Tick over at 4-5k !!!
thuganomics16
PostPosted: 06:26 - 27 Sep 2005    Post subject: Tick over at 4-5k !!! Reply with quote
Obviously this is not the correct amount of revs for tick over on my mito, im guessing arount 1500-2k?
Should i be thinking about adjusting the throttle cable, pilot screw in the carb or is there something else i should check for?
Also could this high tick over cause any damage in the long term?
Thanks
brown_d9
PostPosted: 08:16 - 27 Sep 2005    Post subject: Reply with quote
There will be a large screw on the side of the carb somewhere, turn it anticlockwise to decrease the idle speed.
ZaphodBeeble
PostPosted: 22:03 - 27 Sep 2005    Post subject: Reply with quote
Check that your throttle cable isnt being caught anywhere and also check that it is releasing properly. It could also be drawing in air between the carb and engine (rubber inlet manifold I expect) so check that there aren't any cracks in the pipe and make sure the screws are tight.
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
Andy C
Tree Seeking Missile
PostPosted: 22:32 - 27 Sep 2005    Post subject: Reply with quote
my RS125 idols at 1250 and that what the book says, you mito should be near if not same, very simular engine
Dweeb
PostPosted: 14:10 - 28 Sep 2005    Post subject: Reply with quote
tickover should be somewhere between 1250 and 1450, if you set it at the higher end of this , there will be less chance of the bike stalling when you have to slow suddenly or change down and stuff
ohh look , its like a real motorbike....just smaller !!
thuganomics16
PostPosted: 01:13 - 01 Oct 2005    Post subject: Reply with quote
Cheers for all your help lads, i checked the pilot screw on the carb and it didnt make any difference at all so i assumed that it must be the throttle cable getting caught...wasnt this either.
Good thinking ZaphodBeeble, i'll check for air leaks tomorrow Thumbs Up
thuganomics16
PostPosted: 12:03 - 03 Oct 2005    Post subject: Reply with quote
it seems i was too late in checking for air leaks, i wonder if someone could help me out as i may just be jumping to conlusions... the bike will now not start at all unless i run as fast as hell to bump start it, when it does finally start it is really sluggish and i have to keep the revs above 5k otherwise it dies.
Im guessing this is probably the signs of a cracked ring/piston?
Could this be the cause of the carb being modified to fit a k&n air filter rather than the original air box and there is too much air in the mixture?
I hope im wrong so if somebody else has got any other possible solutions let me know.
cheers
thuganomics16
PostPosted: 12:04 - 03 Oct 2005    Post subject: Reply with quote
cheers
thuganomics16
PostPosted: 12:47 - 03 Oct 2005    Post subject: Reply with quote
I forgot to mention the bike backfires when i try to start it
The last post was made 21 years, 22 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 61.37 Kb
