| Craggles |
 Craggles Traffic Copper
 Posted: 16:38 - 28 Jun 2005 Post subject: Draining Fuel from the tank |
Hiya,
Following on from https://www.bikechatforums.com/viewtopic.php?p=562546 that thread, I've been playing with the bike.
I've checked the plugs which are fine, checked the air filter and will clean it before I put it back (although it's not overly dirty).
I feel the next step is to check the fuel filter. So I have my tank off my bike, and a petrol container. I've held the tank above the container, and turned the fuel on, yet no fuel comes out... I've tried this again with the petrol cap off to get an air flow.
Now - a) is this supposed to happen, or could this be part of the problem I'm having with the bike?
b) how do I drain the fuel?
The haynes manual says nothing
Craig ____________________ If this signature is blue, you're riding too fast |
| iCraig |
 iCraig World Chat Champion
 Posted: 17:11 - 28 Jun 2005 Post subject: |
I cheated with my 500S, I started the engine with the fuel line disconnected and put the line into a fuel container.
I left the vacuum hose on of course, so that ay when you start the engine the vacuum is created thus draining the tank.
I am sure there is a proper and safer way though!  |
| Zoffo |
 Zoffo Brolly Dolly
 Posted: 17:20 - 28 Jun 2005 Post subject: |
What's wrong with just siphoning with a tube and yer gob. It don't taste that bad. ____________________ https://hyperbikes.forumsplace.com/ |
| Will87 |
 Will87 Trackday Trickster
| pipnet11 |
 pipnet11 Brolly Dolly
| stinkwheel |
 Posted: 23:38 - 28 Jun 2005 Post subject: |
Yep, vaccuum fuel tap. Petrol won't run out without a vaccuum being applied to the tap.
What you can do is if the tank isn't all that full is to tip it over onto the right side and remove the fuel tap without any spillages since it is now at the top and sat in air. Then simply pick up the tank and pour the fuel out of the hole into your chosen container. I sat mine on its side in an old tyre I had lying about to do this last time I had to drain the tank to avoid scratching the paint.
You will need to remove the tap to clean the filter anyway. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Craggles |
| Steve H |
 Steve H World Chat Champion
| Zoffo |
 Zoffo Brolly Dolly
 Posted: 11:33 - 29 Jun 2005 Post subject: |
Ran out of barbeque fuel in France so I spent all week sucking petrol out of the bike tanks. Got pretty good at it in the end every time a fancied a cigarette it took a leap of faith  ____________________ https://hyperbikes.forumsplace.com/ |
The last post was made 21 years, 100 days ago. Instead of replying here, would creating a new thread be more useful? |
