Is bodging the future?
Are you a bodger?
I am the bodge master
37%
 37%  [ 18 ]
I do the occasional bodge
52%
 52%  [ 25 ]
Only a main dealer touches my bike you sad little bodger
10%
 10%  [ 5 ]
Total Votes : 48
superstacker
PostPosted: 15:04 - 04 Nov 2005    Post subject: Is bodging the future? Reply with quote
Do you find its much better to bodge something that doesnt fit or work? (Assuming the end result means you've saved some cash)
Or do would you never dream of a bodge job?
sanchezz_182
PostPosted: 16:20 - 04 Nov 2005    Post subject: Reply with quote
Laughing now here's a real bodger
i could sing the song, but lets not.
no sig, thats gay!!
Groove
PostPosted: 16:27 - 04 Nov 2005    Post subject: Reply with quote
bodger and badger
bodger and badger
la la la la la
la la la la la
cant really answer the poll as ive not needed to bodge anything yet *touchs wood* but if it looked as good as the real thing why not!
0ddball
PostPosted: 16:35 - 04 Nov 2005    Post subject: Reply with quote
I am very ingenious so can often come up with a good bodge but i prefer to do things properly if i can afford it.
ZXR750L
gimpy limp
PostPosted: 16:43 - 04 Nov 2005    Post subject: Reply with quote
I am the king of this, I love a good old bodgering (up the bum) I've even temporarily bodged 2 wires onto a fuse with no fuse folder and just wrapped the wire round the leg of it held on with some insulation tape that's lazy for ya lol (hmmm why am saying this like i'm proud of it) Crying or Very sad Surprised
-=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - [email protected]
https://pre-auto.com/cx500/rat_and_survival_gallery_2006
craigie b
Citizen Smith
PostPosted: 16:44 - 04 Nov 2005    Post subject: Reply with quote
SpannerMonkey wrote:
I am very ingenious
Fu(king modest c*nt to boot as well Wink Laughing
craigie b
Citizen Smith
PostPosted: 16:45 - 04 Nov 2005    Post subject: Reply with quote
I am very ingenious
PostPosted: 17:11 - 04 Nov 2005    Post subject: Reply with quote
Depends on what you call a bodge though. I think you may have a different oppinion than I do on this subject.
What I would call a bodge is a temporary repair using any materials to hand. If I used those same materials to effect a permanant repair, I would call that 'fixing my bike'.
So, temporarily stopping an oil leak round a crankcase cover by smearing hermatite then epoxy over the outside of the leak is a bodge.
Cutting out a new gasket from an old cereal packet is a fix.
Substituting proper gasket paper for cereal packet is a 'good fix'.
Getting a dealer to do it using a genuine gasket is 'pissing money against the wall'.
0ddball
PostPosted: 17:20 - 04 Nov 2005    Post subject: Reply with quote
I am very ingenious
Yep, and next time call me Sir Razz
ZXR750L
superstacker
PostPosted: 20:24 - 04 Nov 2005    Post subject: Reply with quote
This is the kind of bodge im talking about mate, one that either gets you out of trouble long enough to get home, or fixes it completely. If its cheaper then a proper repair its a bodge!
Mongrel
PostPosted: 20:31 - 04 Nov 2005    Post subject: Reply with quote
I will always do the job properly if can BUT...some of the methods are ......different shall we say Cool
Soldering wires together using Plumbers solder, flux, a blowtorch and a cold chisel springs to mind...
Or welding plastics with an old screwdriver and the aforementioned blowtorch...
Or making washers with some sheet metal and a holesaw...
All do the job but are slightly unconvetional, what I will not do is bodge badly, a nail instead of a fuse is an accident waiting to happen Sad
Andy C
Tree Seeking Missile
PostPosted: 20:57 - 04 Nov 2005    Post subject: Reply with quote
its great as every boge i do on my bike i use the tech department at my college for all the stuff! only done about 3 boges before but think if they do notice then why not!
PostPosted: 21:10 - 04 Nov 2005    Post subject: Reply with quote
I'm probably being pedantic, but by that rationale, lapping in a 2-stroke cylinder head rather than buying a head gasket would be a bodge. This is despite the engineering principles behind it being entirely sound. A bodge would be to spray the old gasket over with a rattle can then re-use it because: a) it will eventually fail and b) when it does, you wont be able to remove it again.
I suppose what I am getting at is that a bodge is a repair that either doesn't do the job quite as it should or one that you know is going to fail eventually.
If the bodged componant works as designed and proves to be reliable, it is no longer a bodge but a repair.
Teaman
PostPosted: 15:01 - 05 Nov 2005    Post subject: Reply with quote
on my old gpz i did some super bodging,
a switch to turn the fan on, numerous other bodges inc fitting a suzy bandit can to a nexus exaust system
the best bodge had to be when i was going to a lan party in kent from sheffield, I needed some way of fitting my pc case to the bike safetly, so i bodged together a rack at just the right hight to fit it on the back of my bike perfectly,
also on the way back my rear light packed in due to dodgy earth so had to cable tie my front brake slightly on so the brake light was on all the time,,
worked well , brakes were a bit worn and warm by the time i got back home but i survived.
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
PostPosted: 19:05 - 05 Nov 2005    Post subject: Reply with quote
Easier way is to overadjust the back brake light switch. It is on a screw thread, overtighten it and the brake light is on all the time without having to apply the brakes. That or pull the two wires off the front brake switch (they are spade terminals) and tape them together. Wink Thumbs Up
mchaggis
PostPosted: 19:20 - 05 Nov 2005    Post subject: Reply with quote
This definition of bodging seems to be aimed at home mechanics doing things in a way which means they don't get ripped off by the stupendous prices of official spares and dealer servicing prices. So long as your bodge isn't something which is a half-arsed attempt at a repair because you don't know what you're doing, then it makes perfect sense to repair things yourself, using whatever materials you can get your hands on.
I must not be a troll...
Mmmm, Guinness
McGee
O RLY?
PostPosted: 21:40 - 05 Nov 2005    Post subject: Reply with quote
If I can do the job my self i will do it if i cant i ask my dad Wink
Its pronounced Jixxer!
The last post was made 20 years, 334 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 2.59 - MySQL Queries: 15 - Page Size: 102.25 Kb
