What have you done to your bike today?
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... 58, 59, 60 ... 62, 63, 64  Next
Easy-X
PostPosted: 13:17 - 14 Dec 2025    Post subject: Reply with quote
CrypticCrud wrote:
But it would be nice, just the once, to have the option!
I always have plenty of projects bubbling away. Probably lining the shed roof with insulation board, my life is very exciting!
blurredman
PostPosted: 19:44 - 28 Dec 2025    Post subject: Reply with quote
After 10 years finally getting on and replacing some (original rock hard) seals. Will need at least one bearing though. Sad
kawakid
PostPosted: 15:40 - 29 Dec 2025    Post subject: Reply with quote
Oil change and cleaned the chain.
I've a twin and a 4.
Fullers1845
PostPosted: 16:36 - 02 Jan 2026    Post subject: Reply with quote
Helped my brother-in-law change the knackered floating front discs on his old ZZR600.
Had a test ride on it, for a 33 year old it's actually still a really, really good bike - a comfy doddle to pootle about town on, then a complete hooligan out of town Very Happy
Honda CB125F, Kawasaki ZX6R J1, 1978 Kawasaki KZ650, 1922 Sheffield-Henderson Blackburne grasstrack/sprint
blurredman
PostPosted: 10:06 - 14 Jan 2026    Post subject: Reply with quote
Saved £40 by buying a standard metal shielded 6305 instead of a 83357A-9 by carefully transferring the oil slinger/retainer ring part from old bearing. Bit of patience and careful equal retentioning/rebending of the curly parts (not sure of name) in order that the ring is retained in the machined groove properly.
Rob W
PostPosted: 10:27 - 09 Feb 2026    Post subject: Reply with quote
Quite a lot recently.
New chain and sprockets (totally cosmetic, the original set only had 2400 miles from new).
New set of Road 6's, pair of Puig chain tensioners and some decal kits from Pyramid that I think make it look a lot nicer. Also removed the spacers under the bars and raised the pegs to get it a bit more nosey and it's massively improved it IMO.
Oh, and a pair of Litelok X1's. Ever since my GSX-S was stolen outside my local Morrisons in less than 4 minutes from me leaving and coming back to it, I've never felt comfortable parking the bike out of view. Hoping if they see those wrapped round it they'll move on.
recman
PostPosted: 12:24 - 10 Feb 2026    Post subject: Reply with quote
Used the multimeter to check the battery is still receiving trickle charge from the solar charger. Kicked the tyres.
Easy-X
PostPosted: 20:03 - 28 Feb 2026    Post subject: Reply with quote
Dug out the Husky which has been gathering dust (literally) since getting the GT. Checked fluid levels, kicked the tyres, etc. Started first time on the button!
Which is more than I can say for the Old Fella's Jag: suspected glow plug module failure. Still waiting for the AA to turn up after calling them ~4pm.
Rob W
PostPosted: 21:50 - 28 Feb 2026    Post subject: Reply with quote
Took it for it's first MOT.
CrypticCrud
PostPosted: 23:40 - 28 Feb 2026    Post subject: Reply with quote
So not the 4th emergency service!
CBT - Aug24, Theory - Jun25, Mod 1 - Jul25, Mod 2 - Sep25
Kawasaki Z125 > Honda Z125 > GSX-R600 Y
CrypticCrud
PostPosted: 23:41 - 28 Feb 2026    Post subject: Reply with quote
Washed it & lubed it!
A100man
PostPosted: 01:08 - 01 Mar 2026    Post subject: Reply with quote
Err, what? Shifty
blurredman
PostPosted: 11:31 - 01 Mar 2026    Post subject: Reply with quote
Finally got the ts185 running. Running badly- but running.
panrider_uk
PostPosted: 16:10 - 16 Mar 2026    Post subject: Reply with quote
Washed the Guzzi and replaced the pannier hinge pin that dropped out.
Rob W
PostPosted: 09:29 - 30 Mar 2026    Post subject: Reply with quote
Took it to BSD and had it mapped properly.
