ACF 50 does it work or your alternative
Itchy
PostPosted: 11:04 - 14 Dec 2005    Post subject: ACF 50 does it work or your alternative Reply with quote
Howdy
As some of you folks know I'm bikeless till January thing is Cornwall is pretty mild compared to the rest of the country with only oine snow fall and barely ever any salting of the roads (can be good can be bad) , the trick is I've got to ride me bike down from manchester a 365 mile trip through heavily salted roads , most probably rain snow and ice and motorway spray + salt.
So I've seen this stuff called ACF50 which the US Navy is alledged to use cover up your bike with it (apart from the brakes and chain which I don't have) and hey presto a neat weather proof film over your entire bike so washing after every winter ride is not necessary but once a weekand reapplication.
I'm always a firm believer of tooo good to be true = too good to be true / snake oil ,
so has anybody here tried it does it work? , £20 a can vs WD40 £2 a can
if not what are your solutions ? somebody I know in Plymouth covers her Hornet in WD40 ,
Thanks
ZRX61
Victor Meldrew
PostPosted: 19:05 - 14 Dec 2005    Post subject: Reply with quote
USN use it to keep seawater out of their aircraft. Having said that, the USN likes Grummans which just happen to be built like battleships anyway.
Bezzer
PostPosted: 20:57 - 14 Dec 2005    Post subject: Reply with quote
ACF50 works great, doesn't wash off easy same as WD40 and the like and does exactly what it says on the tin. I stocked up at the NEC for £7.50 a can, it's usually around £12-13 not £20.
Itchy
PostPosted: 21:08 - 14 Dec 2005    Post subject: Reply with quote
thanks ,I knew it was something like that but I recently saw a can in some iffy motorshop for £20
Andy C
Tree Seeking Missile
PostPosted: 21:43 - 14 Dec 2005    Post subject: Reply with quote
How does WD40 work to prevent whether?you just rub it in all you paintwork and metal bits and helps prevent whether damage??
not saying it doesnt or anything would like abit more information if you could!!
syl
PostPosted: 21:51 - 14 Dec 2005    Post subject: Reply with quote
Just spray it on. The WD stands for "Water Displacement" (40 shows it was the 40th attempt) - itr displaces water and prevents corrosion.
https://www.wd40.com/Brands/wd40_faqs.html
syl
PostPosted: 21:57 - 14 Dec 2005    Post subject: Re: ACF 50 does it work or your alternative Reply with quote
Thanks
Scottoiler FS 365 Protector Spray is an alternative that seems to be widely used - should be available in most bike shops for about 6/7 quid per litre spray bottle.
The last post was made 20 years, 302 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 53.84 Kb
