Seized 2-stroke
Alastair
PostPosted: 11:54 - 19 Dec 2005    Post subject: Seized 2-stroke Reply with quote
This has to be the most embarrassing thing ever, especially as I've only just got the bike but;
I managed to let the oil run out on my TDR (I don't think the warning light works properly) so obviously the engine seized.
Is this repairable or going to need a replacement engine? Is it the same as a hot seize? The kick start is solid but the bike did go into neutral. I'm no wizard with a spanner but can attempt most things and can manage things with the help of a Haynes manual.
I'm really hoping I can sort this out as being on the bus again today was MURDER!
Any advice appreciated, thanks.
EDIT - Just to save face a little, it really doesn't seem that it did run out of oil now, not sure yet what did cause it though.
PostPosted: 13:53 - 19 Dec 2005    Post subject: Reply with quote
It will be rapairable, although depending on how un/lucky you are a 2nd hand replacement engine may be cheaper.
First thing is to find out what has seized. For me the top end has always freed off shortly after seizing, so it might be the bottom end that has gone.
Drain the coolant and try taking the top end off and take a look.
PostPosted: 13:55 - 19 Dec 2005    Post subject: Reply with quote
Depends. Probably the same as heat siezing as there is often a fair bit of oil floating about in the bottom end which would keep the mains and big-ends lubed for longer than it takes to dry sieze the bore.
Only way to find out is pull it apart and have a look.
At a minimum it will need a rebore/plate and new piston/rings (may as well replace the small ends while you are at it).
At worst the mains and big end will be gubbed which would mean a service exchange crank, new bearings, conrod kit, piston and rebore. Might still be cheaper than a new engine though, especially if you fit the parts yourself. The only real biggy would be the crank...and the barrel if it is nikosil coated.
Dischord
PostPosted: 20:03 - 19 Dec 2005    Post subject: Reply with quote
try bump startin it first, it might unseize and ride away, it happened to me twice! but they free'd up within 2minutes of seizing, so if you left it seized chances are it will need a rebore!
2012 KTM EXC 250
DM
PostPosted: 00:52 - 20 Dec 2005    Post subject: Reply with quote
I seized a 50cc Runner's piston around 10-12 times (out of oil) and it still ran fine. Of course, opening it later revealed a sickeningly scored piston/cylinder, yet the compression stayed at a very acceptable level so I never told my friend when I gave it back Embarassed.
Alastair
PostPosted: 16:44 - 20 Dec 2005    Post subject: Reply with quote
Been at home today trying to sort it out. have got the head cover off, piston out, cylinder and exhaust off too.
Seems the piston exploded rather than just get wedged so there is a lot of debris in the bottom half of the engine. Any idea what I could try next to get it all out?
PostPosted: 16:51 - 20 Dec 2005    Post subject: Reply with quote
Probably safer to split it. Although I have flushed the crankcases in 2-strokes before. What we did with my mates H100 that was in a river for a few days before we bought it (cheap) was to flush all the silt out with diesel.
Just repeatedly filled the crankcase with diesel, swooshed it about, spun the crank in it then turned the whole engine upside down and emptied it out. When we were happy it was clean, we flushed it again with 2-stroke pre-mixed petrol to make sure the bearings had plenty of oil then banged it back together again.
Alastair
PostPosted: 10:55 - 21 Dec 2005    Post subject: Reply with quote
Yokogeri wrote:
I gave you half a bottle off TTS (500mils or so) and said it needed topping up soon and not to rely on the oil light guage as if never ran it that low to test it incase it didnt work and did exactly what its done to you.
To be fair Scott that's not exactly what you said and when I specifically asked you when I first saw the bike if the oil light worked you did say yes.
I'd only done about 20-25 miles on the bike since you delivered it too and the irony is I was going to top it up that evening.
No point getting into it though as this it what has happened and I have to fix it or bin the bike.
I'm not 100% sure anymore that it did run out of oil as the bleed screw only ran dry for a second before oil came out but I had re-filled it first. When I did re-fill it it didn't take the whole 500ml either and I think the oil tank is bigger than that so it may be something else. Broken oil pump? Reeds?
It will probably be going into a bike shop in the new year for some expert opinion about the debris in the bottom of the engine unless I find time to pull it all apart before then. I've started to get to the stage where I can't do too much else myself.
PostPosted: 11:54 - 21 Dec 2005    Post subject: Reply with quote
That doesn't sound like it has run out of 2 squeak oil. Not certain about the TDR but it is rare that road bike 2 stroke oil tanks take less thanb a litre in size.
It is possible to get air in the 2 stroke oil line (leave the bike running on its side for a while might do it, but likely to cause other problems first), but not common.
If it has destroyed the piston in style as you say then it is possible that it has cold seized (were you thrashing it when cold?) but most likely it is just bad luck as to when it has failed.
John C
PostPosted: 13:43 - 21 Dec 2005    Post subject: Reply with quote
When I low-sided the bike the other day at low speed the bike was left ticking over in first gear with the back wheel spinning for about 30 seconds.
Should I be concerened and bleed the oil, or will any air work it's way out? I did about 15 miles going up to 10k revs at times after I picked it up and it seemed fine.
Alastair
PostPosted: 15:21 - 21 Dec 2005    Post subject: Reply with quote
Do I win any prizes for the most spectacular piston failure?
I'm not too hot on how long to leave it warming up to be honest, I left it standing (upright) for about 2 mins, then rode easy for another 5-10 before giving it any welly. I did thrash it before it blew up but when it actually went I was only at mid revs.
