Single Sided Swingarms = how?
NSR125-Kid-UK
Attention Whore
PostPosted: 04:42 - 21 Apr 2005    Post subject: Single Sided Swingarms = how? Reply with quote
A close friend on MSN asked me (through very amusing internet art) - what keeps a single sided swingarm's wheel on?
Is it just kept on by some kind of circlip or something? i've often wondered it myself....
https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
"I'm either going to teach andy to get his knee down, or I'm going to get him killed. One of the two" - Teaman
Raccooncity
PostPosted: 04:45 - 21 Apr 2005    Post subject: Reply with quote
OTZ...................my primary school kids (or even playschool)style drawing ........
Embarassed
Thumbs Up Thumbs Up
White Noise
Mr Dudwee
PostPosted: 08:25 - 21 Apr 2005    Post subject: Reply with quote
There are big F off bolts, but that is only on a VFR that i have been up close to, from memory i think some bikes have just one nut that it done up very tight with a split pin or similar to keep it on the bolt
WN
RealNinja
PostPosted: 09:34 - 21 Apr 2005    Post subject: Reply with quote
I used to own a VFR
The VFR's are very similar to the way a cars wheel is held on, four or five big bolts and the sprocket stays attached to the swinging arm when you take the wheel off. Only problem with the 750/800 VFR's is that you have to take the exhaust off too, cos it's in the way Rolling Eyes
The smaller VFR's have the exhaust routed the same side as the sprocket so you can just undo the bolts
Don't know about anything else though.....
You will become my force of retribution. Where you tread, doom will follow. Go now and claim your destiny
killa
Won't Shut Up
PostPosted: 09:38 - 21 Apr 2005    Post subject: Reply with quote
Yeah generally manufacturers will put a big nut on to keep the wheel in place.
(This could join that petrol pump post the other day) Wink Thumbs Up
mchaggis
PostPosted: 11:26 - 21 Apr 2005    Post subject: Reply with quote
https://www.wemoto.com/library/honda-vfr400rl-1991/honda-vfr400rl-1991-rewh.jpg
A big nut holding the wheel onto a stub axle, with bearings between the wheel and axle to allow it to spin. (I assume anyway.)
I must not be a troll...
Mmmm, Guinness
Bendy
Mrs Sensible
PostPosted: 11:44 - 21 Apr 2005    Post subject: Reply with quote
It would be a 36mm nut. Done up to something like 160nm.
Halfords don't sell 36mm sockets. They sell 34 and 38, but not 36.
My torque wrench goes up to about 80nm.
You may have realised by now that removing the rear wheel from Luke's VFR on Saturday didn't go terribly well. Mr. Green
MementoMori
PostPosted: 12:17 - 21 Apr 2005    Post subject: Reply with quote
My RS has three bolts and a conspicuous looking hole that looks like something should be in it.
The tiger who came for a pint
EuropeanNC30R...
Gay Hairdresser
PostPosted: 12:37 - 21 Apr 2005    Post subject: Reply with quote
Believe it's 120Nm, and my torque wrench only goes to 60Nm Crying or Very sad
Stew
If it's good enough for top race teams...
PostPosted: 12:52 - 21 Apr 2005    Post subject: Reply with quote
I'm pretty certain I got my 36mm socket from halfords. Confused
The spanner for the bolt on the other side (think it was a 42mm) was a bit harder to find.
"Unlike public school you don't need to have your arse up and your head down to go a long way...."
mchaggis
PostPosted: 12:59 - 21 Apr 2005    Post subject: Reply with quote
It looks as though yours has a wheel on a hub held onto the axle by a nut (somewhere). Taper roller bearings mean that a single nut can be used to hold them on and they can still rotate.
See the attached picture for how the taper roller bearings work. The bearings and the space between the outer dust cover and the lip seal at the other end is normally filled with grease.
Mmmm, Guinness
steveh
PostPosted: 13:08 - 21 Apr 2005    Post subject: Reply with quote
Mopeds are a circlip, not sure on bigger bikes, all mine have been normal swing arms.
Steve.
Bendy
Mrs Sensible
PostPosted: 13:11 - 21 Apr 2005    Post subject: Reply with quote
Oh dear.
I don't think Luke's planned that far ahead. Laughing
Stew
PostPosted: 13:27 - 21 Apr 2005    Post subject: Reply with quote
The big nut is only really removed if the entire eccentric hub needs to be taken apart, no need if its just to remove the wheel. Smile
Bendy
Mrs Sensible
PostPosted: 13:30 - 21 Apr 2005    Post subject: Reply with quote
Cos it currently has a wet rear and a road front. Laughing
hawkeye
PostPosted: 14:02 - 21 Apr 2005    Post subject: Reply with quote
Theres a split pin through the nut holding it in place. All the race derived Honda single swingers use a single big nut, with the road biased ones (VFR750F/VFR800F) using 4 smaller bolts into the hub.
'89 R/W/B NC30
'The car in front is... in my way'
PostPosted: 14:11 - 21 Apr 2005    Post subject: Reply with quote
Think I managed to get one from Halfords, but I think it was an impact socket (matt black finish, hefty sides). Failing that try your local Partco as I picked one up there are well (the impact one had too thick sides to fit in the space available).
The RS 50 has a hole in the centre of the wheel to allow you to stick it on a machine to balance it. The bearings are just normal ball bearings.
mchaggis
PostPosted: 16:38 - 21 Apr 2005    Post subject: Reply with quote
Just normal rather deep groove bearings? Confused
Mmmm, Guinness
v4forlife
PostPosted: 16:45 - 21 Apr 2005    Post subject: Reply with quote
as said, on my nc30, its a big 36mm nut with a spacer things, and all the running gear(discs, calipers and sprockets) are kept on the swingarm
five 'spikes' slide into locating holes on the backside of the wheel and then the spacer goes on and then the nut
ot, i dunno if any other nc30 owners feel this way, but when im holding a 1/2 inch torque wrench with a 36mm socket head on, i feel like a real man
www.wilcollinsphoto.co.uk
Stew
PostPosted: 17:27 - 21 Apr 2005    Post subject: Reply with quote
I tend to feel like a man most of the time. Razz (maybe not a real one)
PostPosted: 17:46 - 21 Apr 2005    Post subject: Reply with quote
Just the same as normal bike wheel bearings (although a decent size).
MementoMori
PostPosted: 19:32 - 21 Apr 2005    Post subject: Reply with quote
Don't wish to hijack this thread with stuff about my own bike but this is the hole I was talking about.
I have no idea what it does. Can anyone tell me what it's there for?
Thanks.
Stew
PostPosted: 20:16 - 21 Apr 2005    Post subject: Reply with quote
Don't you insert a bar of some kind into the hole then loosen two bolts at the back of the swingarm. Then as you move the bike forward it adjust the chain tension or something? I could be wrong but I'm sure it was mentioned not too long ago somewhere.
PostPosted: 20:33 - 21 Apr 2005    Post subject: Reply with quote
Stew is right. It is for adjusting the chain.
PostPosted: 20:47 - 21 Apr 2005    Post subject: Reply with quote
My bike has a 46mm nut! Mr. Green
The socket I use has Triumph engraved upon it! Cool
The wheel can be removed without the brake disc, brake, hub, or axle being removed, and with a high level exhaust (which I have) I can change the wheel in two minutes! Smile
And there is no poncing about with wheel alignment! Smile
The last post was made 21 years, 163 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 131.1 Kb
