n00b Chain & Sprocket Question - Dead sv
instigator
PostPosted: 19:49 - 03 Nov 2005    Post subject: n00b Chain & Sprocket Question - Dead sv Reply with quote
If you have no chain on your sprockets and start the bike up in neutral, I assume it's normal for the front sprocket to whirl round?
Also, with no chain on my Sv650, is it normal for the clutch to be very light i.e I'm not used to this kind of clutch mechanism - on the hornet, the clutch cable goes to the rhs, on the sv, it seems to be inside behind the front sprocket casing. So, if I put a new chain on, the clutch will go back to being a bit heavier, yes?
Replacing chain (looked abnormally shagged) for sale tomorrow so appreciate any tips/advice. Thumbs Up
Guest
PostPosted: 20:09 - 03 Nov 2005    Post subject: Re: n00b Chain & Sprocket Question Reply with quote
Yep, quite normal. It's the oil being dragged round by one gear shaft and tranferring the motion to the other. You often see it on bikes when they're on the centre-stand as well - means the chain and sprockets are well lubed and the brakes aren't dragging.
Chain and sprockets, or lack thereof, should have no effect on the feel of your clutch lever as they're not connected. Have you already had the sprocket cover off to remove the chain? If so, it sounds like you may have mis-set the cover and the clutch operating worm isn't meeting up with what it should. You haven't lost the clutch push-rod have you?
PostPosted: 20:27 - 03 Nov 2005    Post subject: Reply with quote
As above. Only thing I would add is that if you have had the front sprocket cover off and cheaned things up then you might have cleaned off some rubbish on the clutch push rod that was making it heavier).
Missing clutch push rod would result in the clutch being VERY light.
instigator
PostPosted: 20:52 - 03 Nov 2005    Post subject: Reply with quote
Try and decipher what that means.
Mashed clutch arm or whatever that means? Bit of metal has sheared right off.
As usual, I jump to conclusions and I hope to god I'm wrong here, but I'm assuming I need an engine to strip down and steal this part from?
Great - was selling it tomorrow too to make way for a ninja I am buying. Rolling Eyes
Middle Finger to me.
True Blue
PostPosted: 21:26 - 03 Nov 2005    Post subject: Reply with quote
Why don't you phone suzuki for a price on the part. Can't be that expensive for that? Confused
Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>>
instigator
PostPosted: 21:33 - 03 Nov 2005    Post subject: Reply with quote
I will do once I get clarification on what part I need. If it was something hefty, then it'd be best of getting a £50 engine and taking it from there as I can't imagine that part suffers from a lot of wear and tear.
Gutted for Kevin though, I will try and get it resolved asap for him, and completely understand if he doesn't want it now, as he did sound a little hesitant on the phone. I'll knock £50 off it for him (£1550) if he holds on for it (that is assuming it isn't anything major) as he did HPI it after all. Sad
Here is a clearer picture but stil crud.
True Blue
PostPosted: 21:37 - 03 Nov 2005    Post subject: Reply with quote
This guy might have the bit your after. Not sure if the 97 model is the same as yours?
Phoenix
Twisted Firestarter
PostPosted: 22:23 - 03 Nov 2005    Post subject: Reply with quote
Your pictures are toss, can't see anything that looks like it's broken.
Only thing that looks like it's missing but is hard to make out is the clutch pushrod, a long metal rod that comes out of an oil seal infront of the sprocket and sits in a worm gear on the inside of that clutch actuator mechanism bolted to the side. Now I don't see how the pushrod could've fallen out, you'd have to of taken the clutch actuator off and pulled it out (it goes into engine a good 8 inches). If it's sheared off, how did that happen? Did the chain snap?
If that's the case all you need is a new pushrod and maybe an oil seal if it's been dented by the force on the rod. You'll have to fish the remaining rod out of the hole somehow, strong magnet should do it. You might be able to get the new rod from that engine on ebay, or you can get a new one with oil seal from a suzuki parts dealer, Redcar Suzuki will sort you out. The pushrod does have to be aligned with something when it's replaced which may need to be held in place on the other side of the engine by removing clutch cover, but it may just go straight in and work fine.
True Blue
PostPosted: 22:34 - 03 Nov 2005    Post subject: Reply with quote
Yeah the chain snapped. Thumbs Up
instigator
PostPosted: 22:42 - 03 Nov 2005    Post subject: Reply with quote
Thanks for your input Phoenix and others, very much appreciated.
I will go look for the chain tomorrow if I can get to it, would be interesting to see how it failed (it was 2000 miles old and lubed every 2nd day - I've learnt my lesson from snapped chains before, once on the hornet)
True Blue
PostPosted: 22:50 - 03 Nov 2005    Post subject: Reply with quote
Where did it happen?
instigator
PostPosted: 22:56 - 03 Nov 2005    Post subject: Reply with quote
Just outside langbank, past the mini roundabout. Thing was, jsut before it I said to myself, "This time I'll be smooth with the acceleration" as the roads were 'caked' with diesel at that moment in time.
So pushed it a couple of hundred meters up to the last slip road in langbank and hired an arnold clark van and picked it up. Thumbs Up
True Blue
PostPosted: 22:57 - 03 Nov 2005    Post subject: Reply with quote
When was this? Shame I never knew, I have a LWB hightop Transit at the moment. I could have picked it up for you. Confused
Guest
PostPosted: 23:36 - 03 Nov 2005    Post subject: Re: n00b Chain & Sprocket Question Reply with quote
Ah, now if you'd said at first that the chain had snapped ....... Wink
Undo the two gold coloured bolts and pull off the clutch worm - there should be a metal rod sticking out as said by Phoenix. Part number 15 .....
https://70.85.253.252/spst/2002%20SV650,S/08.gif
It's quite easy for these to get snapped off by a flailing chain and if it's not there then the clutch lever will be very light.
instigator
PostPosted: 23:45 - 03 Nov 2005    Post subject: Reply with quote
Very helpful Guest, thank you !!! Thumbs Up Thumbs Up Just what I was after as weel, an exploded diagram.
Well, I left Uni at 12.30, and I got home at 4pm. It's a 50 minute journey. Sad
Not as bad as waiting for a recovering truck I imagine. Thumbs Up
PostPosted: 00:23 - 04 Nov 2005    Post subject: Reply with quote
Likely to be cheap from Suzuki and easy to fit.
To be honest, surprised the clutch actuating arm, etc, was not just bolted to the sprocket cover.
BanditsHigh
Worse than a woman
PostPosted: 08:15 - 04 Nov 2005    Post subject: Reply with quote
Sorry for late reply ...
Anyhoo ... if the chain snapped then what you've probably done (as I've done before) is chop the pushrod up into bits!!!!
Either buy a new one from Suzuki (Robinsons Foundry is good) or check the diameter of the rod and then go and buy a bit'o'steel from B&Q, cut it to length (make it too long and then start trimming it) and you're away.
I did mine using an old screwdriver as the donor pushrod Smile ... and it's Mr Le Bodgee to you Wink
All the best ... Barry
P.S. Available tomorrow to lend a hand/fix it, once I've fitted the new oil cooler (fifth one in two months!!!) ... dead easy to do, it'll just take a wee while to get it to the right length.
Guest
PostPosted: 08:51 - 04 Nov 2005    Post subject: Reply with quote
We are not worthy Clapping
Smile
instigator
PostPosted: 16:40 - 04 Nov 2005    Post subject: Reply with quote
£6.07 for the spare part, will update thread to let everyone know once it's fixed.
Cheers for everyone's assistance.
The last post was made 20 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 107.46 Kb
