Can I ride a bike with a blown exhaust?
Major_Grooves
The Doctor
PostPosted: 23:47 - 04 Oct 2005    Post subject: Can I ride a bike with a blown exhaust? Reply with quote
As the subject asks...
I think the exhaust "blew" on the way home tonight, if that is the correct way to describe it. It has suddenly got very loud - sounds like the noise is coming from the gasket so I guess it needs replacing.
I could probably do that at the weekend, but I still need to get to and from work this week. I was kind of worried that running with a dodgy exhaust might make it run lean so seize the engine. Or is that bollocks?
I'll check this thread in the morning at breakfast so I can find out if I need to take the bus or not! Thanks for any help. Smile Thumbs Up
jayluvmito
PostPosted: 23:53 - 04 Oct 2005    Post subject: Reply with quote
bollocks to it.
ride it
Rookie
PostPosted: 23:56 - 04 Oct 2005    Post subject: Reply with quote
Are you basing that on any mechanical knowledge?? Confused
White Noise
Mr Dudwee
PostPosted: 23:57 - 04 Oct 2005    Post subject: Reply with quote
is the bike a 2-stroke?
WN
instigator
PostPosted: 23:58 - 04 Oct 2005    Post subject: Reply with quote
No, it's a 4T Honda cb500. Smile
Depends on how badly it was blowing I guess. I wouldn't use the bike if it had no exhaust system but if it was only a partial leak. Then yes, I would .
tatters
Exxon Valdez
PostPosted: 00:01 - 05 Oct 2005    Post subject: Reply with quote
really depends on how bad it is, would,nt risk it if it was a massive leak.
if its not too bad you could probley get away with it.
Beavis
PostPosted: 00:03 - 05 Oct 2005    Post subject: Reply with quote
Like Jay said - bollocks to it, just ride it.
One of the bolts that fixes through the exhaust port flange (hehe, i love that word!) on my NSR lossened off once, and apart from sounding quite loud it didnt do anything. I wouldn't ride it like that for long though, just don't thrape it and it should be ok.
Edit: Didnt realise it was a 4T. In that case just ride the bloody thing.
=chris=
=If we descended from apes, then why do we still have Monkeys?=
mchaggis
PostPosted: 00:06 - 05 Oct 2005    Post subject: Reply with quote
Check you've not shed any exhaust nuts. You can get away with a small hole/ leak, but I wouldn't leave it too long.
I must not be a troll...
Mmmm, Guinness
iCraig
PostPosted: 00:26 - 05 Oct 2005    Post subject: Reply with quote
Personally I wouldn't risk it.
As I think I may have killed an engine on a previous bike by riding it with a blowing exhaust.
Though my bike did sound like Mike Hailwoods GP Bike of the 70's when blowing!
tatters
Exxon Valdez
PostPosted: 00:30 - 05 Oct 2005    Post subject: Reply with quote
l,ve done 30-40 miles on a bike with both rear collector box gaskets blown out (bloody loud) with no problems, but it was a superdream Wink
Walloper
PostPosted: 00:37 - 05 Oct 2005    Post subject: Reply with quote
You may even get a pull from the police for it... Then the usual producer. Crying or Very sad
Klause
PostPosted: 00:39 - 05 Oct 2005    Post subject: Reply with quote
https://www.holtsauto.com/products/103.jpeg
Bodge it! Thumbs Up
Current bikes: 1960 Triumph 5ta x2, TTR600RE, KTM200EXC, Cagiva Elephant 900ie.
Robin
PostPosted: 10:44 - 05 Oct 2005    Post subject: Reply with quote
I rode my CX500 around on nearly open pipes for a while Collector box went), sounded lovely, but eventually it trashed the exhaust valves, I'd say use it gently for work, but get it fixed asap.
PostPosted: 12:57 - 05 Oct 2005    Post subject: Reply with quote
Maybe try gently nipping up the bolts if it is blowing round the exhaust manifold (dinnae shear it though!)
Check where it is blowing, exhaust gas is hot and will melt plastic bits.
