Embarrassing!
jon p
PostPosted: 19:55 - 27 Oct 2005    Post subject: Embarrassing! Reply with quote
hi im fairly new on here and i own an aprilia rs125. and the names john if u hadnt guessed. anyway i was out my bike today, seen as it was a nice day and then i come along a mini metro. thinking i have no problem takin it seen as it said it was a 1.1. well, to my surprise the damn thing kept up.( must have been modified). i was pretty embarressed as he took over me and now i want to know how to derestrict my rs. i was told all i had to do was cut a wire on the cdi but i dont which 1 so any help would be appreciated.
cheers Embarassed
PostPosted: 20:03 - 27 Oct 2005    Post subject: Reply with quote
DO NOT cut a wire to the CDI (it was the early 1990s RG125 that was derestricted that way).
You need the power valve kit. This might be fitted and just disconnected (either the cable or the electrical connection), or might have been removed.
Latest models have pretty poor exhausts as well as standard.
riichy
PostPosted: 20:51 - 27 Oct 2005    Post subject: Reply with quote
power valve kit. sould do it.......
dont put a race can on though waste of money and make them sound crap........... Mr. Green Thumbs Up
.......... PLOD ............ zx636 2004
colin1
Captain Safety
PostPosted: 23:01 - 27 Oct 2005    Post subject: Reply with quote
yes eitehr connect your powervalve or get one fitted
i have a race exhaust and i like it. you can get them for £50 off ebay, and a high flow filter from www.cmpracing.co.uk
I wasnt sure about the sound of the race exhaust at first but I really like it now. The bike seems to breathe easier with high flow filter and race exhaust but I doubt it ads much bhp
powervalve should take you from 15bhp to 28bhp
those metros wont know what hit them
jon p
PostPosted: 00:16 - 28 Oct 2005    Post subject: Reply with quote
the bike come with a powervalve kit but its not activated. anyone know how to activate these?
colin1
Captain Safety
PostPosted: 04:02 - 28 Oct 2005    Post subject: Reply with quote
i know a bit but not enough
the bit i know, is how to fit the powervalve, but i dont know how to attach it to the servo that operates it
Near where the pipe of your exhaust goes onto the engine, there will be two allen key bolt holding in a blank plate. You need to take that out and put the blade of the power valve in. The pointiest edge of the powervalve blade needs to be nearer the back of the bike.
You push it in, and tighten the bolts. Might be good to put a bit of 2 stroke oil on the blade b4 you put it in.
The control cable that comes off the blade goes somewhere but ive no idea where.
PostPosted: 12:40 - 28 Oct 2005    Post subject: Reply with quote
Do you mean it is fitted and not working, or is off the bike?
If fitted the chances are that they have just disconnected the electrical connection for the solenoid (gold coloured cylinder on the inside of the r/h frame rail). However the chances are that if it has not been used for a while then the actual valve will have seized up. If it has they can be a pain to take apart (had to take the top end off the engine before now). Above the exhaust you will see a housing with a cable going into it. 2 allen key bolts hold it on. Undo these bolts, rotate the cable 180 degrees around the cable and then you should be able to unhook the cable. Take off the housing and cable and then try and pull the valve out. Be carefull as it is entirely possible to snap the shaft on the power valve blade. Once removed clean it up and reassemble it.
Andy C
Tree Seeking Missile
PostPosted: 14:21 - 28 Oct 2005    Post subject: Reply with quote
also does you bike have a dip in power between 5-6k rpm? if it does then you can after putting the powervalve in (as will have much more effect than doing CDI) take CDI and cut out bottom and cut a wire, make the dip go away instantly! i did my myself but took a while to do
Rob W
PostPosted: 14:34 - 28 Oct 2005    Post subject: Reply with quote
I had someone on an RS125 try and keep up with me today.
numark1
Scared of girls
PostPosted: 14:40 - 28 Oct 2005    Post subject: Reply with quote
What does the powervalve actually do?? Embarassed
NSR Mick
PostPosted: 14:44 - 28 Oct 2005    Post subject: Reply with quote
it varies when the exhaust port opens Smile
PostPosted: 15:01 - 28 Oct 2005    Post subject: Reply with quote
As above, affects the exhaust port timing and area. Effectively variable valve timing.
numark1
Scared of girls
PostPosted: 15:13 - 28 Oct 2005    Post subject: Reply with quote
Lost me even more. Laughing
ISLAND GIRL
PostPosted: 15:18 - 28 Oct 2005    Post subject: Reply with quote
why worry about overtaking stuff whilst you are still on a baby bike and riding with L plates, I assume you are?? Just wait until you get a bigger beast and know for sure that you can overtake safely.
NSR Mick
PostPosted: 15:21 - 28 Oct 2005    Post subject: Reply with quote
try here mate it might explain it better than we can
https://en.wikipedia.org/wiki/2-stroke_power_valve_system
colin1
Captain Safety
PostPosted: 15:24 - 28 Oct 2005    Post subject: Reply with quote
click here to understand it better
in particular animation at the bottom
you can skip the rest if you dont like reading
https://www.vf750fd.com/blurbs/stroke.html
the power valve opens so that the expansion champer, can redirect a pressure wave back into the combustion chamber
riichy
PostPosted: 23:58 - 28 Oct 2005    Post subject: Reply with quote
bet that lasted a long time Laughing ...............poor RS125 rider what was he thinking Mr. Green
distortion
PostPosted: 07:22 - 29 Oct 2005    Post subject: Reply with quote
Right you could go out and spend £1k on your RS125 with racing a CDi, piper cross filter, bigger carb ect but all the mod's just are not worth the money for the small (if i remember correctley) 1bhp that it will give you.
If your wanting to get the extras i'd suggest that you get the powervalve sorted, and save the rest for your full test (if you do not have it already) or a bigger bike.
JP
The last post was made 20 years, 335 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.56 - MySQL Queries: 13 - Page Size: 99.84 Kb
