Wheelies
freestyler_onli
PostPosted: 20:32 - 14 May 2005    Post subject: Wheelies Reply with quote
If you attempt them, what is your preferred way to do them- rolling start or what?? Shocked
satans_BIG_helper
PostPosted: 21:53 - 14 May 2005    Post subject: Reply with quote
Rolling IMO as its a bit hard to begin wheelying from a standstill as u wont have ya balance on the bike n that,,,
Take it easy to start with tho dont wanna flip it 1st time Cool <---- speaking from experience Embarassed
freestyler_onli
PostPosted: 12:58 - 15 May 2005    Post subject: Reply with quote
Righto ta- ill bear that in mind Cool
Dr Nick
PostPosted: 12:59 - 15 May 2005    Post subject: Reply with quote
On mine its get to 6k revs in 2nd then chop the throttle and find the balance point Thumbs Up
is that it
PostPosted: 13:04 - 15 May 2005    Post subject: Reply with quote
Definitely rolling. I have played with standing start ones, but it is a lot more complicated. Slow speed wheelies are much harder to keep going in a straight line as well.
On the GSXR, probably start at mid revs, off the throttle for a second then wack it open.
BikerBen
PostPosted: 14:35 - 15 May 2005    Post subject: Reply with quote
Can I just ask, as it does affect wheelying. I know you probably can't do this on the ZXR 400 anyway, but if I am low revs in a gear, and I like whack the throttle on, it kinda gargles and doesn't really go at all, so I have to release and do it more gradually. What would be causing this? Sorry to go off topic.
My NSR --> https://members.boards.ie/instinct/Diagonal.jpg
Now proud owner of a 1999 ZXR 400
Dr Nick
PostPosted: 14:51 - 15 May 2005    Post subject: Reply with quote
All the power in 400's is at the top of the revs, so basically its because your engine isnt powerful enough, its a bit the same with 600's, all power at the top end. Have to wait until you get a 1 litre bike for lots of low downgrunt out of a 4, or a v twin.
is that it
BikerBen
PostPosted: 15:05 - 15 May 2005    Post subject: Reply with quote
Thanks Dr Nick, so this is normal for my bike then, to not really go if I pull the throttle back fast in low revs?
The Tot
PostPosted: 15:17 - 15 May 2005    Post subject: Reply with quote
On a 12bhp 125 4 stroke - the only way is from stationary or <5mph. 1st gear, Clutch all the way in, rev to 7k and drop. It's reluctant to do it in 2nd when rolling - it will pop the front wheel up a couple of inches, but nothing too dramatic. If you've got your balance point correct, so long as you keep the throttle pinned open, you'll cover sufficient distance on the back wheel. But if the revs drop, your front will go down.
It goes without saying - WARM UP YOUR BIKE first before doing them. Doing wheelies on a cold engine with insufficient lubrication will lead in tears and a broken something or another at worst, or a rather notchy gearchange at best.
Yet to try rolling gear changes as i've yet to go on a bike >27bhp (Honda NSR)
Never argue with autism
Dr Nick
PostPosted: 15:41 - 15 May 2005    Post subject: Reply with quote
Yer it does it with mine if i crack it open at low revs, nothing happens until it gets into the higher revs then it starts to take off.
You've got to wind 400's and 600's up.
is that it
BikerBen
PostPosted: 15:49 - 15 May 2005    Post subject: Reply with quote
Thanks for the advice.
So to wheely 400's you have to drop the clutch a fair bit I take it. I saw this BCF video which was at box hill. A green and white ZXR 400 was the main focus of the video. One guy (Zim I think? In green leathers, dunno who he is) was really good at wheelying it, though he did keep going in first gear until you hear some painful high rev noise that has gone past redline lol...
Frost
PostPosted: 15:53 - 15 May 2005    Post subject: Reply with quote
If i were to crack my throttle open in top gear at 3k rpm, it would probably stall Laughing
Kram
PostPosted: 15:54 - 15 May 2005    Post subject: Reply with quote
just a side note, i'm doing small attempts at wheelies... just about get the wheel off the floor (FZR6) but you HAVE to dump the clutch? correct.
i normally cruise hand of cluthc between 2-4k revs, hold clutch to biting point, rev till about 6-8k then dump, is this right?
