Bike DieD after being ALIVE!
NSR_KID
PostPosted: 17:17 - 13 Dec 2005    Post subject: Bike DieD after being ALIVE! Reply with quote
I warmed my bike up, left it like for 2 mintues on the choke and everything was good. Thought i would give a little rev before turning the choke off, however as i did, my bike just died. Now it bloody wont start?
Any1 got any suggestions why Crying or Very sad
( I know this should be in the workshop section, but if i post this thread thier i might get a reply by easter time if im lucky Wink )
If you die in an elevator, be sure to push the Up button
firefox
PostPosted: 17:22 - 13 Dec 2005    Post subject: Reply with quote
Check petrol, wires all still connected e.g ignition, fuses thats all i know :\ sorry Rolling Eyes
doggone
PostPosted: 17:23 - 13 Dec 2005    Post subject: Reply with quote
Not much to go on there - you need to check spark then fuel don't you.
I suppose it hasn't run out of petrol?
mr.z
You'll need to provide more info if you want a quick answer..
Done any serviceing recently?
Has it done anything like this before?
Has it got fuel?
What happened when you tryed to restart? what noise did it make if any?
Has it been layed up for any ammount of time?
colin1
Captain Safety
PostPosted: 17:25 - 13 Dec 2005    Post subject: Reply with quote
the plug could be dirty
get it out and wipe the electrode(the bit that goes in the engine, not the bit you attach the wire to)
a use a kitchen scourer, not the metal things, the slightly rough stuff on the back of the washing up sponge
NSR_KID
PostPosted: 17:26 - 13 Dec 2005    Post subject: Reply with quote
Has it got fuel?
This has happend b4, the spark plug went, i just changed it a month ago.
its on a full tank.
When i stat it up it makes that jurking noise.
Hope this help Rolling Eyes
firefox
PostPosted: 17:29 - 13 Dec 2005    Post subject: Reply with quote
spark plug not went again mate ?
NSR_KID
PostPosted: 17:31 - 13 Dec 2005    Post subject: Reply with quote
it might have, if it has why does it get messed up so quickly? only been a month
firefox
PostPosted: 17:33 - 13 Dec 2005    Post subject: Reply with quote
Im not sure with that igntion unit could be on its way out ? could be giving to much power to spark plug if possible ?
NSR_KID
PostPosted: 17:35 - 13 Dec 2005    Post subject: Reply with quote
it just takes the piss to change the sparks every 2 secounds Rolling Eyes
firefox
PostPosted: 17:38 - 13 Dec 2005    Post subject: Reply with quote
Garage ? Very Happy will prob be cheaper in the long run if its going to burn the plugs out so much. wait for some real help off the forum sorry i coundt help anymore. Sad
Andy C
Tree Seeking Missile
PostPosted: 17:39 - 13 Dec 2005    Post subject: Reply with quote
it hasnt gone, it need a clean probably, take it out and clean the electrodes like colinwall says and put it back in and should start with a bit of effort
tokarev
PostPosted: 17:42 - 13 Dec 2005    Post subject: Reply with quote
Well, check the plug and see if thats the prob.
What plug are you using? You should be using either a standard one; BR9ECS or the more expensive better one; BR9EIX. Both are NGK.
HTH.
vlf
PostPosted: 17:47 - 13 Dec 2005    Post subject: Reply with quote
Happened to me twice... Once the spark plug had gone, the other time I had the fuel tap switched to off.
Rob W
PostPosted: 17:57 - 13 Dec 2005    Post subject: Reply with quote
My bike's weird like that. Sometimes I disable the alarm, turn on the ignition and it'll turn over, just wont fire. I then have to turn the ignition off and start all over again, sometimes 3 or 4 times before it will fire up.
Confused
Aikman666
PostPosted: 18:20 - 13 Dec 2005    Post subject: Reply with quote
Could be the mixture constantly fouling the plugs. Have you ever changed anything to do with the air filter or exhaust? If the bikes input/output has been changed without 'retuning' then it could foul plugs very fast indeed
Will work for petrol
My Design Blog
NSR-Rulez
PostPosted: 18:41 - 13 Dec 2005    Post subject: Reply with quote
same just happened to my NSR, the plugs get dirty from the oil, so you need to give it a clean 9Use a rag and a wire brush), pop it in let the carb fill with fuel then hit the starter.
Works everytime
Hope this helps
NSR-Rulez
Past: 1985 Suzuki GS 125 + 2002 Honda NSR 125 R-2 + Ford Fusion
Present: Honda CBR 600 RR-5 + Suzuki SV650S-K4 + Mitsubishi FTO GPX
cathawhitt
PostPosted: 19:05 - 13 Dec 2005    Post subject: Reply with quote
Sorry but how do you know if ya plugs are shot??? Mine are black after a couple of weeks!!! Is this is a gd sign??? It still runs.
My bike sometimes stops when left idle but there is a screw on the carb that ya turn and it helps!!!!!! I had to to turn clockwise last week to make it run properly only a short amount.
I wonder if you have to do the same?!
Rob W
PostPosted: 19:57 - 13 Dec 2005    Post subject: Reply with quote
Sounds like your running too rich. If you have a service manual try and find out what the standard carburation settings are and adjust to suit.
Jack_Cheese
PostPosted: 21:16 - 13 Dec 2005    Post subject: Reply with quote
Confused
My scooter's like that, i think it's just the immobiliser being hormonal with the chip in the key...
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
The last post was made 20 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 105.96 Kb
