NSR Finding Neutral
JakeyC
PostPosted: 17:40 - 08 May 2005    Post subject: NSR Finding Neutral Reply with quote
on my NSR (2003) it is very hard to find neutral, is there a nack to it, or are most 125's the same, i can do it when rolling to a stop then finding it (mostly) but at a standstill its almost impossible
Suzuki
Roger
PostPosted: 17:41 - 08 May 2005    Post subject: Reply with quote
Down into 1st, and then half a tap up.
Shouldn't be too difficult.
<Simple> no I'm shaven Jon Razz
<Simple> it is a big enough hole.. I'll leave it now
Ride: 1999 Suzuki GSXR600 (yellow/black) IRC: Stats - Relationship Map
nick.h
PostPosted: 18:12 - 08 May 2005    Post subject: Reply with quote
Don't you have a neutral indicator?
As said above, tap all the way down, then lift it up a little and it will slip into neutral.
[Italjet MM5A] ll [Rieju RS1 Evolution] ll [Suzuki GS500e] ll [Suzuki GSX600F] ll [Honda CG125] ll [Pug Elyseo 125] ll [Yamaha YZF750R] ll [Yamaha Thunderace] ll [Yamaha R6] ll [Triumph 955i] ll [Hayabusa RZK3] ll [Suzuki RGV250] ll
Flip
PostPosted: 18:21 - 08 May 2005    Post subject: Reply with quote
As the others said. A gentle tap/lift otherwise you'll keep going in to 2nd. Thumbs Up
mr jamez
PostPosted: 18:31 - 08 May 2005    Post subject: Reply with quote
Sounds like you already know how to do it, but it is still fiddly. Just got to slowly increase the pressure until it pops into neutral
Revving the bike, or rolling it forward a little usualy helps.
Bomberman
PostPosted: 18:32 - 08 May 2005    Post subject: Re: NSR Finding Neutral Reply with quote
Two strokes son't like changing gear when not moving full stop mate (at least so I'm told). My TZR is the same.
dransy
PostPosted: 18:35 - 08 May 2005    Post subject: Reply with quote
if ur stood still , find the biting point off the clutch so ur bike moves forward a little bit then pop it into neutral , my rs does it aswell m8
Frost
PostPosted: 19:22 - 08 May 2005    Post subject: Reply with quote
Most bikes do it, honda's seem to do it more than most. Stop it in 1st, turn the ignition off, change to Nuetral and turn the ignition back on, goes in EVERY time if you do that.
mattsmith95
PostPosted: 21:05 - 08 May 2005    Post subject: Reply with quote
My CB250 and my 250 Rebel have the same problem, Honda's do suffer from this.
Yeti
PostPosted: 22:05 - 08 May 2005    Post subject: Reply with quote
I had the same problem occasionally on my old NSR just rev the engine a little as you are doing it seems to do the trick. a change of gearbox oil might be a suggestion as well.
Lifes a Beach!
JakeyC
PostPosted: 22:19 - 08 May 2005    Post subject: Reply with quote
got it now, i tried rolling using the biting point then popping it in, works like a treat, cheers guys Thumbs Up
tony532
PostPosted: 22:56 - 08 May 2005    Post subject: Reply with quote
as dafrostyone said
you will more than likely have to turn the engine off then turn the ignition on then select neutral
if you can select neutral at the lights i will give you five pounds
Frost
PostPosted: 00:20 - 09 May 2005    Post subject: Reply with quote
If you do come to a stop in 1st and despirately need to get into neutral without turning the ignition on and off, blip the throttle and it will go in sometimes Thumbs Up
NSR125-Kid-UK
Attention Whore
PostPosted: 10:03 - 09 May 2005    Post subject: Reply with quote
NSR can be a bit of a bitch sometimes....
It's easy enough to get into neutral, but on some examples I guess it takes a bit of arsing about.
https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
"I'm either going to teach andy to get his knee down, or I'm going to get him killed. One of the two" - Teaman
JakeyC
PostPosted: 15:31 - 12 Sep 2005    Post subject: Reply with quote
just though i would come back to this old post and say i fixed this problem and it took my girfriends dad approx 5 seconds lol i had to much clutch free play, he adjusted it from the handbars and it goes into neutral whenever and wherever (shakira Laughing ) any way it has also improved my acceleration and shockingly top speed it seems to get further through the gears before red lining! Thumbs Up hope it helps
fuzz
PostPosted: 00:41 - 13 Sep 2005    Post subject: Reply with quote
Yep, every time I found my NSR hard to click it into neutral while at a standstill I'd tighten up the clutch cable. Works every time Thumbs Up Turn the engine off though and it's no problem anyway. But then I only ever used neutral when I was getting off the bike so it didn't matter.
I can't understand how it's improved top speed though, because if you have too much free play, the clutch engages earlier in the lever movement.
The last post was made 21 years, 20 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 89.17 Kb
