cant get all the oil out
riichy
PostPosted: 10:51 - 07 Oct 2005    Post subject: cant get all the oil out Reply with quote
ok i have a zxr400, and wanted to do my first oil change becouse i got some super oil to put in. but got the fairing off unpluged the drain bolt, and i got less than a pint of oil out. the oil tank seemed to stay the same leve. so i but bolt back in start bike up , shut bike down take bolt out and i get the same amount again. is there somthing els i should take out, like the oil filter or somthing.
ps i was on a paddock stand when i was doing all this.
.......... PLOD ............ zx636 2004
PostPosted: 10:56 - 07 Oct 2005    Post subject: Reply with quote
take the oil filter out and change it.
Its a waste of time to just change the oil without doing the filter, because the clean oil will get dirty from all of the crap thats in the filter.
Oh, and you *Really* shouldn't run the engine after draining some of the oil...
Try changing the filter and doing it all on the sidestand. Karma
riichy
PostPosted: 11:00 - 07 Oct 2005    Post subject: Reply with quote
thnaks fella Thumbs Up
ps i only tuck a small amount of oil out and its still above half way on the oil window, pull how do you get the oil filter off. the thing is on well tight.
byke95
PostPosted: 11:09 - 07 Oct 2005    Post subject: Reply with quote
[/quote] how do you get the oil filter off. the thing is on well tight.[/quote]
Halfords sell filter grips that are pretty good and cheap. Failing that (if griping it my hand does not work) hammer a screw driver through the filter and use it as leverage (note: if this goes wrong you're in trouble).
riichy
PostPosted: 11:11 - 07 Oct 2005    Post subject: Reply with quote
thanks for the replys Karma
but still anyone know way i only got a bit of oil out........
Bendy
Mrs Sensible
PostPosted: 11:19 - 07 Oct 2005    Post subject: Reply with quote
Quite possibly because you had it on the paddock stand. I'd put it down on flat ground, on its sidestand and see if any more comes out.
Or you've undone completely the wrong bolt. Smile
Adam_P
PostPosted: 11:20 - 07 Oct 2005    Post subject: Reply with quote
Did you warm the bike up before you started taking the oil out in the first place?
Some oils are really thick before they get warmed up, so if its cold, and the weather has taken a downward turn in temperature, which doesn't help. The oil might be thick and gloopy and won't come out of the drain hole very easily.
However, you've now already taken some of the oil out, so starting it now isn't a good idea. You could put somecheap stuff in it to top it up, then warm it through I suppose.*
*I'm not a mechanic and I take no responsibility for your own actions on your own bike! Wink
Colin McRae MBE 1968 - 2007 RIP Sad
Orwell Rolls in his Grave
God is imaginary
strag
PostPosted: 12:19 - 07 Oct 2005    Post subject: Reply with quote
How much oil does it hold? There will still be some oil in the filter.
carbon bling
Andy C
Tree Seeking Missile
PostPosted: 12:24 - 07 Oct 2005    Post subject: Reply with quote
ive done it with cars and you get tons come out when you ahve ran the engine before for a while, however be carefull when you take the filter off as first time i did it i got really hot oil poured all over my hands, was not a nice feeling! never done it on bike but warming it up should help aswell.
strag
PostPosted: 13:18 - 07 Oct 2005    Post subject: Reply with quote
Have you got the filler cap off while you drain it? Air locks and all that.
carbon bling
riichy
PostPosted: 13:29 - 07 Oct 2005    Post subject: Reply with quote
ok zxr400er just told me the drain plug is on the left but i just drained oil from a right hand side blot.......... any ider what the bolt was for Embarassed
Adam_P
PostPosted: 13:38 - 07 Oct 2005    Post subject: Reply with quote
Is it the level hole? The one you leave open when you fill it up and when it reaches that level you stop?
I seemto remember that my old MT5 had one of those. Not that my mechanical expertise means I'm right though. Whistle
God is imaginary
Walloper
PostPosted: 17:13 - 07 Oct 2005    Post subject: Reply with quote
Woa big boy... Hand
Before you punch a hole in your filter.