Observe the result of a cracked header pipe on the coolant bottle of my mates KLR650
PostPosted: 13:01 - 05 Oct 2005    Post subject: Reply with quote
I would say ride it, just don't go for any top speed runs. It will do some damage eventually (possibly the exhaust valves as Robin mentioned, if really unlucky possibly burn a hole in a piston), but in light use for a week or so I would think you will fine.
Major_Grooves
The Doctor
PostPosted: 21:49 - 05 Oct 2005    Post subject: Reply with quote
Thanks for all the advice guys.
Bodge it! Thumbs Up
You know, I didn't actually open that picture this morning, but on the way home from work tonight, I bought that very stuff.
It's been applied, so hopefully it will hold! Praying
On a closer look it is actually a hole in the exhaust, right at the gasket. Sad
PostPosted: 22:22 - 05 Oct 2005    Post subject: Reply with quote
I rode my DR for a little with the right hand header loose - it was /very/ loud as you may expect for a big single.
Got it back on, but it actually fell off while riding at a mx track - riding it back to the van it was making a constant backfire flame coming out of the port.
(I suspect that may be less good for it Smile.
Anyway, yes, go for it.
NSR125-Kid-UK
Attention Whore
PostPosted: 00:54 - 06 Oct 2005    Post subject: Reply with quote
Don't you mean a blowing exhaust?
Blown is only ever used in the context of engines as a slang word to indicate that the engine has one or more turbos fitted Smile.
PS - in showing off my maxing knowledge, i seem to have skipped the issue at hand: I hope you fix your exhaust Smile.
https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
"I'm either going to teach andy to get his knee down, or I'm going to get him killed. One of the two" - Teaman
Kram
PostPosted: 01:06 - 06 Oct 2005    Post subject: Reply with quote
drove around for 2 weeks with one downpipe not attached (about 3cms from the engine head) no damage done (not that i can see any:S)
FS1E -> SR125 -> CB400N -> CB650 -> FZR600 Genises -> VFR400 NC21 -> CBR900RR Fireblade -> Renault Clio 1.4
PostPosted: 02:00 - 06 Oct 2005    Post subject: Reply with quote
Or the imminent state of an NSR125 engine with a race exhaust and standard jets. Laughing
bish777
PostPosted: 02:48 - 06 Oct 2005    Post subject: Reply with quote
until you can fix it properly you also may want to raise your needles a notch, richen the mix, to prevent potential melting of things.
GSXR1100J
Major_Grooves
The Doctor
PostPosted: 15:03 - 06 Oct 2005    Post subject: Reply with quote
Is there some kind of special knack to using this exhaust putty stuff?
I put it on last night after I got home from work, therefore the exhaust was still warm as the instructions suggest.
I put the stuff on the hole, then it says to either run the engine gently to cure the putty, or leave it overnight so I just left it overnight.
Next morning when I started the engine it was as loud as ever so when I looked at the putty it was blowing up in a bubble so clearly hadn't cured! By the time I got to work it had cured to form one large, but burst bubble.
So it doesn't cure overnight and just running the engine made enough pressure to "inflate" the putty so how am I suppoed to cure the stuff?
map
Mr Calendar
PostPosted: 15:30 - 06 Oct 2005    Post subject: Reply with quote
Major_Grooves wrote:
Is there some kind of special knack to using this exhaust putty stuff?..
FWIW I wouldn't just use the putty.
Get some Holts Firegum and use that first (as you said on a warm exhaust). This expands slightly (like foam) and fills any cracks and also by doing so locks itself in place. Let that go off (less tacky), then cover with exhaust putty, again as directed.
Depends on where the hole(s) are also consider a bandage and some jubilee clips (although this does look naff it works in the short term). Not always easy to bandage though as tend to go at the joints.
HTH Thumbs Up
Kram
PostPosted: 16:04 - 06 Oct 2005    Post subject: Reply with quote
if you can... stick it infront of a electric heater / hairdryer.
should cure it in aboiut an hour or so
Major_Grooves
The Doctor
PostPosted: 23:09 - 11 Oct 2005    Post subject: Reply with quote
Okay, I left it for 2 days to dry and I think it is more or less okay. It is alot less nosier, but I can still feel some exhaust gases, so there must still be a small hole.
My question now is - will it pass an MOT like that? Question Confused
The last post was made 20 years, 355 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 130.39 Kb
