| jeffyjeff |
 jeffyjeff World Chat Champion
 Posted: 19:09 - 12 Jun 2026 Post subject: YBR ESD Power Loss |
12 June 2026
https://live.staticflickr.com/65535/54575078048_e81c6eccd1.jpg
2015 YBR125 ESD purchased new (old dealer stock) in 2019, 23100 km on the odometer. The ESD model has a carbureted engine (Mikuni BS25) sold primarily, dare I say, in the third world. The Pakistani YBRs are ESD models as are YBRs sold in Central and South America, to my knowledge. No electro-mechanical issues other than a TPS replaced at 20800 km. The bike is well-maintained (over-maintained to be honest) and runs better than it did when new…up until yesterday.
I was riding on Moroccan highway N6. It was 35 degrees C, and I was about 60 km into my trip and riding at 80 kph. Several km after turning the fuel tap to "reserve", the bike suddenly lost all power. To wit: instantaneous loss of throttle response and uncontrolled deceleration. After slowing to around 60 kph, the power magically returned. I kept riding, and after an uneventful 10 km, I started to think, "maybe that was just a little hiccup, nothing to be too concerned over." Then it happened again. No hesitation, no stumbling, nothing to indicate that the carburetor was starving for fuel; just an immediate loss of throttle and resulting deceleration. I thought "ignition power loss," but then I noticed my high-beam indicator illuminated even as the bike was in the state of power loss. As I slowed, the power immediately returned when I downshifted from 5th to 4th. Well that's odd. The glitch recurred 3 times over a 12 km stretch, and each time I was able to recover power by downshifting, except the last time required two downshifts to third before power returned. Six uneventful kilometers to the petrol station, where I filled the tank. I rode twenty-eight kilometers to home (after filling up) without any recurrence whatsoever. I had the fuel tap on reserve most of the way to see if that might be a contributing factor.
The instantaneous onset of power loss suggests ignition system failure, but it is odd that downshifting the transmission could bring about such an immediate return of power; coincidence? Maybe, but I have never experienced a repeatable coincidence like that.
I would normally dismiss the fuel system as the cause due to the split-second onset of symptoms, but it is hard to ignore that the problem manifested shortly after turning to "reserve", and only occurred when the engine was drawing fuel on the reserve standpipe.
I'm in Morocco until September. When I return, I'll probably have a spare fuel cock and an extra ignition coil in my bag. In the meantime, I intend to keep the fuel tap in the reserve position to see if that makes a difference. I checked the fuel filter (part of the petcock) and it was unobstructed. Once I run the tank down to less than 5 liters, maybe I'll drain it and remove/inspect the petcock. Specifically, I will be looking for a crack, hole, or damage to the shorter standpipe.
If anyone can suggest actions or observations I might make in the meantime, I'm all ears.
Thanks for reading. ____________________ History shows again and again how nature points out the folly of men. BOC
Getting old ain't for wimps. R.S. Hain |
| stinkwheel |
 Posted: 20:51 - 12 Jun 2026 Post subject: |
Well, a fuel tap obstruction seems possible.
Or even vapour locking in that kind of heat with a prolonged ride (fuel in the float bowl boiling). Especially with a small amount of fuel in the tank to get heated up. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jeffyjeff |
 Posted: 19:36 - 17 Jun 2026 Post subject: |
| stinkwheel wrote: | ...Or even vapour locking in that kind of heat with a prolonged ride (fuel in the float bowl boiling). Especially with a small amount of fuel in the tank to get heated up. |
Thanks for that idea. I had not considered vapor lock, last week the temperature around here got up into the low 40's and the bike performed normally (albeit with a little more fuel in the tank.) I spent part of 1976 in Arizona, and vapor lock was a common occurrence on some of the military vehicles we had in our fleet. Similar to fuel starvation, vapor lock would make the engine falter before stalling out altogether.
I did drain the carburetor, and found 5 or six small (<1mm) water droplets in the fuel. Morocco had an unusually wet winter this year. I'm wondering if maybe some water momentarily obstructed the main jet, and when I down-shifted the increase in vacuum caused the water to pass. Probably a little far fetched as theories go, but worthy of further investigation, I suppose. I intend to drain the tank, or at least measure rate of flow on the fuel tap normal and reserve positions. I will carefully inspect the fuel for water inclusion, especially from the reserve tap. Being in a rural area here, there is no fuel line available in the nearest village, and that has delayed me so far.