MAKE SURE the new one is correct.....
Or you will not have much of a bike until you get the correct one. Sad
Is you are going for 'super' oil then may as well lash out and buy a OEM filter from the dealer. Smile
FILTER REMOVAL TOOL Idea
Your maw's dish towel tied in a reef knot then wound round a bar. (Jack handle 1/2 drive long socket set extension) makes a spiffing filter strap. Takes a bit of technique to work it but your a bright boy. Laughing
riichy
PostPosted: 17:22 - 07 Oct 2005    Post subject: Reply with quote
Laughing sorry people for being such a d##k, but i found out off zxr400er Thumbs Up , that i undid the wrong bolt Embarassed thats why all the oil wouldnt come out. but thanks to you lot i have a few handy tips on changing oil, thanks laids Wink Laughing
Walloper
PostPosted: 17:30 - 07 Oct 2005    Post subject: Reply with quote
Ya dauber Laughing
riichy
PostPosted: 17:33 - 07 Oct 2005    Post subject: Reply with quote
Walloper wrote:
Ya dauber Laughing
the funny thing is ,god only knows what i drain'd out Shocked
Walloper
PostPosted: 17:41 - 07 Oct 2005    Post subject: Reply with quote
Must have been the 'comzouta' fluid.
riichy
PostPosted: 17:49 - 07 Oct 2005    Post subject: Reply with quote
oil came out and the oil window went down abit, but when i strted it up again the place where i drain'd oil from filled up again, so god knows what it for.............. Confused
PostPosted: 00:17 - 08 Oct 2005    Post subject: Reply with quote
ZXR's don't have seperate gearbox oil...
... do they? Question Question Question Question
Rob W
PostPosted: 00:25 - 08 Oct 2005    Post subject: Reply with quote
I had to do the old smash a screwdriver through the filter trick when I changed mine. Where the filter is it's too tight to get a socket in there, I even tried a strap but it was on so tight it didn't budge and I couldn't even get any leverage on it anyway.
TS50 > Senda 125 > ZXR400 > CB-1 > GSX-R1000 > Bandit 600 > ZXR750 H1 > GSX-R750 SRAD > '98 RR-W Fireblade > T595 Daytona > Hornet 900 > '04 Fireblade > GSX-S1000F (x2) > '23 XSR900
Robby
Dirty Old Man
PostPosted: 02:26 - 08 Oct 2005    Post subject: Reply with quote
Do they run a hydraulic clutch?
benc
PostPosted: 04:07 - 08 Oct 2005    Post subject: Reply with quote
no hydraulic clutch and gearbox oil must have just been normal oil but a small hole or sommet must have stoped it commin out.
bugsy46
Village Idiot
PostPosted: 08:59 - 08 Oct 2005    Post subject: Reply with quote
fucking hell this thread is starting to baffle me
weve gone from answering his question on how to drop the oil to "is it the clutch fluid youv drained?"
fuck me
run the bike
find the sump
undo the biggest bolt which should be parallel to the floor
remove it and replace or clean the washer
once thats drained
remove the filter and empty it
whats hard about that?
Laura - "And where did looks come into this and bugsy leave steven alone. You are not gods gift to women you may think you are but you're not."
Keith - "All the best"
Adam_P
PostPosted: 12:29 - 08 Oct 2005    Post subject: Reply with quote
bugsy46 wrote:
run the bike
find the sump
once thats drained
Nothing, except...
He didn't run the bike up first
He didn't undo the biggest bolt
The oil didn't run out when he did undo whatever bolt he did
Wink Laughing Laughing
God is imaginary
PostPosted: 14:42 - 08 Oct 2005    Post subject: Reply with quote
fuck me
run the bike
find the sump
once thats drained
Hope you don't try that on your Mille, cos it don't work like that! Wink
The last post was made 20 years, 257 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 2.26 - MySQL Queries: 13 - Page Size: 129.68 Kb
