| steve8137 |
 steve8137 Two Stroke Sniffer
| Andy C |
 Andy C Tree Seeking Missile
| steve8137 |
| Andy C |
 Posted: 18:36 - 06 Jun 2005 Post subject: |
as you can buy them in stainless steel which doesnt rust! arrows are mild steel and do, i havnt been out on the road but acording to the site says 0-60 6.4 secs, i think i will check this as seems quite quick!!and does about 102ish real speed tops i think, maybe a little more but will be checking all this a week today when im 17! im from brighton (ish) when you buy it?you on the road with it?your first bike? ____________________ 99 RS125 --> 02 SV650s --> 03 Speed Four --> 92 RXS100 --> 93 CB400sf --> 01 CB600f Hornet |
| steve8137 |
 Posted: 19:03 - 06 Jun 2005 Post subject: |
What needs to be done depends on who restricted it. Proper way of doing it is to leave off the control unit, solonoid , cable and power valve, and just put a blanking piece in place of the power valve. Common bodge way of restricting one is to just disconnect the wires to the solonoid. Difference is the first means buying hundreds of pounds worth of parts to derestrict, the other just means connecting the wires (and probably a fair amount of effort to get the valve out and clean up so that it moves again). Between these extremes you may find only a few bits removed.
The cdi "restriction" does nothing to top speed at all. It is purely there to cause a flat spot between 5000 and 6000rpm (there is a massive amount of ignition retard between those revs). It isn't really a restriction, just a bodge to get the bike through various homologation tests.
| silent |
 silent Scooby Slapper
| Andy C |
The last post was made 21 years, 114 days ago. Instead of replying here, would creating a new thread be more useful? |
