| veeeffarr |
 veeeffarr Super Spammer
 Posted: 13:11 - 11 Oct 2005 Post subject: Plug spanner |
Anyone know what I can use to take out a DPR8EA-9 spark plug? My socket in my toolkit doesn't fit  |
| Jrod |
 Jrod Page 3 Girl
 Posted: 13:45 - 11 Oct 2005 Post subject: |
A plug spanner?
most car shops will sell them. |
| the grim reaper |
 the grim reaper World Chat Champion
| veeeffarr |
| map |
 map Mr Calendar
 Posted: 13:56 - 11 Oct 2005 Post subject: |
Plug spanner. From memory that's a 10mm one. If you're unsure you can get a double header one (it swivels in the middle) with the 10mm on one side and 12mm the other.
BTW the mm size refers to the size of the plug, not the size of the nut. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| the grim reaper |
| Guest |
 Guest Brolly Dolly
| map |
 map Mr Calendar
| veeeffarr |
 Posted: 18:07 - 11 Oct 2005 Post subject: |
Surely if it's a 12mm thread then I'll need a 12mm socket? Hmmm...
The one in my toolkit looks as though it would fit, but it's too short  |
| map |
 map Mr Calendar
| Guest |
 Guest Brolly Dolly
 Posted: 18:34 - 11 Oct 2005 Post subject: |
Wot map says
https://www.koken-tool.co.jp/img/products/product/clip/3300c.gif
A proper plug socket usually has a rubber bung or a bas lip inside to grip the plug and stop it falling out as you remove it. As you can see from this drawing the hexagon size is bigger than the thread size, but it's correct engineering practice to quote the thread size.
So those bolts on your bike that take a 10mm spanner are actually 6mm bolts (thread diameter) |
| veeeffarr |
| Guest |
 Guest Brolly Dolly
 Posted: 19:10 - 11 Oct 2005 Post subject: |
You got it
You can also juggle up the plug codes ..........
D8HS would be 12mm thread diameter and 12,7 mm thread length
B8HS would be 14mm thread diameter and 12,7 mm thread length
C8ES would be 10mm thread diameter and 19 mm thread length
the extra numbers and letters are just 'refinements' as you can see from the list.
The heat range number (8 in the examples above) can be a bit confusing. A lower number like 6 is a 'hotter' plug, but they're usually found in less tuned engines like old mopeds and lawnmowers. A number like 9 or 10 would be a 'colder' plug that would be found in a highly tuned engine like a racer.
It's best to stick to the proper heat range if you can. A 'cold' plug (9) in a lawnmower wouldn't work very well, and if you went the other way and put a 'hot' plug (6) in an R1 it'd probably melt and destroy the pistons. |
| veeeffarr |
 Posted: 19:14 - 11 Oct 2005 Post subject: |
| Guest wrote: | You got it
Well DPR8EA-9 is my plug, can only find DPR9EA-9 in Halfrauds, will order it online or something
Was thinking of getting my plug out to check it against a chart I've seen on the web to see if everything's running ok.
Toby |
| Guest |
 Guest Brolly Dolly
| bish777 |
 bish777 World Chat Champion
| bish777 |
| Mark_petty |
 Mark_petty Brolly Dolly
 Posted: 09:27 - 12 Oct 2005 Post subject: |
I use a plug spanner the one I got with the bike. I'm sure it says 22 on the end of it.
Your engine probably is the same as my Honda CLR 125 engine ____________________ [Rides: Suzuki GSF600sx]
[CBT: Passed] [Theory: Passed] [DAS: Passed] |
The last post was made 20 years, 352 days ago. Instead of replying here, would creating a new thread be more useful? |
