my nephew who has just done his cbt so he is itching to ride it however the bike is out of m.o.t, the only issue I see is that the indicators do not flash, now I believe the voltage regulator on these bikes is a combined unit with the indicator flasher relay (correct me if I'm wrong) I have searched high and low all over the interweb and I can not find a direct replacement, I have found other similar but they do not have the same number of terminals, i am trying to think of a way to maybe add in a separate flasher relay but I'm not sure how I would go about this because the bike doesn't have a battery from factory
I'm hoping there may be someone familiar with these bikes that is a bit electrical savvy!
Much appreciated!
Thanks
Nobby the Bastard
Harley Gaydar
PostPosted: 14:46 - 18 Sep 2024    Post subject: Reply with quote
It wouldn't be part of the voltage regulator.
Are you sure that there's no battery?
Triumph Sprint ST 1050
AzzA1990
PostPosted: 15:23 - 18 Sep 2024    Post subject: Reply with quote
100 % sure it does not use a battery, take a look at this wiring diagram
Nobby the Bastard
Harley Gaydar
PostPosted: 15:43 - 18 Sep 2024    Post subject: Reply with quote
Wht make you think thats the wiring diagram for the bike? Please post a photo of the flasher unit that youve taken on the bike.
Has someone put led flashers on it when its designed for bulb?
WD Forte
PostPosted: 15:44 - 18 Sep 2024    Post subject: Reply with quote
looks pretty simple to me
the legend would help but it's easy enough to work out what's what
without it
bikers smell of wee
Nobby the Bastard
Harley Gaydar
PostPosted: 15:47 - 18 Sep 2024    Post subject: Reply with quote
My reading of it is the flasher unit regulates the power to the indiccator bulbs so that the speed stays constant becausse there's no regulation anywhere else.
I'm somewhat confused because every site I've looked at for that bike recommends a battery for them.
Easy-X
PostPosted: 15:55 - 18 Sep 2024    Post subject: Reply with quote
I've seen regulator/flasher combos on this very forum:
https://www.bikechatforums.com/viewtopic.php?t=308759
Nobby the Bastard
Harley Gaydar
PostPosted: 16:12 - 18 Sep 2024    Post subject: Reply with quote
The setup you linked to is a regrec for the whole system whereas the op's system is just for the flasher unit.
AzzA1990
PostPosted: 16:17 - 18 Sep 2024    Post subject: Reply with quote
I got the diagram from the motorhispania page on facebook, it may be the wrong once but it's the one that's been uploaded everytime somone has asked for one for the furia,
Nobby the Bastard
Harley Gaydar
PostPosted: 16:23 - 18 Sep 2024    Post subject: Reply with quote
Photo of flasher unit please. Does it have bulb or led indicators?
AzzA1990
PostPosted: 17:06 - 18 Sep 2024    Post subject: Reply with quote
Hope this helps, there is literally nothing else on the bike that looks like a typical flasher relay
Nobby the Bastard
Harley Gaydar
PostPosted: 17:41 - 18 Sep 2024    Post subject: Reply with quote
That's definately the flasher unit.
I''ll ask for the third time - does it have bulb or led indicators?
jeffyjeff
PostPosted: 17:47 - 18 Sep 2024    Post subject: Reply with quote
Appears to be a regulator rectifier for a single-phase charging system. If not, why would a flasher unit have terminal designation L1 and L2?
History shows again and again how nature points out the folly of men. BOC
Getting old ain't for wimps. R.S. Hain
Nobby the Bastard
Harley Gaydar
PostPosted: 17:51 - 18 Sep 2024    Post subject: Reply with quote
Left and right indicators. Look at the wiring diagram.
AzzA1990
PostPosted: 18:54 - 18 Sep 2024    Post subject: Reply with quote
Original bulb type indicators are fitted mate sorry
Easy-X
PostPosted: 18:56 - 18 Sep 2024    Post subject: Reply with quote
12V AC flasher units are quite common on old scooters. Would adding a 12V Zener diode be sufficient to protect it from the variable voltage coming from the stator?
Nobby the Bastard
Harley Gaydar
PostPosted: 18:57 - 18 Sep 2024    Post subject: Reply with quote
Do you have a multimeter?
Have you checked every bulb is good including the dash indicator one?
Nobby the Bastard
Harley Gaydar
PostPosted: 19:05 - 18 Sep 2024    Post subject: Reply with quote
The dash indicator seems to be earthed through the L1/L2 in the flasher unit. This would indicate there must be some sort of diode arrangement going on in there.
Not quite sure why its necessary, I'd be tempted to buy a led type flasher and connect the L1/L2 wires from the bulbs to earth and connect the output from the flasher to the switch wire and just bypass all that bullshit.
Might blow bulbs in the indicators though.
AzzA1990
PostPosted: 19:06 - 18 Sep 2024    Post subject: Reply with quote
So i have discovered if I remove the headlight and tail light bulb the indicators work fine so it would seem as if there is not enough power to run the lights and the indicators? I have ac voltage of around 45 volts coming from the outer 2 terminals and the L1 and L2 Iow DC voltage from each one but only when the indicators are switched on
Nobby the Bastard
Harley Gaydar
PostPosted: 19:14 - 18 Sep 2024    Post subject: Reply with quote
In that case look at the wattage of the head and tail light
Headlight should be 25w and 25w (dipped and main) and rear should be 5w/21W (rear and brake)
If they are wrong then it's draining too much power, non-electronic flasher units speed are very dependant on the amount of electricity flowing through them.
If the bulbs are the correct wattage and the indicator bulbs are also right wattage (2*10W each side and 1.2 W dash) I'd suspect the stator not giving out enough.
AzzA1990
PostPosted: 19:40 - 18 Sep 2024    Post subject: Reply with quote
That does make sense, would fitting l.e.d indicators help seen as they are a fraction of the wattage of bulb type? Also I believe the headlight is 35w/35w so I may look for a 25/25 and see if that helps, thanks for your help so far you have given me direction on what to check next, I was stumped before
Nobby the Bastard
Harley Gaydar
PostPosted: 19:49 - 18 Sep 2024    Post subject: Reply with quote
Fitting ledss would likely fuck up the flasher unit even more because your typical flasher unit depends on both power in and drain to flash at the corrrect speed. LEDs actually act as if they are infinate resistance so dont pull any power.
You could get round that by using resistors in line to add load but then you will be back to the original problem.
There are ways leds could be used but I really dont think you have the expertise to do them.
That headlight bulb is your problem.
You will find it's quite dim afterwards and will wish that you'd bought a bike with a proper charging circuit and battery so it can have reasonable headlights and indicators at the same time.
A100man
PostPosted: 10:28 - 19 Sep 2024    Post subject: Reply with quote
Hmm, wouldn't simply turning off the headlight 'free-up' some load and enable the indicators in this case..
worst case can you move sw20 back an forth about once every two seconds? Wink
Nobby the Bastard
Harley Gaydar
PostPosted: 10:36 - 19 Sep 2024    Post subject: Reply with quote
Good point.
The last post was made 2 years, 58 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 121.76 Kb
