Plug spanner
veeeffarr
PostPosted: 13:11 - 11 Oct 2005    Post subject: Plug spanner Reply with quote
Anyone know what I can use to take out a DPR8EA-9 spark plug? My socket in my toolkit doesn't fit Sad
Jrod
Page 3 Girl
PostPosted: 13:45 - 11 Oct 2005    Post subject: Reply with quote
A plug spanner? Rolling Eyes
most car shops will sell them.
the grim reaper
PostPosted: 13:49 - 11 Oct 2005    Post subject: Reply with quote
You might be better off getting a plug socket as the vast majority of bike plugs are recessed, buy a ratchet and an extension bar too.
Grim
veeeffarr
Well I have one, but it doesn't fit... So I was wondering whether there's a specific measurement someone who has experience with these plugs could give me?
map
Mr Calendar
PostPosted: 13:56 - 11 Oct 2005    Post subject: Reply with quote
Plug spanner. From memory that's a 10mm one. If you're unsure you can get a double header one (it swivels in the middle) with the 10mm on one side and 12mm the other.
BTW the mm size refers to the size of the plug, not the size of the nut.
the grim reaper
PostPosted: 14:01 - 11 Oct 2005    Post subject: Reply with quote
I have 10mm, 12mm and a 17mm plug sockets. There maybe other sizes but these do every bike and most cars I've worked on.
Grim
Guest
PostPosted: 17:26 - 11 Oct 2005    Post subject: Reply with quote
A 'D' plug has a 12mm thread and needs an 18mm socket .... Plug codes here .......
https://www.spark-plugs.co.uk/pages/technical/ngkjpg.htm
Buy a set of plug sockets ........
https://www.spark-plugs.co.uk/graphics/images/tools/magnetic_sockets.jpg
They'll pay for themselves the first time you don't break a plug off Wink
map
Mr Calendar
PostPosted: 17:52 - 11 Oct 2005    Post subject: Reply with quote
map wrote:
...From memory that's a 10mm one...
I apologise for any confusion. Off the top of my head I was quoting for my current bike, not the old CG.
Guest wrote:
Buy a set of plug sockets ........They'll pay for themselves the first time you don't break a plug off Wink
True Thumbs Up
veeeffarr
PostPosted: 18:07 - 11 Oct 2005    Post subject: Reply with quote
Surely if it's a 12mm thread then I'll need a 12mm socket? Hmmm...
The one in my toolkit looks as though it would fit, but it's too short Sad
map
Mr Calendar
PostPosted: 18:13 - 11 Oct 2005    Post subject: Reply with quote
No. For plugs the sockets/spanners all quote the thread size. It'll be stamped on the side. The nut size that the socket/spanner actually is in order to tighten the sparkplug will not be the same (but, yes it is confusing until you get the hang of it).
Guest
PostPosted: 18:34 - 11 Oct 2005    Post subject: Reply with quote
Wot map says Thumbs Up
https://www.koken-tool.co.jp/img/products/product/clip/3300c.gif
A proper plug socket usually has a rubber bung or a bas lip inside to grip the plug and stop it falling out as you remove it. As you can see from this drawing the hexagon size is bigger than the thread size, but it's correct engineering practice to quote the thread size.
So those bolts on your bike that take a 10mm spanner are actually 6mm bolts (thread diameter)
veeeffarr
PostPosted: 18:39 - 11 Oct 2005    Post subject: Reply with quote
Aha, I see now, so on that NGK chart D - 12mm, which is the sizeof the thread? I can see why that information is more important to an engineer Smile
I understand now, just had the nut size mixed up with the thread size Smile
So an 18mm you think?
I'm not taking my plug out for any reason, just to have a gander Smile
Guest
PostPosted: 19:10 - 11 Oct 2005    Post subject: Reply with quote
You got it Thumbs Up
You can also juggle up the plug codes ..........
D8HS would be 12mm thread diameter and 12,7 mm thread length
B8HS would be 14mm thread diameter and 12,7 mm thread length
C8ES would be 10mm thread diameter and 19 mm thread length
the extra numbers and letters are just 'refinements' as you can see from the list.
The heat range number (8 in the examples above) can be a bit confusing. A lower number like 6 is a 'hotter' plug, but they're usually found in less tuned engines like old mopeds and lawnmowers. A number like 9 or 10 would be a 'colder' plug that would be found in a highly tuned engine like a racer.
It's best to stick to the proper heat range if you can. A 'cold' plug (9) in a lawnmower wouldn't work very well, and if you went the other way and put a 'hot' plug (6) in an R1 it'd probably melt and destroy the pistons.
veeeffarr
PostPosted: 19:14 - 11 Oct 2005    Post subject: Reply with quote
Well DPR8EA-9 is my plug, can only find DPR9EA-9 in Halfrauds, will order it online or something Smile
Was thinking of getting my plug out to check it against a chart I've seen on the web to see if everything's running ok.
Smile
Toby
Guest
PostPosted: 20:45 - 11 Oct 2005    Post subject: Reply with quote
You can order them on-line from this place .........
And I've heard they're pretty good.
Click on Part finder and bikes and then select your year/model. they quote £4.72 including VAT and delivery for DPR8EA-9
Never hurts to have a spare plug in the shed 'just in case'
They also do plug spanners ......
https://www.spark-plugs.co.uk/graphics/images/tools/box-wrenches.jpg
bish777
PostPosted: 21:58 - 11 Oct 2005    Post subject: Reply with quote
Or big detonation leading to the cylinder head being blasted through the headstock?
GSXR1100J
bish777
PostPosted: 22:00 - 11 Oct 2005    Post subject: Reply with quote
Smile
Toby
Going 1 colder would probably be ok.
GSXR1100J
Mark_petty
PostPosted: 09:27 - 12 Oct 2005    Post subject: Reply with quote
I use a plug spanner the one I got with the bike. I'm sure it says 22 on the end of it.
Your engine probably is the same as my Honda CLR 125 engine
[Rides: Suzuki GSF600sx]
[CBT: Passed] [Theory: Passed] [DAS: Passed]
The last post was made 20 years, 350 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.39 - MySQL Queries: 13 - Page Size: 103 Kb