FS1E -> SR125 -> CB400N -> CB650 -> FZR600 Genises -> VFR400 NC21 -> CBR900RR Fireblade -> Renault Clio 1.4
tatters
Exxon Valdez
PostPosted: 15:55 - 15 May 2005    Post subject: Reply with quote
ZZR600
1st gear 5-6k revs shut then open the throttle and lean back. much easyer with a pillon on the back Twisted Evil
Dr Nick
PostPosted: 15:57 - 15 May 2005    Post subject: Reply with quote
On my Hornet it comes up off the power in 1st, or give it a big yank in 2nd and it comes up at around 6k revs, you can either chop the throttle or give it a yank, i find it comes up smoother with the yank. No clutch involved
My bikes downgeared from 15/42 to 14/45 tho Whistle
is that it
Kram
PostPosted: 15:58 - 15 May 2005    Post subject: Reply with quote
mine attempts to get up on power... but i have a holey exhaust, and it seems to lack a bit of power
Method
PostPosted: 19:03 - 15 May 2005    Post subject: Reply with quote
My GS barely lifts...
<15mph, first gear, clutch in at about 5k revs, rev it up to 8-9k revs, drop and hope. It doesnt even lift in second gear, and attempting to do a "Roll On" style where you simply drop and open the throttle simply hurts your arms a little as it pulls away. Sad
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
BikerBen
PostPosted: 19:42 - 15 May 2005    Post subject: Reply with quote
Poor Method Razz
Wait for your Clitoris dude, then you'll be laughing! Thumbs Up
Gazdaman
I did a trackday!!!
PostPosted: 13:28 - 16 May 2005    Post subject: Reply with quote
I used to find you should roll off the throttle in first, the front will dip under engine braking, as it rebounds and is on the way back up, snap the throttle open and bingo, the front wheel comes up to say hello.
This was on an MZ 125 though, and I think had quite a low first gear.
Gaz
Method
PostPosted: 15:24 - 16 May 2005    Post subject: Reply with quote
Meh, ill give it a shot when i get my bike back on the road! Smile
8316
PostPosted: 16:00 - 16 May 2005    Post subject: Reply with quote
on my gs125 i find it is impossible to get a proper wheelie up unless i rev it to 10k(the redline) anything less and it is sooo reluctant to lift up at all. thing is, it also depends how far you lean back as well. i tried it at 5mph but leant back as far as possible, and it would have carried on wheelying until i was off the back Embarassed .it was close.
i once watched a Superbike Magazine "how to wheelie" dvd. they said dont try to wheelie if you cant use the power to wheelie alone. didnt really think about us little 4stroke 125 riders! Laughing
at least my clutch is still surviving! Cool
Now own a Fireblade!! Speed Limits? Bah!
DukeRed
PostPosted: 16:15 - 16 May 2005    Post subject: Reply with quote
It seems most people do power wheelies on here but I've heard that the pro's tend to only do clutch wheelies, anyone know why?
Enjoy Life There's Plenty of Time to be Dead
https://www.janoner.com
Jon
Anyone for donuts?
PostPosted: 16:24 - 16 May 2005    Post subject: Reply with quote
power wheelies are for amateurs Razz Clutching tends to give you a lot more control over the wheelie when getting it up.
biker-bev
PostPosted: 16:46 - 16 May 2005    Post subject: Reply with quote
What is the difference??
Proud owner of a Motorhispania RX50
https://www.bikepics.com/members/bikerbev/
Jon
Anyone for donuts?
PostPosted: 17:08 - 16 May 2005    Post subject: Reply with quote
Generally I've found powering it up is unpredictable (comes up quite violently) but clutching it gives you more control as you're feeding it through the clutch.
The last post was made 21 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 130.1 Kb