Only made 101 at the wheel which is less than hoped but apparently the engine is healthy and that's about right, and at least now the fuelling is sorted. Certainly doesn't feel slow anyway.
blurredman
PostPosted: 12:06 - 01 Apr 2026    Post subject: Reply with quote
Fixed (just proof of concept) the air leak causing an unsteady idle.
https://i.ibb.co/23TZSnrr/Untitled.jpg
EDIT: Not fixed. Idle still tempermental.
RhynoCZ
PostPosted: 20:55 - 02 Apr 2026    Post subject: Reply with quote
The leak usually happens between the head and the carburetor. Thinking
A100man
PostPosted: 10:32 - 03 Apr 2026    Post subject: Reply with quote
Disassembled the 'new' showa USD forks for the 'prilla. I'm now faced with an alarming array of bits and bobs. Confused
blurredman
PostPosted: 10:45 - 03 Apr 2026    Post subject: Reply with quote
You mean the inlet? If so: Yes I can see minute cracks on the clamping section. But the screw top was definately letting something in. Skipping threads and not completely etc.
RhynoCZ
PostPosted: 12:31 - 04 Apr 2026    Post subject: Reply with quote
Yes. That is the most crucial part for proper operation. As your intake manifold is metal/not plastic nor rubber, I doubt there are any cracks directly in it, but I do believe the seals/gaskets on both ends might be worn out and that's where the air gets in. There is a simple test for this, with the engine running, spray some carb/brake cleaner (must be flammable) on suspicious spots, if the idle raises, you found your leak. I recommend carb/break cleaner, because I can be 100% sure there will be no residue afterwards + those usually do not eat rubber/plastics, unlike for instance chain cleaners. Motorcycle chains use neoprene o-rings (x-rings), not rubber.
As for the top of the carburetor, with a CV carburetor any air leak there does affect the membrane's functionality, however as your carburetor seems be a regular slide carburetor, I don't think it's that important to have it air tight there. I sure might be wrong, I only worked on USSR era slide carbs.
TL;DR: the most important part is the intake manifold and its air tightness.
blurredman
PostPosted: 15:54 - 04 Apr 2026    Post subject: Reply with quote
Yes of course. There are some tiny cracks I saw- that may or may not change/let air through with warm/cold conditions. Pretty standard really- tehre is no seal just metal on metal. Though seals to barrel is fine. Done all that stuff checking with carb cleaner etc. For now- just slapped loads of grease on the inside of inlet where carb mates- and on the outside where the cracks would follow through to. I've broken a few of these over the years over-tightening. Unfortunately the aftermarket ones are really poorly ported.
Yes- there's an o-ring in the cap to keep it air tight. Without o-ring (or on earlier bvf carbs a sort of paper gasket) idle is indeed all over teh place. Cool
to v or not to v
PostPosted: 18:15 - 04 Apr 2026    Post subject: Reply with quote
adjusted the clock. for whatever reason it hasnt kept accurate time since the bike got tucked away for the off season.
Moto Guzzi V7.
to v or not to v
PostPosted: 07:29 - 11 Apr 2026    Post subject: Reply with quote
moved the rear suspension setting from middle to stiffest. it has 5 settings.
have yet to ride the bike and see what difference it makes.
the weekend is here and its raining!
Moto Guzzi V7.
PostPosted: 18:35 - 12 Apr 2026    Post subject: Reply with quote
Triggered!
You don’t mean ‘stiffness’ you mean either preload or compression damping one presumes? You should never go to maximum on any of them unless you’ve eliminated other handling issues.
Paragraph break - I did things today too.
I changed the oil on my GSXR and fiddled with the idle on my KR1S.
to v or not to v
PostPosted: 10:05 - 13 Apr 2026    Post subject: Reply with quote
MarJay wrote:
Triggered!
maximum preload then.
i thought id try that, then try minimum, just to see what difference the two extremes make.
the bike is a bit harsh at the back end over uneven surfaces.
Moto Guzzi V7.
Page 59 of 64
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 137.12 Kb
