| funmonkee |
 funmonkee Super Spammer
| bidman |
 bidman Crazy Courier
 Posted: 17:29 - 20 Nov 2005 Post subject: |
Unless you've got a manometer don't bother trying, just take it into a garage, it's not all that expensive  ____________________ Don't ride it, RAG IT!! |
| White Noise |
 White Noise Mr Dudwee
 Posted: 17:38 - 20 Nov 2005 Post subject: |
you can make a manometer cheaply
https://www.obairlann.net/~reaper/motorcycle/manometer.html
never done it before but on my list of things to do!
stinkwheel has used this type of method before
WN ____________________ Buy my wife: 96' Yam XJ600s (Diversion)
Wing Commander White Noise - SE Clique
Riding Tip #86: See God, then back off a bit: Problem is i haven't seen god yet, just a close up of tarmac on revett straight |
| pipnet11 |
 pipnet11 Brolly Dolly
| White Noise |
| quik_d |
 quik_d Could Be A Chat Bot
 Posted: 22:14 - 25 Nov 2005 Post subject: |
Nothing stops the water / mercury going into the engine except the height of the pipe.
If you look at the intakes between the carbs and the engine you will probably find either a pipe with a rubber cap over it or a small philips head bolt covering a hole. These are where you connect the vacuum gauges.
I have heard that some Hondas have had some silly system where they have no proper connector but instead you puncture the intake with a hypodermic needle.
| DynaMight |
 DynaMight World Chat Champion
| Ian (GPX) |
 Ian (GPX) Brolly Dolly
 Posted: 18:49 - 28 Nov 2005 Post subject: |
I've got these, they work a treat In saying that, it's time I did mine again ..  |
| the grim reaper |
 the grim reaper World Chat Champion
| luigi |
 luigi Two Stroke Sniffer
The last post was made 20 years, 74 days ago. Instead of replying here, would creating a new thread be more useful? |
