Balancing the carbs
funmonkee
PostPosted: 17:12 - 20 Nov 2005    Post subject: Balancing the carbs Reply with quote
Does anyone have a newbie guide to balancing carbs? Or is that a bad idea since I've never done it before ...
I'm looking to do this for a Kawasaki GT550 and a Vmax...
Heyhoo any help much appreciated
P
**** Don't ride faster than your angel can fly Get this Free Space
The democratically elected Mod of the Scottish Section - The Peoples Choice[b]
bidman
PostPosted: 17:29 - 20 Nov 2005    Post subject: Reply with quote
Unless you've got a manometer don't bother trying, just take it into a garage, it's not all that expensive Thumbs Up
Don't ride it, RAG IT!!
White Noise
Mr Dudwee
PostPosted: 17:38 - 20 Nov 2005    Post subject: Reply with quote
you can make a manometer cheaply
https://www.obairlann.net/~reaper/motorcycle/manometer.html
never done it before but on my list of things to do! Rolling Eyes
stinkwheel has used this type of method before
WN
pipnet11
PostPosted: 18:40 - 20 Nov 2005    Post subject: Reply with quote
Now that looks a useful and quite obvious solution. Wont be too accurate i dont suppose but for next to nothing its good.
I love the girls that do, I hate the girls that dont, I hate the girls who say they will and then they say they wont, but the girl I like most of all and I think youll say Im right, is the girl who says she never has but looks as though she might. - Max Bygraves
White Noise
Mr Dudwee
PostPosted: 18:47 - 20 Nov 2005    Post subject: Reply with quote
TBH from what i believe to be true it will be more accurate than a mercury device as mercury travels less distance than water per unit of flow and hence using water rather than mercury you can see the error in the balance much clearer than mercury, and hence tune the carbs to a greater degree. think mercury is only used due to the compact nature of the substance, hence user friendly unless you crack one of the tubes open! Sick Evil or Very Mad
someone may need to confirm this of write it off as BS
WN
PostPosted: 19:24 - 20 Nov 2005    Post subject: Reply with quote
The tubes of mercury are open anyway (and the stuff came in a seperate bottle). Not seen mercury gauges for sale for years though.
Think mercury is 13~14 times heavier than water, so the water vacuum gauges will need to be larger by about the same amount which will make them rather too large to use most of the time..
quik_d
PostPosted: 20:46 - 25 Nov 2005    Post subject: Reply with quote
where do you connect it onto on the carbs and what stops them from sucking the water in?
LOOK AT DAT M8 WELL LUSH A PARROT INT IT
PostPosted: 22:14 - 25 Nov 2005    Post subject: Reply with quote
Nothing stops the water / mercury going into the engine except the height of the pipe.
If you look at the intakes between the carbs and the engine you will probably find either a pipe with a rubber cap over it or a small philips head bolt covering a hole. These are where you connect the vacuum gauges.
I have heard that some Hondas have had some silly system where they have no proper connector but instead you puncture the intake with a hypodermic needle.
DynaMight
PostPosted: 23:32 - 27 Nov 2005    Post subject: Reply with quote
Just buy: https://www.carbtune.com/carbdtls.html theres good instructions too. It's very easy and you'll ever wondered why you'd paid garages £30-40 to do it.
Ian (GPX)
PostPosted: 18:49 - 28 Nov 2005    Post subject: Reply with quote
I've got these, they work a treat Razz In saying that, it's time I did mine again .. Shocked
the grim reaper
PostPosted: 09:28 - 29 Nov 2005    Post subject: Reply with quote
I've got a set as well and they are the mutts nuts, they even do strokers, if you hang the guages upside down.
Grim
luigi
PostPosted: 11:15 - 28 Dec 2005    Post subject: carburetors balance Reply with quote
Hi,pblack.
Carburators balance it's a simple operation that (with the valve clearance check) can improve deeply the low speed driving (in the city traffic for example).
Operation involves only the idle screw if the engine are in good condition, and the air screw too if there's some leaking in cylinder.
In the second situation this is a more complicate and expert-mechanic work.
I only suggest you to turn the carburetors idle screws little by little trying to balance (if you have a four cylinder engine) the 180°phased cylinders in couple before and after the two couple between (e.g. on my Suzuki engine the first step is balancing the n°3 & n°4 before and the n°1 & n°2 after. The second step is balance the two couple between).
More the engine are in good condition, more you can read steadily the instrument.
A simple self-made instrument can be made by four table-tennis ball, four glass tube (from chemical furniture) with internal diameter close more than possible to the balls diameter, four air flow regulators and four rubber hose to collect everything to the carburators.
Remember to set the instruments before the balance following this procedure:
-choose a cylinder like you need.
-collect the glass tube n°1 to the carburetor of the cylinder.
-set the air flow regulator until the ball stays steadily at the middle.
-repeat the procedure for the other three glass tubes using always the same cylinder.
Obviously the description are rough but i hope to have explained all clearly
ciao Luigi
The last post was made 20 years, 69 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 76.24 Kb