I also took a peek under the tank where the coil resides. It is covered in dust and the mounting bolts look a little rusty. I'll probably remove it for a good physical inspection and clean up of contacts and mounting points. It also occurred to me to inspect the magnetic pickup and circuit connections to the ecm.
This is a relatively remote area, and I really don't want to risk the bike taking a big shit miles from nowhere. Once i poke around a little bit, I'll feel a little better about venturing further afield. Hopefully I'll find something out of the ordinary. ____________________ History shows again and again how nature points out the folly of men. BOC
| jeffyjeff |
| WD Forte |
 WD Forte World Chat Champion
| jeffyjeff |
 Posted: 22:16 - 02 Jul 2026 Post subject: |
So I took the bike out on my local test route last week, and the sudden no-power glitch manifested 4 times in 40 km under very similar environmental conditions. It happened with the fuel tap in both run and reserve positions, and in each case the power returned before I could even react; so there are two more data points. I decided to dive deeper into the ignition system, and was surprised at the apparent condition of the wiring upon removal of the fuel tank. Much of the harness was spotted with a kind of furry discoloration; resembling mold growth. Some of the exposed wire insulation also had dark spots. I cleaned up the harness with a damp rag and compressed air, and inspected the terminals at the accessible connectors, including the ECU and ignition coil. I removed the coil and cleaned up the spade terminal and mounting points with 400 grit sandpaper, then reinstalled and checked the spark.
I was surprised to observe a really weak spark. It was indeed a blue spark, but it was really small, a micro-spark that appeared to dance around the spark plug center electrode. I removed the coil once again and checked primary and secondary winding resistance against the manual specs.
My coil measured 0.9 ohms on the primary, and 7.84 k ohms on the secondary.
https://live.staticflickr.com/65535/55371031618_cd48e2f3c2_c.jpg
My coil has a single spade, like those on the 2005-06 YBRs and all XT models. As stated earlier, mine is a 2015 YBR ESD model, an orphan (at least in terms of available technical information), so I'm really not sure if my readings are out of spec or not.
On a hunch, I went down to my local hardware guy, who sold me a Chinese coil for a Honda GB125 (less than 5 quid!) that matched my OE coil dimensions exactly. It also matched my OE coil ohm readings exactly. I mounted it and found, unsurprisingly, no change in my weak spark condition.
Then I remembered that last year I had replaced the spark plug. My YBR takes an NGK CR6HSA spark plug. Last year, I found a set of four at an attractive price off Ebay. Oddly, they came in a Honda branded box (probably for a Honda inline four of some sort), but I really wasn't concerned about that much at the time.
https://live.staticflickr.com/65535/55370983643_3482b79398.jpg
I checked the spark on a used OE NGK plug and voila! The spark strength returned to about 80% of what I expected. I reassembled the motorcycle, and today I took it for a 60 km test ride with no recurrence of the issue.
So now my suspicions are focused on the spark plug. Perhaps I unintentionally installed a resistor type spark plug into a resistor type spark plug cap. Or perhaps I unknowingly obtained counterfeit NGK spark plugs that do not perform up to standard. Maybe both.
At any rate, that is where things stand today. Time will tell if the abnormal operation has been repaired permanently or temporarily. ____________________ History shows again and again how nature points out the folly of men. BOC
| WD Forte |
| jeffyjeff |
| twowheelwonde... |
 twowheelwonde... Derestricted Danger
| jeffyjeff |
 Posted: 15:04 - 25 Sep 2026 Post subject: |
UPDATE 25 SEP 26: I now have ridden the bike 1361 km since the power loss incident without recurrence. I recently performed the 24000 km service, which includes a valve lash check and adjust. Valve lash was within Yamaha specification. I opened the petcock to drain the tank, then tried to invert the tank to remove all remaining fuel. Unfortunately, the steel cup (with the fuel nozzle restrictor hole) prevented the unusable volume from completely draining out. I could have removed the petcock but was not inclined to do so. Peering inside with a torch, I did not find any debris in the tank. This whole ordeal has made me hypersensitive to consistent smoothness of engine operation, and I have experienced an occasional hiccup that, prior to June 12, I would not have given a second thought. These instances are rare, however, the last one occurring 540 km ago. I am inclined to believe that the coil and spark plug change has done more to alleviate the condition than anything else I have done. The bike is running great under some fairly extreme weather conditions. In the past month, the thermometer has reached 46C in my area, and I have ridden frequently in temperatures up to 42C after filling the crankcase with Shell Helix 20W-50. ____________________ History shows again and again how nature points out the folly of men. BOC
| sickpup |
