| Easy-X |
 Easy-X Super Spammer
 Posted: 13:17 - 14 Dec 2025 Post subject: |
| CrypticCrud wrote: | But it would be nice, just the once, to have the option! |
I always have plenty of projects bubbling away. Probably lining the shed roof with insulation board, my life is very exciting! ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| blurredman |
 Posted: 19:44 - 28 Dec 2025 Post subject: |
After 10 years finally getting on and replacing some (original rock hard) seals. Will need at least one bearing though.  ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 - 40k, 1989 MZ ETZ251 - 52k. |
| kawakid |
 kawakid World Chat Champion
| Fullers1845 |
 Fullers1845 Nova Slayer
 Posted: 16:36 - 02 Jan 2026 Post subject: |
Helped my brother-in-law change the knackered floating front discs on his old ZZR600.
Had a test ride on it, for a 33 year old it's actually still a really, really good bike - a comfy doddle to pootle about town on, then a complete hooligan out of town  ____________________ Honda CB125F, Kawasaki ZX6R J1, 1978 Kawasaki KZ650, 1922 Sheffield-Henderson Blackburne grasstrack/sprint |
| blurredman |
 Posted: 10:06 - 14 Jan 2026 Post subject: |
Saved £40 by buying a standard metal shielded 6305 instead of a 83357A-9 by carefully transferring the oil slinger/retainer ring part from old bearing. Bit of patience and careful equal retentioning/rebending of the curly parts (not sure of name) in order that the ring is retained in the machined groove properly. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
| Rob W |
 Rob W World Chat Champion
| recman |
 recman World Chat Champion
| Easy-X |
| Rob W |
| CrypticCrud |
 CrypticCrud Trackday Trickster
| CrypticCrud |
| A100man |
 A100man World Chat Champion
 Posted: 01:08 - 01 Mar 2026 Post subject: |
| CrypticCrud wrote: | Washed it & lubed it! |
Err, what?  ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| blurredman |
 Posted: 11:31 - 01 Mar 2026 Post subject: |
Finally got the ts185 running. Running badly- but running. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
| panrider_uk |
 panrider_uk World Chat Champion
| Rob W |
| blurredman |
 Posted: 12:06 - 01 Apr 2026 Post subject: |
Fixed (just proof of concept) the air leak causing an unsteady idle.
https://i.ibb.co/23TZSnrr/Untitled.jpg
EDIT: Not fixed. Idle still tempermental. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 20:55 - 02 Apr 2026 Post subject: |
The leak usually happens between the head and the carburetor.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| A100man |
 Posted: 10:32 - 03 Apr 2026 Post subject: |
Disassembled the 'new' showa USD forks for the 'prilla. I'm now faced with an alarming array of bits and bobs.  ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| blurredman |
 Posted: 10:45 - 03 Apr 2026 Post subject: |
| RhynoCZ wrote: |
The leak usually happens between the head and the carburetor.  |
You mean the inlet? If so: Yes I can see minute cracks on the clamping section. But the screw top was definately letting something in. Skipping threads and not completely etc. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
| RhynoCZ |
 Posted: 12:31 - 04 Apr 2026 Post subject: |
| blurredman wrote: | | RhynoCZ wrote: |
You mean the inlet? If so: Yes I can see minute cracks on the clamping section. But the screw top was definately letting something in. Skipping threads and not completely etc. |
Yes. That is the most crucial part for proper operation. As your intake manifold is metal/not plastic nor rubber, I doubt there are any cracks directly in it, but I do believe the seals/gaskets on both ends might be worn out and that's where the air gets in. There is a simple test for this, with the engine running, spray some carb/brake cleaner (must be flammable) on suspicious spots, if the idle raises, you found your leak. I recommend carb/break cleaner, because I can be 100% sure there will be no residue afterwards + those usually do not eat rubber/plastics, unlike for instance chain cleaners. Motorcycle chains use neoprene o-rings (x-rings), not rubber.
As for the top of the carburetor, with a CV carburetor any air leak there does affect the membrane's functionality, however as your carburetor seems be a regular slide carburetor, I don't think it's that important to have it air tight there. I sure might be wrong, I only worked on USSR era slide carbs.
TL;DR: the most important part is the intake manifold and its air tightness. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| blurredman |
 Posted: 15:54 - 04 Apr 2026 Post subject: |
Yes of course. There are some tiny cracks I saw- that may or may not change/let air through with warm/cold conditions. Pretty standard really- tehre is no seal just metal on metal. Though seals to barrel is fine. Done all that stuff checking with carb cleaner etc. For now- just slapped loads of grease on the inside of inlet where carb mates- and on the outside where the cracks would follow through to. I've broken a few of these over the years over-tightening. Unfortunately the aftermarket ones are really poorly ported.
Yes- there's an o-ring in the cap to keep it air tight. Without o-ring (or on earlier bvf carbs a sort of paper gasket) idle is indeed all over teh place.  ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
| to v or not to v |
 to v or not to v World Chat Champion
| to v or not to v |
| MarJay |
 MarJay But it's British!
| to v or not to v |
