| blurredman |
 blurredman World Chat Champion
 Posted: 09:47 - 29 Apr 2025 Post subject: |
Hmmmm... maybe I will just keep all the crap specifically to prevent someone else 'enjoying' it  ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 - 40k, 1989 MZ ETZ251 - 52k. |
| blurredman |
 Posted: 09:45 - 01 May 2025 Post subject: |
Fitted new inner (and outter) seal to master cylinder on ETZ250. Brake lever no longer creeps. Finally got around to fixing the brake light switch too.  ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
| blurredman |
 Posted: 11:00 - 03 May 2025 Post subject: |
Finally got around to changing clutch plates on ETZ251, and replaced gear change shaft o-ring oil seal whilst the clutch cover was off as that was leaking. Now need to fix leaking core plug, and also take piston out and see whether anti-rotation pins for the rings aren't recessed in the cheapo pistons (this happened on another bike of mine on a cheapo piston thankfully without too much damage). ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
| Easy-X |
 Easy-X Super Spammer
 Posted: 11:34 - 03 May 2025 Post subject: |
Thoroughly tested my brakes after the bike's service when some c*nt cut across me to get to their oh so important turning. Less SMIDSY and more "if I don't see you, you're not really there" - Schrodinger's Motorbike or some such  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| recman |
 recman World Chat Champion
| DaddyStu |
 DaddyStu Crazy Courier
| blurredman |
 Posted: 08:46 - 13 May 2025 Post subject: |
Bike wouldn't start yesterday- did 110 miles though on Sunday no problem. Felt like ignition - no kickback - and I see there's no spark at the points. They had worn off square and the spark was intermittent at best. I used my tiny file to file the contacts square with eachother again and we're back in action. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
| recman |
| to v or not to v |
 to v or not to v World Chat Champion
| blurredman |
 Posted: 09:09 - 14 May 2025 Post subject: |
| blurredman wrote: | Bike wouldn't start yesterday- did 110 miles though on Sunday no problem. Felt like ignition - no kickback - and I see there's no spark at the points. They had worn off square and the spark was intermittent at best. I used my tiny file to file the contacts square with eachother again and we're back in action. |
Spark has gone again to-day  ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
| WD Forte |
 WD Forte World Chat Champion
| blurredman |
 Posted: 15:46 - 14 May 2025 Post subject: |
Potentially. I believe (but not quite sure) this is an factory set of points which are obviously far better quality than the crappy aftermarket stuff. I put this set of points on 12k miles now which is fairly reasonable before any sort of issues. I've barely looked at the things let alone maintained them.
So tonight I've done some fiddling with some washers to get the pivoting contact to land even more squarely (perfectly infact) on the static contact- and filed them really nicely. We'll see how this goes. I did test the condenser (admitably cold) but that tested fine and the symptoms did not indicate any failure for this case - I have no reason to even think about replacing that test or no test. I'm not one to just change components without making sure they are defective. And as I say aftermarket points are crap- friend of mine had the heel break on two sets within 30 miles. Good job he had two spare...
Additionally, because this bike let me down again - I went to work on the etz251 to-day - which I then got MOTed. It would be nice to have some backup machines. Monday I tried the TS185 too but it had a solidly stuck throttle when I tried to use it as a backup so as well as fixing the etz250 I fixed the Suzuki. Took carb apart this evening and cleaned it all out as it was full of crap, compressed air etc. So- now I got two backup bikes working.. I might need them too  ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
| Zen Dog |
 Zen Dog World Chat Champion
 Posted: 13:42 - 15 May 2025 Post subject: |
Had the back wheel off the CBF to see I could find anything causing the wobble, but I didn't find anything that seemed an obvious problem, and after putting it all back together it's still the same.  ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
My bike trip around S.E. Asia 2010/2011 |
| Robby |
 Robby Dirty Old Man
| A100man |
 A100man World Chat Champion
 Posted: 10:59 - 17 May 2025 Post subject: |
Took the Skorpion out for a little test ride. Got to a corner and it felt like it wanted to go straight on..
..and these things are supposed to be a model of great handling..
Checked tyre pressures - all spot on.  ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
| sickpup |
 sickpup Old Timer
| Easy-X |
| hellkat |
 hellkat Super Spammer
 Posted: 00:37 - 19 May 2025 Post subject: |
Started up the Suzuki for the first time in almost a year
(well ok, I didn't - my ex did, one of his chores whilst doing my front garden gate )
Took a while and some jump leads, but I think he flooded the engine cos the choke is a bit emotional.
But when he finally got it started, petrol started pissing out the side So we switched it off in rather a hurry.
Not sure if this is something to do with flooding the engine, but I think I will get the bike shop to pick it up, rather than risk having it blow up in a fireball when I fill it up at the petrol station  ____________________ Not nearly as interesting in real life. |
| Easy-X |
 Posted: 10:24 - 19 May 2025 Post subject: |
If it runs carbs the floats are probably stuck. Magicians tap the carb bowls with a screwdriver and presto-bongo! the leak stops  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| to v or not to v |
| A100man |
 Posted: 12:15 - 19 May 2025 Post subject: |
| Easy-X wrote: | If it runs carbs the floats are probably stuck. Magicians tap the carb bowls with a screwdriver and presto-bongo! the leak stops  |
This is worth a try (assuming one or more is overflowing) but if its one of the middle ones tappety tap access might be tricky.
PS Ex needs dumping again if not aware of this trick. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| blurredman |
 Posted: 14:54 - 19 May 2025 Post subject: |
If it is running reasonably enough, you can also turn off the petrol tap and only turn it back on when the bike is struggling for fuel- then when it starts overflowing turn the tap off again. Sometimes that clears up float hangs - may require a few cycles. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
| Grumpy Grandad |
 Grumpy Grandad Two Stroke Sniffer
 Posted: 17:41 - 19 May 2025 Post subject: |
Thought I'd start trying to get some large dents out of my 550s Fuel Tank by pressurising it with a foot pump.
Dont panic I didn't blow the seams, didn't get that far!
Managed to drop a large bolt into the tank
Learnt the Tank has a lip on the inside so you can't simply turn it upside down and shake it ..... Now fishing with a magnet on a bit of string!
Cheers  ____________________ Life may begin at 30, but it doesn't get interesting until about 75 mph. |
| panrider_uk |
 panrider_uk World Chat Champion
 Posted: 13:32 - 20 May 2025 Post subject: |
I washed it  ____________________ Current bikes: Honda ST1100 Pan European. Moto Guzzi V85 TT Travel |
| Easy-X |
 Posted: 19:00 - 20 May 2025 Post subject: |
First MoT for the Husky. "I wish they were all as easy as this", said the MoT tester Just the customary advisory for "noisy exhaust"  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
The last post was made 1 year, 129 days ago. Instead of replying here, would creating a new thread be more useful? |
