What have you done to your bike today?
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... 60, 61, 62
to v or not to v
PostPosted: 10:14 - 21 Jul 2026    Post subject: Reply with quote
panrider_uk wrote:
Fitted the new ignition barrel to the old Pan
Thought it would be a fairly easy job.
Took two of us all day!
All electrics now working.
Shame it doesn't fire up.
Probably a blocked fuel system as it's been stood for years.
chuck a good dose of Sea foam in the tank. people tell me it works wonders.
https://seafoamworks.com/sea-foam-motor-treatment-oil-fuel-additive/
Moto Guzzi V7.
to v or not to v
PostPosted: 10:26 - 21 Jul 2026    Post subject: Reply with quote
fitted a sport air filter with an open airbox lid, and remapped the engine.
https://iili.io/CwZzzS2.jpg
Moto Guzzi V7.
thx1138
PostPosted: 16:37 - 22 Jul 2026    Post subject: Reply with quote
Spent ages riding it round block, getting off checking everything, repeating, trying to work out why i was fighting the vanvan to go straight, bars oscillating. Had a cup of tea, then Rolling Eyes realised hadn’t checked tyre pressure. It was 12psi on front, it’s usually at 19psi.
A100man
PostPosted: 20:02 - 22 Jul 2026    Post subject: Reply with quote
to v or not to v wrote:
chuck a good dose of Sea foam in the tank. Americans tell me it works wonders.
FTFY
to v or not to v
PostPosted: 20:09 - 22 Jul 2026    Post subject: Reply with quote
FTFY
even our very own Stinkwheel has recommended it to me fella.
Moto Guzzi V7.
panrider_uk
PostPosted: 15:55 - 23 Jul 2026    Post subject: Reply with quote
Nothing ventured...
panrider_uk
PostPosted: 16:03 - 23 Jul 2026    Post subject: Reply with quote
Today I did have the "new" Pan delivered and took it for a quick ride round the villages.
Silky smoooth.
PostPosted: 20:11 - 06 Aug 2026    Post subject: Reply with quote
I found the ignition switch in my American ̶d̶r̶e̶a̶m̶ ̶m̶a̶c̶h̶i̶n̶e̶ tractor had come loose so had to strip half the engine apart (slight exageration) to sort that. (why is it cool to put your ignition down by your knee?)
Went over the bike with a fine tooth comb. Left hand side panel hanging by one fixing as the other grommets had split. Brake pads not brilliant and one caliper bolt loose. Rear air suspension low. Total bodge job on the rear speaker wiring. Going to totally replace that cause Americans don't seem to understand how crimps work.
I was replacing the front pads when next door neighbors grand son came out and said my bike was beautiful. A lad of taste. Whistle He then proceeded to help me by asking all those questions you don't want to think about while you are trying to get the brake pistons to retract with a g glamp and a bit of flat bar.
Still it made his day when i sat him on it and started it. His Mum wasn't so impressed though Laughing
Triumph Trophy Launch Edition
Rob W
PostPosted: 22:05 - 08 Aug 2026    Post subject: Reply with quote
That's cool that they let him out despite being visually impaired, bless his heart.
panrider_uk
PostPosted: 02:13 - 09 Aug 2026    Post subject: Reply with quote
Took the top yoke off the old pan's forks and correctly routed the cables i got wrong a couple of weeks ago.
Also removed the heated grips controller (original Honda) and plugged them into the new pan's grips.
No heat though so I reckon I must need another wire somewhere.
PostPosted: 10:16 - 09 Aug 2026    Post subject: Reply with quote
Did you get someone to remap teh engine or did do it yourself?
Rob W
PostPosted: 15:28 - 09 Aug 2026    Post subject: Reply with quote
This was yesterday:
https://i.ibb.co/9HQTgQ5m/20260808-113714.jpg
Rolling Eyes
to v or not to v
PostPosted: 18:27 - 09 Aug 2026    Post subject: Reply with quote
sent off for a plug in device, uploaded the bikes map to it, then sent the map off to the company and they emailed a new map back a few days later which i then uploaded to the bike.
Moto Guzzi V7.