 sickpup Old Timer
| jeffyjeff |
| jaffa90 |
 jaffa90 World Chat Champion
| jeffyjeff |
| jeffyjeff |
 Posted: 13:04 - 25 Nov 2026 Post subject: |
| jeffyjeff wrote: | UPDATE 25 SEP 26: I now have ridden the bike 1361 km since the power loss incident without recurrence. I recently performed the 24000 km service, which includes a valve lash check and adjust. Valve lash was within Yamaha specification. I opened the petcock to drain the tank, then tried to invert the tank to remove all remaining fuel. Unfortunately, the steel cup (with the fuel nozzle restrictor hole) prevented the unusable volume from completely draining out. I could have removed the petcock but was not inclined to do so. Peering inside with a torch, I did not find any debris in the tank. This whole ordeal has made me hypersensitive to consistent smoothness of engine operation, and I have experienced an occasional hiccup that, prior to June 12, I would not have given a second thought. These instances are rare, however, the last one occurring 540 km ago. I am inclined to believe that the coil and spark plug change has done more to alleviate the condition than anything else I have done. The bike is running great under some fairly extreme weather conditions. In the past month, the thermometer has reached 46C in my area, and I have ridden frequently in temperatures up to 42C after filling the crankcase with Shell Helix 20W-50. |
ANOTHER UPDATE: Only a few hundred kilometers since this overconfident post, and now the problem has returned with a vengence. Once again, 80 kph - 6600 rpm, total loss of throttle response and uncontrolled deceleration...exactly the same symptoms as occurred on 12 June 2026, only this time on a cool November afternoon. It happened six times on two rides over a two day period. Here is the interesting part: I have determined that it is not the downshift that restores my throttle response when this happens, but rather the clutch action. On the last four consecutive occurrences, I was able to restore normal engine operation simply by pulling and releasing the clutch lever. I have been able to confirm that my issue is not related to the side-stand switch, because that circuit is entirely independent of the clutch switch (side stand operation kills the engine when the transmission is in gear regardless the operation of the clutch switch). Apparently, my abnormal condition is ignition system related, but why? how?
My Haynes manual contains four wiring diagrams; two for the YBR and two for the XT125R. I have determined that the closest one that matches my bike is the 2005-06 YBR diagram because it is the only one that matches the 8 ECU wire connections and it indicates a single diode in the harness.
https://live.staticflickr.com/65535/55672607756_94d578793a_b.jpg
Tracing the clutch switch circuit (lower left corner) there is no direct or indirect connection to the ignition circuit, or the ecu for that matter. The clutch switch solely provides an alternate ground for the neutral switch in the starting circuit. I cut open the harness because I wanted to verify the number of diodes in the block. This is what I found:
https://live.staticflickr.com/65535/55672710753_e2c825044d.jpg
A single diode attached to a nylon block connector. I checked it with my meter set to the diode test position: OL in the reverse bias connection, and 0.439V forward bias. Haynes says check continuity, no specification other than that, so going by that, it appears that the diode is good.
AI says that the most common diode failure is to fail short circuit (conduct current in both directions). Could that be happening? What if my diode is intermittently failing short circuit? I traced out the clutch switch circuit to see what might happen if the diode failed- short, and indeed there is a connection to the ECU albeit through the neutral light filiment and the failed diode.
https://live.staticflickr.com/65535/55673018030_914fe09fef_b.jpg
So I'm thinking maybe I'll swap out the diode for a new one, but it will take awhile for me to source one and get it here. In the meantime, I intend to reassemble the bike and keep on riding. If the ignition loss happens again, i"ll keep a close eye on the neutral light when I operate the clutch lever. If I notice a blip on the neutral light, that would (in my mind) support my hypothesis.
I suppose this all sounds a little far-fetched; I swear I'm not making it up. If anyone on this forum has a comment or suggestion, I'd like to hear it. Thanks. ____________________ History shows again and again how nature points out the folly of men. BOC
| Rob Fzs |
 Rob Fzs World Chat Champion
| jeffyjeff |
 Posted: 13:24 - 25 Nov 2026 Post subject: |
I've seized enough two strokes to know a seized engine when I see one no, this is definitely not that. Bypassing the clutch switch might allow the starter to engage a running engine if the start switch were to be accidentally bumped while riding.
no, this is different. ____________________ History shows again and again how nature points out the folly of men. BOC
| Rob Fzs |
| Easy-X |
 Easy-X Super Spammer
 Posted: 12:52 - 26 Nov 2026 Post subject: |
I don't think replacing the diode is going to do much. Looking at the wiring diagram...