Starting to think it was bad luck more than anything and I'll have to chalk it up to experience and just pay to get it sorted. Will get the pump and reeds checked out though so it doesn't happen again as soon as I put it all back together!
lilredmachine
PostPosted: 15:42 - 21 Dec 2005    Post subject: Reply with quote
nice one Thumbs Up
certainly does not look like a lack of oil seize TBH.
John C
PostPosted: 16:05 - 21 Dec 2005    Post subject: Reply with quote
ace Thumbs Up
Looks like you've been feeding it ball bearings. Very Happy
PostPosted: 18:36 - 21 Dec 2005    Post subject: Reply with quote
If it was going to cause a problem then I would suspect it already would have done. Only real issue would be if it was on its side long enough for a large air bubble to form.
Piston is a bit of a mess. Not sure that is a heat or oil related seizure (possibly the long term result of piston damge from a seizure in the past). I do think that it needs a strip down to clean the rubbish out of the crank cases.
This is the piston from Charlottes CB125T many years ago.
https://www.alfa-pages.co.uk/TempPicture/piston.jpg
PostPosted: 18:41 - 21 Dec 2005    Post subject: Reply with quote
Guy up the road from me has a Z650 piston with a valve embedded in the piston crown so firmly you can't pull it out.
I have a Jawa 350 piston somewhere with the skirt ripped off, gudgeon pin ripped out and three needle rollers from the opposite side small end embedded in the crown.
EDIT: looking at that picture, it looks like the piston crown is 'dinged over' at one point? Has it hit the head? If it has, this would suggest one of the main bearings or big end has let go.
It will need pulling apart and the crank spinning up with a dial guage, if there was enough force to rip the gudgeon pin out through the bottom of the piston, there was enough force to make a bent crank a possability. The conrod is almost certainly gubbed.
satans_BIG_helper
PostPosted: 22:46 - 21 Dec 2005    Post subject: Reply with quote
I seized my old TZR250 pretty badly before.... some little pikey on my estate had cut the oil line... no amateur really but it still happened... rode fo about 20 miles at about 25 MPH cos it wudnt pull.. then it died n pissed petrol n coolant everywhere....
the left hand piston had gone all the way throough on the top and the rings had melted into the barrel... and the right hand one looked like a rat had been in the barrel chewing at it....
end result pair of new barrels, pistons, n a crank rebuild as it done the main bearings too etc... very messy Laughing
Alastair
PostPosted: 12:18 - 04 Jan 2006    Post subject: Reply with quote
Right, nothing has changed since my last post as I couldn't do anything over the xmas break.
Am starting to look for replacement engines now though, is there anyway of knowing what engines will fit? Is it as simple as any TDR/DT/TZR engine or are there other things to consider?
Would frame numbers help me determine which to buy etc?
All help much appreciated as I really want to get it back on the road as soon as I can now.
Knowlsey
PostPosted: 01:17 - 05 Jan 2006    Post subject: Reply with quote
pity, got one of those chinese engines, but dont think they will fit the tdr
faith183uk
PostPosted: 12:25 - 09 Jan 2006    Post subject: Reply with quote
Ebay has a few TZR engines on there at the mo.
This one looks very clean for the year, but obviously id get more info from the sellers before making a decision.
https://cgi.ebay.co.uk/TZR-125-ENGINE_W0QQitemZ8027366536QQcategoryZ10490QQrdZ1QQcmdZViewItem
Alastair
PostPosted: 12:32 - 09 Jan 2006    Post subject: Reply with quote
Thanks so much for the heads up - had missed that one with all my searching.
Got outbid on sat night by someone using software to snipe auctions on a DTR engine that looked great.
Will the TZR engine def fit is my only concern now as it looks a bit different to the DT and TDR engines I've seen.
Alastair
PostPosted: 14:14 - 24 Jan 2006    Post subject: Reply with quote
I'm still in exactly the same situation and but had decided to get it rebuilt. I have been let down by a mechanic twice that was going to come and pick up the bike though. If he doesn't want my money, fine, someone else will get it. Mad
Have had time today to take the engine out but I've spotted something that to my untrained eye looks pretty terminal. See the bit inside the red circle on the attched pic, that shouldn't be bent should it!?!
Does it look like a replacement engine is the only way to go now?
Gazdaman
I did a trackday!!!
PostPosted: 14:39 - 24 Jan 2006    Post subject: Reply with quote
No, I don't think that should be bent.
But with that much crap in the bottom half of your engine, I'd be looking for a new lump anyway.
Engines for a bike of that age are pretty cheap, splitting crank cases is /not/ fun.
Gaz
cagiva gezzer
PostPosted: 20:05 - 24 Jan 2006    Post subject: Reply with quote
Way too much crud in that bottom end to even consider using it without stripping it. The crankcase shouldn't be bent, it's taken a hell of a whack from the con rod.
ancientd
PostPosted: 20:39 - 24 Jan 2006    Post subject: Reply with quote
Judging by that bending in the case it looks like one of 2 things has happened, either the reeds have been sucked into and through the engine, (you haven't taken off the air filter have you?) or the big end failed.
I ride 3 bikes, a Thundercat, an FZRexup 1000 Streetfighter and a Jawa 350 Combo, something for all seasons.
Alastair
PostPosted: 21:11 - 24 Jan 2006    Post subject: Reply with quote
Wasn't going to try and use that engine without a full rebuild don't worry. If it is fixable it'll be a full strip job Shocked
Air filter is still in place and the reeds actually still look pretty decent (to my eye and it's the first time I've ever seen reeds), so it probably is the big end but i wont know till I split it and I don't know if I'd ever get it back together!
The last post was made 20 years, 270 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 132.76 Kb
