Rust
hedjehog
PostPosted: 16:46 - 29 Nov 2005    Post subject: Rust Reply with quote
Hi all,
My CG is rusty in many places. Some on the frame is quite heavy. I'd like to
1. remove the rust
2. paint over
3. protect all areas
so:
1. Should I wait until the weather's nicer, or not?
2. Can the same procedure be used for the exhaust, and the frame, and the fasteners?
3. Is a wire brush the best way to remove the rust?
4. Paint. Searching on here, Stinkwheel has recommended stove paint for the exhaust (I'm quite positive about rattishness Smile ). Is heat-proof paint suitable for other bits? Or what's a better recommendation? And Scottoil FS365 for protection?
Thanks for taking the quiz Mr. Green
I can post some pictures if you want a laugh Neutral Wink
Should be inheriting some handlebar muffs from a friend soon. Grrreat for the cold thumbs.
Cheers,
Jack (hedjehog)
1988 CG125 BRE; 2000 GPZ500S D7; VFR 800 FI-X; 1980 CB 250 RSA; 1998 FZS 600 Fazer; 1986 Honda C70 E
bidman
PostPosted: 17:01 - 29 Nov 2005    Post subject: Reply with quote
Hey these answers should be a of some help
1. Should I wait until the weather's nicer, or not? No the sooner the better before it spreads anymore and you want it protected over the wet months really.
2. Can the same procedure be used for the exhaust, and the frame, and the fasteners? Yes as long as you use high temperature paint for the exhaust thats fine, but try getting some silver colour because black will look a bit daft on your chrome pipe Wink
3. Is a wire brush the best way to remove the rust? A wire brush or any abrasive material really, as long as its just suface rust your removing if its gone right through the frame may reuire grinding out and re-welding Confused
4. Paint? Halfords sell some good high temperature paint for 5.99 a can, available in different colours, its good stuff and protects as well. I recommend as a protection material, old engine oil. cover the exhaust and any rusty engine parts in old engine oil then once it heats up it will provide a protective layer over any metal. It looks dull but protects Thumbs Up
Hope that helps Thumbs Up, Dan
Don't ride it, RAG IT!!
the grim reaper
PostPosted: 17:21 - 29 Nov 2005    Post subject: Reply with quote
One note of caution with the high temperature paint. Make sure that whatever you are painting is COMPLETELY free of grease, dust, loose rust or any other conatminates. If you don't the paint doesn't adhere properly and just peels off as soon as the exhaust gets hot. DAMHIK.
Grim
PostPosted: 18:54 - 29 Nov 2005    Post subject: Reply with quote
Do not underestimate the properties of hammerite 'smoothrite'. Very forgiving when applied by brush.
romperstomper...
PostPosted: 19:24 - 29 Nov 2005    Post subject: Reply with quote
I find the hammered effect works best Thumbs Up
Yeah I know !
ZRX61
Victor Meldrew
PostPosted: 15:56 - 30 Nov 2005    Post subject: Reply with quote
Diluted phosphoric acid removes rust really well... Thumbs Up
romperstomper...
PostPosted: 15:57 - 30 Nov 2005    Post subject: Reply with quote
where do you get that from ?
Yeah I know !
ZRX61
Victor Meldrew
PostPosted: 16:07 - 30 Nov 2005    Post subject: Reply with quote
Auotpaint suppliers, failing that use Muracic acid from pool supply shops, but dilute it to about 10% acid. & ferfuxsake keep it away from aluminium & paint.
romperstomper...
PostPosted: 16:12 - 30 Nov 2005    Post subject: Reply with quote
thanks Thumbs Up
Yeah I know !
hedjehog
PostPosted: 16:59 - 30 Nov 2005    Post subject: Reply with quote
I like the acid idea (no nonsense grass roots). Just as good I bet as specialist rust remover but you don't pay for all the weird additives which, like expensive bike oil, probably aren't significant to the CG or me. But I reckon I'll go with a wire brush since you can paint hammerite (or similar) on surface rust when the loose stuff is removed.
I had a look at the hammerite site and only then did I realise that romperstomper1 wasn't making a suggestion involving inebriation as the solution to concerns about corrosion. Man. Idea
Eh?
Jack (hedjehog)
P.S. 'Hammered' does look nicest I think
map
Mr Calendar
PostPosted: 17:10 - 30 Nov 2005    Post subject: Reply with quote
Would suggst Hammerite Rust Remover Gel or Hammerite Kurust.
Have used the latter and found it ok. Turns rust black and then can be painted over. However, only used on small areas and careful not to get onto paintwork.
I think the Rust Remover is for larger areas.
Info on Kurust here - click me.
Rust Remover info here - click me.
Found they also do a dip (info here) that's useful for nuts, bolts, etc. Not used this either but will look into it.
HTH Thumbs Up
romperstomper...
PostPosted: 18:43 - 30 Nov 2005    Post subject: Reply with quote
hedjehog wrote:
I
it also seems to keep the rust at bay for longer Thumbs Up
Yeah I know !
BFG
PostPosted: 19:24 - 30 Nov 2005    Post subject: Reply with quote
map wrote:
Hammerite Kurust.
Used this for years - excellent stuff. Thumbs Up Thumbs Up
For small components, this is the ultimate rust removal:
https://myweb.tiscali.co.uk/andyspatch/rust.htm
sickpup
Old Timer
PostPosted: 20:11 - 30 Nov 2005    Post subject: Reply with quote
ZRX61 wrote:
Muracic acid.
Also sold as concrete prep.
mchaggis
PostPosted: 21:16 - 01 Dec 2005    Post subject: Reply with quote
https://www.janicewise.com/aj2050a.jpg
Should do the trick, though you'd have the sugar to worry about instead of the grease.
I must not be a troll...
Mmmm, Guinness
hedjehog
PostPosted: 11:57 - 02 Dec 2005    Post subject: Reply with quote
Indeed yes, McHaggis Exclamation :
https://img492.imageshack.us/img492/7551/colabike24rg.jpg
Surprised Laughing
Thanks for all the info folks!
Jack (hedjehog)
The last post was made 20 years, 262 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 94.81 Kb
