spark plugs
raps
PostPosted: 12:00 - 16 Dec 2002    Post subject: spark plugs Reply with quote
I got a NSR 125 and i need a new spark plug. Can anyone recommend one to me. Something not too expensive and lasts that extra bit longer and does wotever a spark plug does a lil better, Smile
Thanks Raps
PS, do these get really black really quick on the NSR's? Cos mine is supposed to be practically new (200km old) and when I checked it, it was as black as anything. Im thinking maybe the garage didnt check that side of the bike when i bought it!!!
andrew
Mister Road Rage
PostPosted: 12:02 - 16 Dec 2002    Post subject: Reply with quote
Well seeing as a spark plug is only gonna cost you around 7 quid is the life of it really a problem?
I change my spark plugs everytime i do an oil change which for me seems the best time to to it.
raps
PostPosted: 12:13 - 16 Dec 2002    Post subject: Reply with quote
thx andrew,
so that means that spark plugs dont usually last a long time on these nsr 125's then. Is that right?
Also what make should I buy? Is there a brand I shoudl look out for. What do you buy for your bike? What bike have u got anyways?
Kris
PostPosted: 12:52 - 16 Dec 2002    Post subject: Reply with quote
NGK
item code=BR9ECS
raps
Lastly, ive been told that the spark plug code/number is BR9ECS. Do you guys know if this is correct for a 2002 NSR 125 (import from france)
Thx Raps
Kris
PostPosted: 12:53 - 16 Dec 2002    Post subject: Reply with quote
lRolling Eyesk above
raps
PostPosted: 13:19 - 16 Dec 2002    Post subject: Reply with quote
woops sorry kris cheers Embarassed
Hex
Party Boy
PostPosted: 13:44 - 16 Dec 2002    Post subject: Reply with quote
if the plug is relativly new and in good condition (appart from been black) have you considered cleaning it with a wire brush!?
the black is a mixture of carbon and oil! I used to take my spark plug out every other week on my NS125R and clean it up!
Hex
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
Mr Lucky
PostPosted: 14:03 - 16 Dec 2002    Post subject: Reply with quote
What ever you do, don't buy any spark plug with the word 'CHAMPION' on it...
https://www.labusas.org
TiN
Pocket Tin
PostPosted: 15:22 - 16 Dec 2002    Post subject: Reply with quote
/me digs out classic visual reference:
https://www.tin3d.com/images/sparkplugs.jpg
Is it sooty black, or oily black?...in most cases, you can probably get away with just cleaning the plug rather than buying a new one, and spend your money on getting a qualified mechanic (oxymoron?...or maybe just moron Razz) to see what's wrong with your bike. It could just be a case of using too much choke in the morning...
TiN
dotgems.net
Doddmaster
PostPosted: 16:59 - 16 Dec 2002    Post subject: Reply with quote
Try a B9ECS, it might make the bike marginally quicker
Scooby
Scrappy Doo
PostPosted: 18:33 - 16 Dec 2002    Post subject: Reply with quote
Don't clean it with a wire brush coz it can take off the coating.
Robby
Dirty Old Man
PostPosted: 18:36 - 16 Dec 2002    Post subject: Reply with quote
a hotter plug also causes more engine wear, and oil more at lower revs. not good for town work
Hex
Party Boy
PostPosted: 20:38 - 16 Dec 2002    Post subject: Reply with quote
when I say wire brush I dont mean like one of these big nasty really hard ones Shocked
I use a copper wire brush which cleans it up with no damage. Smile
Robson
PostPosted: 11:04 - 17 Dec 2002    Post subject: Reply with quote
By the sound of it your bike is running rich which is no bad thing be worried when its running lean and you take your plug out and its bone white, to be quite honest i'd leave it as it is mate and just replace the plug regularly or you could jet down and correct the mixture giving you longer plug life and the possibility of more power (it will only be a small increase though)
hope this helps Very Happy
Paul (Robson)
Paul (Robson)
raps
PostPosted: 13:51 - 17 Dec 2002    Post subject: Reply with quote
Cheers lads,
Tin the plug looked more like "sooty black", my friend just too it out and cleaned it with a wire brush and then put it back in again. The bike started first time (previously it weren't starting at all, just making sounds as though it were gonna start but just cud not).
I was still iffy about riding it though, since i figured i would get a new spark plug and then if it conked out again i wud have something ready and handy to replace the old one.
Problem is i tried 3-4 places for this spark plug (NGK BR9ECS) and they all said its not something they keep in stock and have to order it.
So i sit and wait, driving my car instead, rather be on the bike to be honest.
Anyways Thanks
Raps
Robby
Dirty Old Man
PostPosted: 13:54 - 17 Dec 2002    Post subject: Reply with quote
can you get iridium spark plugs for the NSR? these might stay a bit cleaner.
Robson
PostPosted: 14:03 - 17 Dec 2002    Post subject: Reply with quote
Alright mate your not confined to having to use the B9ECS take your old plug to a shop/garage and they will give you the equivilent plug or an alternative
Hope this helps mate Wink
PaulR
PostPosted: 16:13 - 17 Dec 2002    Post subject: Reply with quote
Doubt an Iridium plug would stay clean for longer, just cost a fortune more to replace (think they are around £12 each the last time I asked)
If you are using the bike round town then maybe use a B8 plug. The number is the heat range the plug works in, with lower number being "hotter" plugs to work in a colder engine (thats logic for you......). A lower number will result in a higher temp in the combustion chamber and will make the plug less likely to foul up. However it is possible that it will cause problems (possibly engine damage such as a hole burnt in the piston) if the bike is thrashed with that plug in place.
Honda specify a BR9ECS plug, or a BR10ES plug for extended high speed riding. From that I would guess that you could use a BR9ES plug without any real problems, and these should be easy to find
If you want to know how the NGK plug names can be decoded:-
https://www.in.net/~eholman/ngkplugs.html
The last post was made 23 years, 89 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 98.65 Kb
