| Major_Grooves |
 Major_Grooves The Doctor
 Posted: 22:47 - 04 Oct 2005 Post subject: Can I ride a bike with a blown exhaust? |
As the subject asks...
I think the exhaust "blew" on the way home tonight, if that is the correct way to describe it. It has suddenly got very loud - sounds like the noise is coming from the gasket so I guess it needs replacing.
I could probably do that at the weekend, but I still need to get to and from work this week. I was kind of worried that running with a dodgy exhaust might make it run lean so seize the engine. Or is that bollocks?
I'll check this thread in the morning at breakfast so I can find out if I need to take the bus or not! Thanks for any help.  |
| jayluvmito |
 jayluvmito Crazy Courier
| Rookie |
 Rookie World Chat Champion
 Posted: 22:56 - 04 Oct 2005 Post subject: |
Are you basing that on any mechanical knowledge??  |
| White Noise |
 White Noise Mr Dudwee
 Posted: 22:57 - 04 Oct 2005 Post subject: |
is the bike a 2-stroke?
WN ____________________ Buy my wife: 96' Yam XJ600s (Diversion)
Riding Tip #86: See God, then back off a bit: Problem is i haven't seen god yet, just a close up of tarmac on revett straight |
| instigator |
 instigator Super Spammer
 Posted: 22:58 - 04 Oct 2005 Post subject: |
No, it's a 4T Honda cb500.
Depends on how badly it was blowing I guess. I wouldn't use the bike if it had no exhaust system but if it was only a partial leak. Then yes, I would . |
| tatters |
 tatters Exxon Valdez
 Posted: 23:01 - 04 Oct 2005 Post subject: |
really depends on how bad it is, would,nt risk it if it was a massive leak.
if its not too bad you could probley get away with it. ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| Beavis |
 Beavis Borekit Bruiser
| mchaggis |
 mchaggis World Chat Champion
 Posted: 23:06 - 04 Oct 2005 Post subject: |
Check you've not shed any exhaust nuts. You can get away with a small hole/ leak, but I wouldn't leave it too long. ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush.  |
| iCraig |
 iCraig World Chat Champion
| tatters |
 Posted: 23:30 - 04 Oct 2005 Post subject: |
l,ve done 30-40 miles on a bike with both rear collector box gaskets blown out (bloody loud) with no problems, but it was a superdream  ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| Walloper |
 Walloper Super Spammer
 Posted: 23:37 - 04 Oct 2005 Post subject: |
You may even get a pull from the police for it... Then the usual producer.  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| Klause |
 Klause World Chat Champion
| Robin |
 Robin Scooby Slapper
| stinkwheel |
 Posted: 11:57 - 05 Oct 2005 Post subject: |
Maybe try gently nipping up the bolts if it is blowing round the exhaust manifold (dinnae shear it though!)
Check where it is blowing, exhaust gas is hot and will melt plastic bits.
Observe the result of a cracked header pipe on the coolant bottle of my mates KLR650 ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Kickstart |
 Kickstart The Oracle
| Major_Grooves |
| G |
 G The Voice of Reason
 Posted: 21:22 - 05 Oct 2005 Post subject: |
I rode my DR for a little with the right hand header loose - it was /very/ loud as you may expect for a big single.
Got it back on, but it actually fell off while riding at a mx track - riding it back to the van it was making a constant backfire flame coming out of the port.
(I suspect that may be less good for it .
Anyway, yes, go for it. |
| NSR125-Kid-UK |
 NSR125-Kid-UK Attention Whore
 Posted: 23:54 - 05 Oct 2005 Post subject: |
Don't you mean a blowing exhaust?
Blown is only ever used in the context of engines as a slang word to indicate that the engine has one or more turbos fitted .
PS - in showing off my maxing knowledge, i seem to have skipped the issue at hand: I hope you fix your exhaust . ____________________ https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
"I'm either going to teach andy to get his knee down, or I'm going to get him killed. One of the two" - Teaman |
| Kram |
 Kram World Chat Champion
| stinkwheel |
| bish777 |
 bish777 World Chat Champion
| Major_Grooves |
| map |
 map Mr Calendar
| Kram |
| Major_Grooves |
 Posted: 22:09 - 11 Oct 2005 Post subject: |
Okay, I left it for 2 days to dry and I think it is more or less okay. It is alot less nosier, but I can still feel some exhaust gases, so there must still be a small hole.
My question now is - will it pass an MOT like that?  |
The last post was made 21 years, 42 days ago. Instead of replying here, would creating a new thread be more useful? |