1) If you removed the diode you could only start the bike by pulling in the clutch
2) If you bypassed the diode then the neutral light would come on when you pulled the clutch (but you should still be able to start the bike with either neutral engaged or the clutch pulled in)
Other than that, the clutch switch only offers an alternative ground path for the starter relay (which you stated already).
If pulling the clutch in is "restoring power" then either there's some wiring issue and the clutch switch is shorting something else to ground (other than the starter relay) or taking the load off the engine is what's having the real impact.
Some other things to bear in mind. Calling it an "ECU" is a bit generous as there's no control over fuelling via an injector. The unit controls timing (VR crank sensor input, coil output), provides a tacho output and controls the headlight. It's more like a smart transistorised ignition unit with a couple of extra features.
Depending on how smart the ECU is, it will have various ignition timing modes (acceleration, deceleration, starting) and it calculates which mode to be in from the crank position sensor. The problem here is separating out whether this is an electrical problem, a fuelling problem, or something else.
Given this is a carb engine, the amount of fuel and air drawn into the engine is dictated entirely by engine speed and how far the carb slide is open, the ECU only dictates timing of the spark. If one were to disrupt spark timing while still drawing in the same amount of air and fuel, I would expect misfiring and spluttering rather than a smooth loss of power  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| jeffyjeff |
 Posted: 20:42 - 26 Nov 2026 Post subject: |
Thank you, Easy-X, for your thoughtful, logical comments. You're right that the term "ECU" is a bit of a misnomer, I only use it because that is how it is identified on the wiring diagram.
Due to the instantaneous onset of power loss and the restoral of throttle response via clutch operation, I tend to lean toward the abnormal engine operation being electrical in nature. Point well-taken that it could be a fueling issue or something else, but the symptoms suggest to me that if the cause is not electrical in nature, then it is probably "something else".
As stated earlier, my bike is an orphan, and I am not entirely sure that the diagram I am following accurately represents the electrical system on my bike. My carburetor has a throttle position sensor on it, although nowhere to be seen on the diagram. So the ECU has the TPS and the crank position sensor to compute spark timing, and one output to the ignition coil. How the clutch switch figures into the equation is anyone's guess. It might well be necessary to do a little exploratory surgery on the wiring harness to see if there is evidence of errant electrical contact (or ground) between circuits.
Compounding my problem is my travel schedule this year, which will prevent me from focusing on the issue in a way that might result in a speedy solution.
I think, to begin with, I am going to remove the diode and continue riding. If/when the power loss returns, the bike's response to clutch operation will indicate which side of the diode to focus my diagnostic attention. If clutch operation continues to restore throttle response, then the clutch switch is abnormally affecting one of the ECU inputs, power, or ground. If clutch operation fails to restore throttle response, that would suggest that the diode is integral to power recovery when the symptoms manifest. Hopefully, if I can determine why the clutch operation is restoring throttle response, it might lead me to the source cause of the power loss. At least that is something I can do now without violating the wiring harness too much. ____________________ History shows again and again how nature points out the folly of men. BOC
| Easy-X |
 Posted: 11:47 - 27 Nov 2026 Post subject: |
TPS? Definitely worth mapping out at least some of the loom. A torturous process of "is that white with a red stripe or brown?" Hope you're not colour blind  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| jeffyjeff |
 Posted: 13:48 - 27 Nov 2026 Post subject: |
Removed the diode and the first thing I noticed was no neutral light. It is clear to me that I really, really need to source an ESD wiring diagram from somewhere. The ESD models are/were sold in Pakistan, Central and South America; I may be able to find a diagram in Urdu, Spanish, or Chinese. An hour internet search this morning turned up nothing, but there has to be a diagram out there somewhere.
The motor started right up, even without the diode, so I took the bike out to see if an open diode connection might affect some other aspect of engine operation. The motor ran normally and accelerated smartly away, but within 2 kilometers, the power loss returned. As before, clutch lever action returned the motor to normal operation. But abnormal operation is happening much more frequently now, in just 4 km, the power loss happened 3 times.
Before I molest the harness, I am going to go through and verify all the ground points. I count 17 ground points on the Haynes diagram. I don't know why I didn't do this before. As Rod Fzs implied, I might be overlooking a very basic cause. ____________________ History shows again and again how nature points out the folly of men. BOC
| WD Forte |
| WD Forte |