PostPosted: 20:26 - 09 Aug 2026    Post subject: Reply with quote
Would you mind sending a link. In very interested in the concept, more than actually needing it at the moment,
to v or not to v
PostPosted: 07:11 - 10 Aug 2026    Post subject: Reply with quote
i used a Guzzi specialist in Germany.
do a search for Dynojet and you will like find something that suits your chunk of iron.
https://www.daes-mototec.de/de/Motor/Mappings-Drehmomentkit/Mapping-V7/
Moto Guzzi V7.
panrider_uk
PostPosted: 14:55 - 10 Aug 2026    Post subject: Crash bars Reply with quote
Finally installed the crash bars on the Guzzi.
I't's only taken me a year to get round to it.
PostPosted: 10:16 - 11 Aug 2026    Post subject: Reply with quote
Started re wiring the saddle bags. Aftermarket lights and speakers. All works ok but they are quick release panniers yet you cant because the wires are too short. Going to source some six wire snap connectors from somewhere. Plus its basically an eyesore.
https://i.postimg.cc/bvxcfq3G/PXL-20260811-085604480.jpg
https://i.postimg.cc/KYPShmJk/PXL-20260811-085641342.jpg
blurredman
PostPosted: 11:41 - 11 Aug 2026    Post subject: Reply with quote
Been sorting this mess out. Actually, after wire wheeling down absolutely nothing wrong with the metal.
https://www.bikechatforums.com/download.php?id=107387
A100man
PostPosted: 16:33 - 11 Aug 2026    Post subject: Reply with quote
I think we now need to ee an 'after'..!
Easy-X
PostPosted: 18:17 - 11 Aug 2026    Post subject: Reply with quote
The Old Fella seems happy with the progress on his Harley Breakout. The brake light now behaves and I've re-tuned the engine, he says it runs much better now.
The only fly in the ointment is one of the forks leaking a bit. Dismantle, clean, main seal and dust seal and new oil I suppose, annoying given we already did all that a few years ago.
blurredman
PostPosted: 10:33 - 12 Aug 2026    Post subject: Reply with quote
Here. Pitted. But claned up nicely and painted.
PostPosted: 21:57 - 12 Aug 2026    Post subject: Reply with quote
Keys. My American tractor only came with one key. OK, I thought, just get a couple cut.
Ist attempt Timpsons - No mate, no blanks like that. Bugger. But I suppose some random American lock set so went searching and you can get Victory key blanks from China. 5 for £15. Ok bought.
Went back to Timpsons said here's a blank. Oh no mate, company policy, only cut our own blanks. But you don't have a blank. I know but i can't cut them. Fucks sake.
So looked for a local interdependent and found one in Bletchley. Little old man (older than me). Shop an utter tip. Key machine was probably on the ark. Oh, Yamaha blank will fit, he says then proceeds to cut a key. £10. I get home and try it. It works in the panniers, it opens the fuel cap but the ignition works but is very tight, too tight. The last thing I want to do is break a key in the lock.
So I look for another independent and find one in Stoney Stratford. I go there and its clean, smart etc. Show the bloke what I want and tell him i have a proper blank. No problem, come back in 20 minutes. So after a cup of tea I go back. Here you are Sir, your master and the new one. That will be £25 please Shocked . Don't do that to an old man with a dicky heart. So paid, got home and Dance! all fits properly. So now I have 2 and a half keys. I'll have a play with a file tomorrow and see if I can get the other key to fit better.
What a palaver.....
PostPosted: 09:53 - 13 Aug 2026    Post subject: Reply with quote
So this morning, after using bluetac to imprint the keys like I saw on mission impossible, I played around with needle files till it was as close as i could get to the original. It's actually better now. It operates without the worry of braking off so that a win in my view, 3rd choice key for emergencies.
I do wonder what keys are made of though, the silver ones. It's so soft my cheap and nasty needle files cut through it like butter.
Edited to add. I see on ebay cheap Chinese key cutting machines available for about £125. If I cut five keys thats paid for itself. I'm tempted to get one just for the lols.
Page 62 of 62
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.8 - MySQL Queries: 13 - Page Size: 127.01 Kb
